Make sure you count how many complete turns you un-wind it.
Use a marker pen and put a mark on your Chassis, and then put a corresponding line on your 27mm socket.
Makes it much easier to set it back up after you have fitted your ball joints.
Flipped Ball Joints.
• Page 2 of 2 • 1, 2
Re: Flipped Ball Joints.Comments on Betsy here please!!! viewtopic.php?f=115&t=56282
Bobster!!!! Frontera's do it better in MUD!!! ![]() West Midlands Area Rep Its here, the FOG Annual Meet 2014 viewforum.php?f=123
Re: Flipped Ball Joints.Make sure you count how many complete turns you un-wind it.
Use a marker pen and put a mark on your Chassis, and then put a corresponding line on your 27mm socket. Makes it much easier to set it back up after you have fitted your ball joints.
Re: Flipped Ball Joints.did not touch the torsion bars, just used very long bolts to pull them back together, then removed one at a time and replaced with new nut and bolt
Who is onlineUsers browsing this forum: No registered users and 5 guests | ||
