Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat Oct 31, 2009 10:17 pm
Well as I drive a normally ultra reliable 2.2 Dti me & she went for a drive,only thing of note was getting wheel spin in second while "dragging" a scooby at the lights,pointless exercise but a giggle none the less :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sat Oct 31, 2009 10:42 pm
Not so much what I did to the truck but more what I did with it. The Mrs and her friend took a little jaunt over to France for the day for a bit
r+r and some shopping. On the way back there was a bit of a panic as they thought they could smell burning coming from the 07 plate Zafira, so
as soon as they could they pulled in to a layby on the dual carriage way or what they thought was a layby. Turned out it was an escape lane for
lorries and the Zafira sank into the gravel up to its sills. KITT to the rescue then, hooked up the tow rope, put it into 4WD and dragged the helpless Zafira out of the gravel back onto blackstuff. :roll: :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Oct 31, 2009 10:56 pm
Hah, yeah, I've seen that happen before.
Way to go Krusher and the pink one for coming to the rescue
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Oct 31, 2009 11:18 pm
I saw a Pink fronty in Ramsgate today...lurking outside a row of shops...whilst I was doing some service calls down there...
I yelled..."Oi you with the PINK fronty," out of the window of the works Ashtray....
much to the Krushers amusement.... :wink:
Turns out that Krusher was there as he was getting some "dressing up clothes" from the fancy dress shop :shock: :wink: :wink:
Had a brief chat, then Krusher dared me to try and eat 2 jumbo battered sausages from the chippy....I took the challenge despite the diet as didnt want to be a spoil sport... :lol: :lol:
Then went and did my call nearby....blamed the traffic for being late :shock:
Hope the dressing up stuff works for you mate... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Oct 31, 2009 11:26 pm
Finished fitting new copper brake pipes and braided hoses, bled brakes and while I was at it bled the clutch as well as it felt a bit squiffy and looked very black and yucky.
Did oil and filter change on the engine.
Was gonna fit new shock bushes but seems to be a mix up with my order from Difflock :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sat Oct 31, 2009 11:29 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sun Nov 01, 2009 12:14 am
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Sun Nov 01, 2009 12:15 am
New cam cover gasket fitted, hopefully no more oil leak now.
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Nov 01, 2009 2:06 am
nothing to say
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Nov 01, 2009 5:03 am
Where to begin, It all started last week. Fitted a new crankshaft sensor and took the car for a drive, no more EML and seemed a bit pokier.
Parked the truck in the garage in preparation for the peak district/lake district trip. Next day loaded up the car with the camping gear in the garage, went to start it and nothing, engine turned over but nowt happening in the sparkplug igniting the air/fuel mixture department.
Checked fuel, none happening, checked spark, none happening. Changed relays one by one with spares from the donor car, nothing happening, checked fuses, nothing doing. after a lots and lots more attempts to start the immobiliser started flashing and going haywire. Swapped ecu and immobiliser from donor car, still no spark and no fuel and immobiliser and eml going bonkers, flashing away and generally not doing what they normally do.
Sod it, missed the peak district trip but went camping in the lake district anyway, went in Meryls car. Dropped the ECU off at Camco in Warrington to get de-immobilised, picked it up on thursday on the way back. Plugged it into the truck and still nothing except now Im getting fuel but no spark.
Traced all the wiring back from the DIS module to the ecu and back again, swapped fuel injection relays with a neighbour to see if that helped. Still nowt.
Pretty much at the end of my tether here now as the dash is out of the car along with lots of other bits. On a whim and really as a last resort I put the old Crankshaft sensor back in just to see and guess what, fired up first time.
Just finished putting the whole lot back together about an hour ago (3am). Tightened up lots of bolts behind the dash so hopefully no more creaking, cable tied a tonne of wiring loom so no more loose wires under the dash and generally rerouted several cable runs while I was at it.
Took ages, felt like hitting summat with a hammer at several points and the worst thing about it was that if I wasnt able to do it myself I wouldnt even have been able to get the car to a garage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sun Nov 01, 2009 6:00 pm
Fitted a new set of rear brake pads and will be putting a new set of fronts aswell this week some time....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Nov 01, 2009 6:01 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Nov 01, 2009 8:56 pm
Only meant to copper grease the brake pads on the front to stop the squeeling and ended up regreasing the front bearings and hubs and brake caliper sliders as well as the piston. Had a good old tidy up in the garage as well.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Mon Nov 02, 2009 4:03 pm
started to sort out the little rust holes ready to be welded. loose rust out and lashings of rust treatment and a couple of coats of primer for temp protection
i did find a pipe inside the rear sill goes up into the rear body looks like a drain pipe but was inside the sill so i'll re direct when the works done ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Mon Nov 02, 2009 10:18 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Nov 02, 2009 11:13 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Tue Nov 03, 2009 1:00 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Wed Nov 04, 2009 11:18 pm
Drove KITT up into london today for a driving assessment for my new job. First heavy traffic been in since new rad fitted. KITT performed
flawlessly unlike some of the newer cars that were sat at the side of the road with streams of coolant running out from underneath them :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Thu Nov 05, 2009 3:47 pm
Stuck a replacement rad in the 2.4 and freed up the headlight adjusters, as mis-aligned beam was all it failed the mot on even though it has been sat since 2007 doing nothing :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Thu Nov 05, 2009 9:00 pm
Put my ride in for an MOT today and apart from the fan belt snapping during the test she passed!!!!
:D :D HAPPY DAYS :D :D
PixelMonkey
Vehicle Name: Mini Monsta!
Modifications: Debadged
Mud Guards Removed
Spare Wheel Carrier Removed
Rear Seat Removed
Rear Bumpers Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Black Suede Headlining
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
Red L.E.D. Dash Conversion
Blue L.E.D. Interior Lights
+2" Coils
+2" ES9000 Pro Comp Shocks
2" Body Lift
Much much more to come.
