Frontera Technical Support • View topic - What a week~! *sigh* >>> WIRING HELP NEEDED <<
by Drift on Fri Feb 15, 2008 11:13 pm
Si, is it not in the isuzu wiring diagrams you had when you where doing the conversion ?
by rangaKoo on Fri Feb 15, 2008 11:19 pm
Ummmm, dunno, don't have those at the moment to look
Will have to try it out in the morning, was kinda hoping someone would know for sure.. heheh
Just been looking at the old thread and found this:
WHITE (Solid) goes to battery for regulating the voltage.
WHITE (Red) goes in to the loom from the 2.0i
BLACK (Yellow) goes to the stop solenoid
and this:
ALTERNATOR SIDE (in caps)
WHITE WITH RED TRACE goes to the battery light on the dash it's a white with red trace wire as well.
WHITE (no trace) is voltage regulator direct to POSITIVE on battery.. (THIS one receives voltage FROM the battery and regulates how much charge to put back in to the battery)..
BLACK WITH YELLOW TRACE is to the Stop Solenoid.. (THIS one turns on the CHARGE SYSTEM, otherwise without power to this one the charger doesn't kick in from the alternator)
Both were posted by me..
Ummm, anyone able to clarify any of this for me?? :shock:
I don't wanna break it
Si
rangaKoo
by Trugga on Fri Feb 15, 2008 11:53 pm
by rangaKoo on Fri Feb 15, 2008 11:56 pm
rangaKoo
by Trugga on Sat Feb 16, 2008 12:11 am
by willowkevin on Sat Feb 16, 2008 10:00 am
frontera 2.8td hybrid
willowkevin
My car is mostly a Frontera
Vehicle Name: molliemobile
Modifications: hybrid isuzu 2.8td .5th year on still going strong ...
by Trugga on Sat Feb 16, 2008 10:06 am
Just for reference, here is the back of the alternator:
by Red Oktober on Sat Feb 16, 2008 10:10 am
i'll have a look at the wiring on mine today ......
see if i can make any sense of what colours they are and where they go
by Trugga on Sat Feb 16, 2008 10:11 am
The Haynes manual (Page 13.22) indicates the following.
A. A big red wire connecting to the starter motor
B. A black earth wire to chassis
C. A white (that subsequently splits to two green) wire that goes to the tacho
D. A black/white wire going to the ignition lamp/heater relay
That is my interpretation of the Haynes diagram.
As to where each wire physically connects, I don't know - but I will have a look within the hour.
by rangaKoo on Sat Feb 16, 2008 10:18 am
rangaKoo
by Trugga on Sat Feb 16, 2008 10:42 am
by rangaKoo on Sat Feb 16, 2008 10:45 am
rangaKoo
by Trugga on Sat Feb 16, 2008 10:46 am
Right, inside of the connector, that corresponds with the alternator connector above:
and two of the back where the wires go in:
The actual wire colours (well, on mine anyway) are:
....| green/black
_ _
Black/white... red/white
Does that help ?
by willowkevin on Sat Feb 16, 2008 10:51 am
trugga , on the 2.8 trooper the tacho feed comes from the injector pump !but then again its not in a trooper is it ? :lol: ranga ,look on the bright side theres one wire less to connect ! you know one wire goes to the alty/battery circuit , one wire will be for the ign/no charge warning light and then isn't one going to be the exiter wire ? the one that tells the alternator to charge ?? looking at the haynes book i have to admit that i havn't a clue how to use the wiring diagrams for the later model ! :oops:
edit - why not fabricate brackets to fit the 2.0 alternator ? then you can use the origional connector ? and the stop solonoid just wire to the on side of the ign switch ? messing on i know but you'd know the wiring was right :wink:
willowkevin
by rangaKoo on Sat Feb 16, 2008 7:33 pm
Ok, after much shouting, cursing, swearing, many millimetres of missing skin and a few bent bits of metal and piping...
The alternator is IN..
And apparently working.
BUT for future reference for anyone considering swapping bits between Isuzu engines and Frontera 2.8 engines things are NOT the same.. The block, the head, and a few other little ancillaries are the same but things like the the alternators are different.
I will explain later.
Si
rangaKoo
by Trugga on Sat Feb 16, 2008 8:07 pm
I'm glad to here it's on and working, especially after the phone call following the number plate kicking session :shock:
by rangaKoo on Sat Feb 16, 2008 11:59 pm
rangaKoo
by Trugga on Sun Feb 17, 2008 10:07 am
This is the engine dressed allready to go in
I don't think I have another picture side on, but you can sort of see the clearance you should have.
