Frontera Technical Support • View topic - what am I??
what am I??
Re: what am I?? by alex on Wed Sep 03, 2008 7:48 pm
Dave, I am surprised you aint spotted it....
Bernie, thanks mate, will let everyone know, will be an interesting fitup. Am going for 30mm at the mo...
Will give everyone a clue...
You need a 22mm spanner to get em off.... oh and a bloomin big bar.
Re: what am I?? by alex on Wed Sep 03, 2008 7:49 pm
Drift and beer? thats still a rumour??? :drink:
Re: what am I?? by woodwizzard on Wed Sep 03, 2008 7:51 pm
Re: what am I?? by alex on Wed Sep 03, 2008 7:59 pm
Re: what am I?? by Drift on Wed Sep 03, 2008 8:03 pm
:drink: try me :party:
Its still difficult
Re: what am I?? by weave67 on Wed Sep 03, 2008 8:04 pm
ahh ime getting it now :roll:
Re: what am I?? by woodwizzard on Wed Sep 03, 2008 8:07 pm
What is it then Dave?
Re: what am I?? by Trugga on Wed Sep 03, 2008 8:08 pm
I could well be interested in the first exchange set - would need a hand with the swap though
Re: what am I?? by Drift on Wed Sep 03, 2008 8:10 pm
Re: what am I?? by woodwizzard on Wed Sep 03, 2008 8:10 pm
Brackets for dropping the axle?
Re: what am I?? by alex on Wed Sep 03, 2008 9:17 pm
:well done:
As many of you already know, the higher you lift the car the steeper the cv joints have to be. To a point where I now slice my cv boots off if I fully articulate (cv shaft touches outer edge of cup, boot gets pulled in and it cuts a very neat edge in 1 revolution)
1 solution is to lower the car a tad :cry:
2 solution, lower diff to bring it and the hubs back into alignment and keep the lift :dance:
I have a spare set of cv's and diff hangers, so it was just the effort missing to get into it. Oil seals are about £16 a set (they don't come off) bearings have come off, that get it stripped to the piccy with half shafts out.
I will do mine and if it works weld up the old ones, then mod them to pass on. You will need to re-use or replace your own circlips,seals and bearings.
Obviously will help out too.
Mods to members and trays TBA, have a spare member too, bring yer own bash plate (aint doin everythin)
Re: what am I?? by weave67 on Wed Sep 03, 2008 9:23 pm
hmmm i will be keeping an eye on this,oh and ime available weekends if you need a lift alex :wink:
Re: what am I?? by alex on Wed Sep 03, 2008 9:45 pm
Cheers Dave, could be a full meet :lol:
Re: what am I?? by Sir-Doris on Wed Sep 03, 2008 11:07 pm
Im volunteering aid cause I wants some :D :D :D Willing to travel to see this.
Alex, I now have the same problems as you re: splitting gaitors. The split one I replaced went after the weekend.
Let me know where and when will do me best to makes it up :D :D :D
Re: what am I?? by alex on Thu Sep 04, 2008 7:17 am
TBH Phil,
If you want the experience for yourself then of course your welcome, but wouldnt expect someone to come that far to secure a set. You will of course be a priority for getting a set :wink:
Wonder if anyones breaking a few A's.
Re: what am I?? by Sir-Doris on Thu Sep 04, 2008 11:06 pm
Hmmm... There is a possibility I may come up for the social side of things anyway, and there is also the possibility that I may have the front diff off the car sometime soon as I have to do front brake discs and CV joint boots all round as well as rear propshaft UJ's AND sort something out with those gearsticks. Had a shower of water in the car after a deep water crossing at Strata Florida. Alternatively I may try and make do with just the spacers and see how I get on with those.
Re: what am I?? by alex on Fri Sep 05, 2008 7:25 am
:lol:
Always welcome mate, with the tops flipped and if youve had the 4 bolts out of the lowers recently then removing the hub is a doddle. cv's will then depart easily for working on.
Up to you on the spacers.
Upon inspection the 2 mounts on the hangers are actualy some sort of pressed rubber bush. It explains why each turn with a bar needed a good 120 degrees of movement to get any sort of turn on the bolt.
Re: what am I?? by Sir-Doris on Fri Sep 05, 2008 8:55 pm
As Iv been overbooking myself a bit lately can we confirm when this meet will be taking place?
Re: what am I?? by alex on Fri Sep 05, 2008 9:09 pm
erm.
Gimmie a dry weekend day to remove. Then it'l likely be the next dry weekend day.
So December ish I reckon. :roll:
Couple of weeks If I get breaks ith weather, or a beautiful evening or two.
Re: what am I?? by Sir-Doris on Fri Sep 05, 2008 9:18 pm
Ok, best I just see when its all taking place and see if I can make it.
