Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Fri Oct 23, 2009 4:17 pm
Well today I fitted some extended front Arb drop links, were going to be disconnects, but got impatient and welded them :lol: replaced split cv boot, tightened bearings, cleaned and replaced manual hubs. Just need to fit my spring retainers and she is ready for the weekend :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Fri Oct 23, 2009 4:48 pm
actually got rround to changing oil & filter on me 2.8 trooper
and charged battery up on sports as it dont get used as much :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Fri Oct 23, 2009 4:57 pm
i ran out of fuel :oops: just up the road from home and rolled it down the hill to the house
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Fri Oct 23, 2009 7:25 pm
:P
Doh.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Fri Oct 23, 2009 7:38 pm
yep always wonderd what the fuel pump icon was for :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Mon Oct 26, 2009 8:25 pm
Popped out this morning to fit the new top and bottom ball joints, along with new CV boots.
Took well over 4 hours to get the first side done, so the other side has to wait until tomorrow.
Nothing wanted to come undone and as per what seems to be usual, the bottom ball joint was a right pig to split.
Still, half way there :dance: :dance: :dance:
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Tue Oct 27, 2009 9:18 pm
done my tapets, was going to use the rule of 9, but just caught them on the rock, a lot easyer,
removed bash plates, and found my oil leak was coming from the oil presure switch,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Tue Oct 27, 2009 10:22 pm
washed the truck and found more holes than bodywork :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6Jon on Wed Oct 28, 2009 11:09 am
Yesterday I treated my truck to a pair of new pair of Good Year Wranglers on the front, and got the slow puncture fixed in the rear.
Took the fitters nearly an hour to get one of the front alloys off as it has corroded to the hub so badly :shock:
Mind you from the MOT history it has ony done 16K miles in the last three years and as there was no repairs to the old tyre that came off, I presume the wheel hasn't been off in over three years !
Just dragged my eldest out in the drizzle to help bleed the clutch, as it was juddering like mad when pulling away, and after much swearing and bleeding, I can't get the bash plate under the bellhousing off to blead it all the way through :evil:
Stiil, it is bled halfway, the fluid that came out was black with lumps in :shock: and the clutch is much better.
I think a few days of squirting with WD40, and another go at the weekend should finish the job.
V6Jon
Registration Year: 2002/52
Vehicle Name: George
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul4be on Wed Oct 28, 2009 3:23 pm
Got both ball joints and the CV boot on the second side changed today.
Bottom ball joint split straight away this time - result.
I did waste nearly an hour with the track rod end though. Nut was very stiff on the threads and before I had got it off, the joint seperated from the hub meaning that the ball joint turned when I tried to turn the nut.
Tried everything to get it back onto the taper tight enough to move it, got there in the end.
Another job off the list!!!
paul4be
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Wed Oct 28, 2009 3:29 pm
well considered taking the fronty off the road for a while while all the works done on it. just got to fix the other car first
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Oct 28, 2009 5:10 pm
Replaced the sump gasket...what a bugger to do with the engine still in the truck.....Why don't I ever think that a job would be easier if I took the engine out, until I've had a fight with it and finished?
One slight concern was that ammount of carbon deposits in the bottom of the sump (deffo not metal) and there seems to be a "whistling" sound coming from the oil pump or pick-up now...but pressure is good. (any thoughts?)
hopefully there won't be a puddle of oil out the front tomorrow morning
next job.....front discs and pads........but that will wait until the weekend (maybe)
My truck was put to work today (what it was bought for)and towed my poorly other car on trailer to Northampton Motorsport. Been putting this off for months as the Fronty hadn't been boosting on the turbo and was flat as a fart. Last time i towed with it just over a year ago, it was nothing but grief. Today pulled like a train, not once did the EML light come on. Even overtook at (legal!!)full chat going uphill on the A605. Sorted!! :dance:
wilko the vanman
Vehicle Name: Randy the Ranger
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Oct 30, 2009 7:00 pm
well put the engine back together, and she is purring like a pussy cat,
done a water flush, and new anti freeze and clean water, oil change tomorrow with oil filter, then set about changing the other oils,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spike on Sat Oct 31, 2009 3:43 pm
Took the alloys off my Black frontera, and put them on my Silver one...Had to strip off the front disk from the Black one and put it on the Silver one, as the wheel studs had sheared.. (ordered replacement studs and a bumper from Tom, so hopefully will get these sent up next week).
Thought as both were 2001 reg SWB's 2.2i's the wheels would have been same size, but the Silver one had Steels which are 15" , and the Black had Alloys which are 16"..
Silver one looking good now, so should be able to get it through its MOT next week now....
Next job is to acquire an engine for the Black one...and fit the bumper that Tom is sending up, then 2 of them should be road worthy....
PS could be looking for a set of Alloys to put back on Black one, as it doesn't look good with the Steels.... :drink:
Spike
Modifications: 2" + Landrover Springs on rear.. 2" lift on Front.
235/75 x 15" Recip Tyres all round 80% mud, 20% Road
Light bar on roof, 4 front facing spots, Wired to come on via full beam via switch 2 rear facing wired through reversing lights, via a switch.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sat Oct 31, 2009 7:04 pm
Hooked up the trailer with my mates offroad bike in it and went lanning with him :) :)
Found a lane near Haldon called "five lanes" (they call it that because five lanes all meet here :oh yer: :roll: ).
"Note to self" dont do it again with a trailer(spent most of the time trying to bounce into the hedge or threw the back window)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Lipton on Sat Oct 31, 2009 7:15 pm
I was a good boy today, I changed the serpentine belt as well as the oil and filter. Thought I had better as it has done 124824 miles and I do not know when the belt was last changed (if at all :shock: ).
Now once the little sods, sorry the little darlings, have stopped knocking on the door begging for sweets I'll have a few :drink:
1998 TransGlobe 2.5 TDS LWB
I started out with nothin' and still got most of it left
Lipton
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat Oct 31, 2009 7:20 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sat Oct 31, 2009 8:29 pm
Gave someone in government an extra £104.50 for a duck pond........got back in truck and no start...twiddled sensor in air intake pipe, turned key and away we went. cleaned said sensor with carb cleaner and a little sealant around pipe, tested and starts...no eml lights. bizzare never done it before, maybe the truck was disgruntled about the road tax as well (was a bit dirty mind...hopefully it'll be ok)
swore a lot about being made to spend so much for road tax,,,,,,,for what I ask you....!!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Oct 31, 2009 10:06 pm
A set of new glow plugs and the rear has been raised another inch to 4" 8)
A great day as usual at the weird person they call Andysd1.
Furball had an interesting afternoon too :lol: :lol:
Users browsing this forum: Google [Bot] and 100 guests
