Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Oct 02, 2009 1:16 am
going to need a bit more than t-cut, haha, just aswell its geting a respay
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Oct 02, 2009 3:47 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Oct 02, 2009 4:46 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Fri Oct 02, 2009 8:25 pm
MOT tomorrow :shock: :shock: :shock:
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Oct 02, 2009 8:27 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Oct 02, 2009 8:33 pm
Good luck Chris, sure it will be fine 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Oct 02, 2009 8:36 pm
Well this was'nt on me truck but me car i bought for work.
I thought i would be good today and buy it some new wiper blades, so into Halfrauds i went and spent £23 on 3 new blades. I put the one on the back first great, then the drivers one jobs a goodun i thought. Come to the pasenger one and it was a pig to release so i gave it a bit of extra force it slipped wiper blade came off and the arm promptley hit the windscreen and cracked it. So thats gona cost me all together £83 for a new set of wipers.
Moral of the story is:- IF IT AINT BROKE DONT FIX IT!!!!!!!!! :cry: :cry: :cry: :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Oct 02, 2009 8:45 pm
:oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Fri Oct 02, 2009 9:10 pm
well today i fitted a set of 31" A/T's on toyota rims they do look nice need a good clean though and the offset is a lot more than the fronty alloys changed the fuel filter and had new enging belts and oil filter delivered oh and a body lift from milners. got waxol and hammerite all ready for repairing the floor in the truck
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Oct 02, 2009 9:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Fri Oct 02, 2009 10:26 pm
well, i did as advised, fitted new turbo, drained old sludge (i mean oil)(perhaps 3 years is a bit long an interval between oil changes) :oops: , new oil filter, primed turbo, filled engine with flushing oil, started her up and after a big cloud of smoke, she sounded beautiful on tickover.
after 5 mins on tickover the engine temp hadnt moved from cold so i gave her a bit of revs, not too much, just 1500 so as not to spool the turbo. all of a sudden she stasrted revving her t1ts off uncontrollably and even when i took the key out, she kept going, screaming and belowwing smoke out her bum. the only way to kill her was to put her in gear an stall her, (unfortunately she jumped forward and hit my mates car, no damage though)
After ringing Alex in a blind panic it was found after disconnecting inlet manifold hose and turbo outlet hose that the old turbo, when it failed had dumped about half a ltr of oil into the intercooler. Wheni built up the revvs, the oil was sucked through the intercooler into the air inlet manifold where it mixed with the air and of cause, the engine thought, happy days, loads of fuel and air to guzzle rendering the throttle useless.
So, it was off with the intercooler and all pipes (what a bugger that is to remove), clean it out with diesel and drain and dry. Changed oil again for some nice 10w/40 semi synth, another new filter. Put the intercooler and pipes back on, started her up and hey presto, she lives again.
Thanks very much for the advice Alex and Drift, without it i think i could have permanently killed her
ANGELINA LIVES AGAIN :dance: :dance: :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Fri Oct 02, 2009 11:35 pm
Looked at it and thought. " Once I get the third Transit mobile I'll be able to get the Fronty back on the road." Big sigh. And went to feed the Lambs. Then sorted the front porch light out and looked at my poor sad Fronty sitting there on its axle stands waiting for it's trooper flywheel etc. and then had another big sigh. Then went and did water runs to the other 400 sheep and gave them more hay that we really need for winter but guess what....... it's a drought in central france.......umbrella salesmen are topping themselves by the dozen. Popped the cork on a bottle of good red and sat in the Fronty listening to the hi-fi while the sun went down.
Then I peed on the back wheel so she knows shes still with us.
Sigh.
Not the best of days.
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Oct 03, 2009 12:15 am
Sounds like a sad car day, but sheep fed, sun shining, tomorrow is another day, squeak of a cork sitting out on a warm evening wine glugging into a glass 8)
Want to swap :lol:
I know the winter blues start in the spring for a farmer
But, to your health and sanity :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Oct 03, 2009 5:16 am
the son took my trooper for mot and i thought it might have something wrong or an advisory :twisted:
but it went straight through so got a years use out of it :D
the wifes friend has had her motor nicked so i might lend her the sports till she gets another motor by the end of next week :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Oct 03, 2009 1:46 pm
Today my rear axle fell off :shock:
Well okay I had a big ommer and had undone everything. So in the week its LSD time :dance: Thats if I can put the handbrake bits back together after... so many bits... my clumsy fingers, ah well who needs handbrake?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Oct 03, 2009 3:16 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Oct 03, 2009 3:20 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Oct 03, 2009 3:24 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sat Oct 03, 2009 5:28 pm
MOT and tax done, all nice and legal for another year (Thanks to AndySD1... and his nephew :wink: )
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Oct 03, 2009 5:58 pm
Well, today I realised the biggest downside to owning a LWB again, specifically one that's been lifted so much as Holly...
I washed her, AAAARRGHHHH... etc... I'd forgotten just how much extra there is to wash and polish on a LWB. Side note though, I've decided that the roofrack's coming off when I get my holidays, for a sand off and repaint, and so I can clean the roof properly, and give it several coats of wax...
Still, worthwhile effort, cos she's all shiny and lovely looking now :D :D
