Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Thu Sep 17, 2009 10:59 pm
Took the old gal for mot, flew through, no advisories :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Thu Sep 17, 2009 11:24 pm
Great news that Jim, always a good feeling when that happens :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Thu Sep 17, 2009 11:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spike on Thu Sep 17, 2009 11:36 pm
I picked up Frontera No 2 tonight (Y reg 2.2i RS Sport) , stuck her on the back of a Transit and trailer...
brought her near home so I can strip the engine out and put it in mine, so I can get up and running...Hope everything goes to plan..
Will try and take pics as I go along.. Hopefully then I will strip down the donor car for spares... :drink:
Spike
Modifications: 2" + Landrover Springs on rear.. 2" lift on Front.
235/75 x 15" Recip Tyres all round 80% mud, 20% Road
Light bar on roof, 4 front facing spots, Wired to come on via full beam via switch 2 rear facing wired through reversing lights, via a switch.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Thu Sep 17, 2009 11:59 pm
Got your work cut out there mate, hope it all goes well for you :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by leee7196 on Sat Sep 19, 2009 1:16 am
last night i started to clean and polish the new alloys,finished the job at 1am.
they do look better for it
leee7196
Vehicle Name: Jerry or Jeri
Modifications: 2" Body Lift....Plasma Pucks.
2" Suspension Lift.
+2" ES9000's Shocks.
FOG windscreen url front rear and side windows.
Snorkel.
Blue LED Dash Conversion.
Extended Nudge Bars.
6 spotLight roof bar.
32x11.50x15 Cooper Discovery SST Tyres.
Side Steps Removed.
Midland 78+ CB Radio.
Planned... Rock sliders OR Side steps.
New leaf springs.
Rear and side window tint.
Black Interior headlining,handles & sunvisors.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sat Sep 19, 2009 8:56 am
last night picked ria up from band practice and had all her friends looking at the frontera then she said i'm going to be driving that soon :shock: so i brought it to work today for a bit play so strol on 6pm then play on the way home.tommorrow i shall be mostly using the LWB :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Sep 19, 2009 8:13 pm
I just picked a fight with the top control arm and nearly lost... Damn theyre tighter than Drifty :butt:
In the end Ive done complete bearing swap front pas, clean and re-grease drivers front, then added 3mm shims to the control arms.
I ended up with 2x12"extension bars with a 22mm socket on to a T breaker bar which had a 4ft scaffold pipe on each end. The Mrs helped and it took some breaking, then needed the 4ft bars all the way on one bolt to undo and tighten. Ive been wd40'ing for over a month, didnt believe it could be that tight. Even had to call the Bernie monster for a pep talk half way through when I was out of ideas. Ta old un, amazing the difference a moment to think makes.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Sep 19, 2009 8:23 pm
Ta mate :shock: :lol:
Bernie was here when you rang, you set off some funny memories from when we did mine, both hanging on the bar then the nut cracked and we ended up in a heap on the floor thinking we sheared the nut. :sick: but we hadnt. :D
Well today I checked my rear diff oil as the seal has a very slight leak, been meaning to do it for ages and was pretty sure it would need topping up but took the filler out and oil flowed out so alls good there, Ill live with the tiny leak a bit longer as I have plans for the axle 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alchamist on Sat Sep 19, 2009 8:30 pm
Strange you should say that Ste ... I finally got round to mine today. I must have caught it on one of the offroad days, and it slightly bent the bottom of the plate, causing a slight leak. I thought from the mess around the diff that I had lost most of the oil, but strangely enough it was still mostly full.
Drained the diff, cracked the rear plate, refitted with hematite and tightened back up. Hopefully that will sort it. :lol:
Even better ... very very little metal in the old oil ... hopefully the diff will last a bit longer!
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Sep 19, 2009 8:35 pm
I think thats how I did my leak :lol:
I wonder if a piece of flat metal welded flush to the bottom of the diff housing then curved/turned up around the diff pan could protect the lip on the diff pan?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Sep 19, 2009 8:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alchamist on Sat Sep 19, 2009 8:37 pm
It certainly needs something ... the diff plate is an easy target, being the bit that's likely to get scraped ...
Where are the fabricators!? :lol:
Jay
Alchamist
Modifications: .
* CB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Sep 19, 2009 8:42 pm
Ideas, good ideas, its a weak point. Fortunately not on the Trooper diffs. Good job as mines weeping now :roll: might push me to the diff swap.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Sep 19, 2009 8:44 pm
A bit crappy but you get the idea. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Sep 19, 2009 8:48 pm
they are on ebay, but they are for the lr's, and they are round, could give a few ideas, but i did see them some where,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Sep 19, 2009 8:50 pm
Looked into that a long while ago, they wont fit as the diff is a complete different shape, they bolt on using a tension method.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Sep 19, 2009 8:58 pm
got some metal there will have a look, hold on, you have it, DOH, will locate some more
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Sep 19, 2009 9:01 pm
:lol: :lol: , to be honest I think you need something thicker.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Sep 19, 2009 9:05 pm
might be easyer just to shave the bottom of the diff plate, just so it sits just slightly higher than the diff bottom
