Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Oct 12, 2009 10:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Mon Oct 12, 2009 11:11 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by foggy on Tue Oct 13, 2009 12:26 am
Fitted stainless A bar and, chisled off all the nobbly bits on the boot lip and covered with ali tread plate, fitted DVD player and TV tuner, changed bulbs for some brighter ones all whilst my buddy tinted the windows for me :dance:
foggy
Vehicle Name: The Punisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by leee7196 on Tue Oct 13, 2009 11:47 pm
i wired up my new cb radio also fitted the new silencer and rear pipe.jobs a good un' :lol:
leee7196
Vehicle Name: Jerry or Jeri
Modifications: 2" Body Lift....Plasma Pucks.
2" Suspension Lift.
+2" ES9000's Shocks.
FOG windscreen url front rear and side windows.
Snorkel.
Blue LED Dash Conversion.
Extended Nudge Bars.
6 spotLight roof bar.
32x11.50x15 Cooper Discovery SST Tyres.
Side Steps Removed.
Midland 78+ CB Radio.
Planned... Rock sliders OR Side steps.
New leaf springs.
Rear and side window tint.
Black Interior headlining,handles & sunvisors.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Wed Oct 14, 2009 12:54 am
Well, didn't actually make anything or fit anythng useful, though, what I actually did was get it stuck. A few of us were out night laning toninght, on a particular lane the track splits, one way its flat-ish field the other way it's long grass and undulating terrain. So for a change I led everyone along the undulating terrain (never driven this bit before) when all of a sudden the undulation went extreme and I disappeared down a hole (deep enough I had to climb out the window). There I was sat on the rear diff and front cross member and only the near side wheels contacting the ground. All this and leaning over at a bit odd an angle.
The shame of it was having to be winched out by a Range Rover, a consulation prize was that only 2 LR 90's with ARB lockers and 35 inch simex pattern tyres went through. The Disco's and LR110 bottled out.
I think with an extra inch of lift, 33inch tyres and no anti roll bars and the Fronty would have made it.
First time I ever got stuck in it, had to rescue a few green ovals in it when the going gets slippery on occasion.
Gave the Landy Lemmings something to chirp about when we got to the pub.
Regards
Stuart :oops:
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by headbanging on Wed Oct 14, 2009 7:58 am
Bleed the clutch, as it started playing up on the way home sunday.
Feels like i'm driving a new car now!
headbanging
wound up torsion bars (2")
flipped top ball joints,
roof light pod
blue-tooth CD player
modified side repeaters
smoked tail lights
uprated turbo hoses
Skype Username: BadgesPatches
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6Jon on Wed Oct 14, 2009 12:18 pm
Stopped the truck from bleeding !
Wynn's engine flush, drained oil, removed the filter, and then cleaned the milimeter of crud off the metal face the filter seals against.
Followed this up with new oil and a genuine Vx filter, and jobs a good un !
No more complaints about the pubble on the drive :D
V6Jon
Registration Year: 2002/52
Vehicle Name: George
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Wed Oct 14, 2009 5:28 pm
Investigated the overheating problem on Tessie,
Took out the radiator to find it full of mud :lol: :lol: jet washed it and fitted it back in.
Did the same to the intercooler rad.
No more over heating :dance: :dance:
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Wed Oct 14, 2009 7:37 pm
Repaired the front fog lamps once again after going in deep water lots of silicon round them so they don't fill up again. :D
But then i notice the under bell has gone :x
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Wed Oct 14, 2009 7:47 pm
not so much on the truck but for the truck
i fitted a pressure regulator and valve to my compressor and set it at 87psi max
as compressor runs at 140psi max & i dont want to blow the air tools the max safety pressure is 97psi :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Oct 14, 2009 10:01 pm
well this weekend will be fun,
planned is
new front pads on simo_d truck,
new shocks on the front of furballs truck
new discs and pads all round on mine, plus one caliper (cheers tom)
new springs and 3" spaces, (cheers alex)
extension of the brake bias thing,
Axel breathers extended
new rear shocks if they arrive,
air mod
EGR removal
some rust treatment,
some painting,(hahaha)
install CB,
and a bloody good clean,(it sticks to high heaven of smelly dog)
new wheels and tyres end of the month,(may be next month)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Wed Oct 14, 2009 10:25 pm
Andy,
Might as well remove the cat, chop the birds nest, flip the bj's and have it all done.......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Oct 14, 2009 11:23 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Oct 15, 2009 12:37 am
I washed mine yesterday :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Oct 15, 2009 12:50 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Oct 15, 2009 12:51 am
Made some braided brake hoses for the rear axle and fitted them along with some nice new copper pipes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6Jon on Thu Oct 15, 2009 11:12 am
Finally this morning (after nearly a month) I managed to complete the process of exporting my truck from the UK and re-registering it in Guernsey :dance:
Having done that, I have ordered the new plates which will be ready tomorrow and at the weekend I can get rid of those hideous black on white/yellow things with letters on that you people insist on using !
Then I can fit some nice silver on black letter-free plates :D
V6Jon
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Thu Oct 15, 2009 6:22 pm
finally got around to straightening the nudge bar and re-fitting the checker plate to the side step......all damaged whilst on the weekender in Wales back in august-ish
found and solved "new" rattle....exhaust bracket on cross-member worked loose....free fix...loberly jubblie
also fitted a pair of spots, that were donated by a neighbour (yet to wire them up, so they are merely decrotive for now)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Oct 15, 2009 6:47 pm
Finished of air horns and fix electrical faults changed front bulbs to more powerful ones so have more light.
now time for a :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Fri Oct 16, 2009 1:25 am
Frenchfarmer
It works!!!!
