Re: WHAT YOU DID TO YOUR TRUCK TODAY! by DAZZA75 on Fri Nov 13, 2009 1:01 pm
Fitted a set of 4 insa turbo dakar's 265/75/16
DAZZA75
Modifications: 2"bodylift
insa mud tyres 265/75
hd shocks & rear springs
exhaust mod
roof lights
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 13, 2009 1:16 pm
Ive had a set of them, rather nice tyre :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by quiteone on Fri Nov 13, 2009 2:25 pm
Started on today and working over most of weekend.
Throttle body and inlet manifold off for a jolly good clean, replace throttle body and manifold gaskets
may even take out the injectors and have them ultrasonic cleaned, whilst out I will see if there any aftermarket jobby's that I can fit.
New fuel filter to fit
Cooling system flush and new antifreeze, replace clips on pipes with nice shiny new ones
Remove cam cover replace gasket and spray cam cover,
Gaz
quiteone
Modifications: K&N Panel filter.
"A" bar and spots refitted.
Wind deflectors.
4 branch performance Exhaust Manifold
and a stinky bear called Rufus.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri Nov 13, 2009 7:26 pm
Not today, but yesterday seeing as the Fronty now has an 80mm body lift, I relocated the fuel tank 80mm higher :dance:
Bought another tank carrier as mine was more iron oxide than iron, cut off the mounting brackets, jacked the tank carrier up as far as it would go and re-welded the brackets back on. Then wire brushed it clean and painted it black.
Did a few tidy up jobs after the body lift, new vac hose for the servo, power steering pipes and bottom rad hose lengthened as they were all a little on the short side :wink:
And today I replaced the timing belt on Dave Raynets 2.0 SWB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Nov 13, 2009 8:00 pm
Well today i removed and fitted the new axle with massive help from Jason :D Was going to refit gearbox but as the weather was wet i deiced to fit it next weekend as i am working for the next 7 days :( Hopefully have it moving next weekend :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Nov 13, 2009 9:30 pm
sat there looking at her, and wondered how much she is worth, and is it all worth it, then i did go and take the antara for a test drive, and fell in love with it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sat Nov 14, 2009 1:50 pm
Silly boy
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sat Nov 14, 2009 5:44 pm
I moved it!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Nov 14, 2009 5:55 pm
sod the antara, i have been looking at a 2.5 v6, and its looking promising
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 14, 2009 5:57 pm
I looked at mine between the rain drops :roll:
Andy, they are 3.2 V6's :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Nov 14, 2009 6:07 pm
oh yer that one, 3.2 v6
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 14, 2009 6:11 pm
:lol: :lol:
Where is it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Nov 14, 2009 6:21 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 14, 2009 6:34 pm
More details please 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Nov 14, 2009 6:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 14, 2009 6:47 pm
You cock :butt:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sat Nov 14, 2009 6:55 pm
Went to give Tessie her service today(even if the weather was against me :lol: )
new air filter and fuel filter fitted,went to start engine to warm it up to make oil easier to drain and she wont start :( :(
the engine will turn over with a nasty metallic squeal comming from the top of the engine.
Looks like i will be working on Tessie again tomorrow.
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Nov 15, 2009 3:23 am
Tweaked the gear lever and transfer lever and tested them out, still not quite right so tweaked them lots more and they are better but I'm not totally happy with them :roll:
BUT
Seeing as I'm off laning in the morning it will do for now :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sun Nov 15, 2009 5:21 pm
Today I have replaced the fuel filter and sparkie plugs, now I no longer have a "flat/dull" spot between 2krpm and 2750rpm
also flushed the oil and replaced the filter...
replaced the missing sunroof trim, and replaced the melted lower light lenses.
oh one more thing...
replaced the cracked air box lid and flexie pipe (that may have helped with the dull/flat spot I had)
and a couple of other little bits and bobs that I kept on meaning to do, but never got around to.
now it's :drink: o'clock
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Sun Nov 15, 2009 6:27 pm
Started operation swap shop got to say looks mean on me alloys off me leafer 8) 8) 8) going stick some pics in members rides later :wink:
