Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Oct 18, 2009 11:59 pm
Been a day for moving cars then Ian - Lara made her journey into the Garden of England, so as to stop me getting grief for having 2 Fronties parked down here.
Glad you managed to find a solution for the council's petty thinking mate. I wanna see Angelina in teh flesh at our play site :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Oct 19, 2009 12:23 am
done nothing, had a lazy day
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Mon Oct 19, 2009 9:02 am
Oh yeah... Not strictly my car related, but had my first go with Oxy-Acetylene (or was it Oxy-Propane??) whilst sorting out and tidying up.
Fun, in a vaguely scary way, hehe
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Mon Oct 19, 2009 9:05 am
Changed my number plate bulb.
Fitted my strop box in the boot.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Stuart69 on Mon Oct 19, 2009 2:57 pm
Adjusted my torsion bars a little over an inch for now, probably go a little more once i fit the coil spacers on the rear. ( that was a great tip about jacking up the front, makes it much easier to turn the nuts :) )
Before...
After :D ....
Stuart69
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Mon Oct 19, 2009 5:31 pm
Are the tyres clearing the arch now on lock??
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Stuart69 on Mon Oct 19, 2009 5:49 pm
Stuart69
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Mon Oct 19, 2009 10:38 pm
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kingfisher on Tue Oct 20, 2009 12:23 am
changed oil ,filter . new air filter . petrol filter .spark plugs , general tidy up ,i'e wash and wax . :)
kingfisher
Vehicle Name: The money pit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Oct 20, 2009 9:28 am
More brake stuff yesterday, the bias valve got some attention but beginning to wish I hadn't started
Problem 1: brake pipes didn't want to come off, now gonna have to make new ones to go back to the master cylinder
Problem 2: bias valve rusted onto the mounting studs and despite using hammers of various sizes it aint coming off. Eventually drilled out the studs and it is now stripped ready for cleaning and reassembly
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Tue Oct 20, 2009 10:46 am
Hound Dogs Tractor
Hound Dog
Missing In Action
Missing In Action
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Tue Oct 20, 2009 11:43 am
started to wire my cb and aux powerpoints in
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kris63 on Tue Oct 20, 2009 12:29 pm
had new spare tyre fitted as when i got the mistress the spare was smaller than those on the car, have received my roof mounted brake light and fuel filter ready for when it is serviced. started to polish scratches out of the car.
kris63
Vehicle Name: The Mistress
Modifications: bigger tyres, 235/85/16
uprated bulbs in spots to 100w
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Tue Oct 20, 2009 9:53 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Stuart69 on Tue Oct 20, 2009 10:29 pm
Yeah Jason, it was easy after I had a read at some of the posts on here :)
I had sprayed the adjusters with WD40 for a few days before I moved them. Measured the height and near side was at 33", offside at 32". I turned both adjusters clock-wise and raised both sides to 34". A great tip from here was to jack up the front end, takes tension off and makes the nuts much easier to turn.
(the nuts 27mm)
Hope that helps,
Stuart.
Stuart69
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Wed Oct 21, 2009 10:11 am
Got the tape measure out on Holly this morning, as I noticed a slight feeling of claustrophobia in some of the multi-storey carparks in town. There's only one she cannae fit in currently, although the roofrack just clips the height boards on a couple. Tops out at 6'4" at the moment
Thinking if I stick 33's on, I'll need a height gauge like in my truck, hehe :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Wed Oct 21, 2009 12:33 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tez1963 on Wed Oct 21, 2009 12:39 pm
just a quick oil and filter change on the truck and while i was under it give it the quick once over checking everything was ok after pay and play last week... and everything was ok, :dance: :dance:
tez1963
Modifications: none
in between trucks
at moment !
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by headbanging on Wed Oct 21, 2009 1:14 pm
Ripped out the alternator!! Not the easiest of jobs in the world, as I could only get in from the top.
Just waiting for Mr Courier to bring my new one, and then have to fit that. Need to get it all done by 6pm as eldest has rugby training.
headbanging
wound up torsion bars (2")
flipped top ball joints,
roof light pod
blue-tooth CD player
modified side repeaters
smoked tail lights
uprated turbo hoses
Skype Username: BadgesPatches
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Wed Oct 21, 2009 1:44 pm
Other than delivering logs and taking it past 140000 miles, nothing. :D
Users browsing this forum: Google [Bot] and 58 guests
