Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Mar 14, 2018 5:49 pm
worked out i may need a new engine :evil:
but this means i can now play with the engine :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Furryroo on Wed Mar 14, 2018 11:07 pm
Furryroo
Vehicle Name: Tonka
Modifications: Standard
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ding on Thu Mar 15, 2018 7:59 pm
Refitted the clutch master cylinder after a rebuild, went to bleed it, snapped the bleed nipple flush to the thingy half way down ffs Dont know what it's called to find another :lol:
ding
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Mar 16, 2018 9:07 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Fri Mar 16, 2018 7:40 pm
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Mar 16, 2018 8:11 pm
I may have something in the pipeline...
I did look at supershargjng it too, but found when that is done the engin has problems with getting too hot
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Mar 17, 2018 10:27 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Fri Apr 13, 2018 9:26 pm
just picked my fronty up from local mechanic,been off the road now for over month missed out on all that lovely snow to play in ,but hope its all sorted now .Had new power steering pipes (many thanks to Greg),new brake pipes throughout ,fuel filter ,oil and filter and auto gearbox oil changed .Drives like a dream now ,So happy siting here beaming from ear to ear lol
aredee
Vehicle Name: Bubbles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by chrisgg90 on Sun Apr 22, 2018 12:08 am
Stripped and cleaned both front brake caliper lifted the front 2 inch with torsion bar, lifted rear with new shocks and springs. Removed the rear bumper reinforcement cross member so I can attempt to try and repair/fabricate one during the week. Still got top/bottom ball joints to do during the week when they arrive.
chrisgg90
Vehicle Name: The Snowman
Modifications: None yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue May 15, 2018 10:17 pm
well this last weekend i started to stip the engine down to get to the oil pump
removing the crank sharft pully bolt was interesting :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun May 20, 2018 8:51 pm
and today i have got all the bits off so i can remove the oil pump...
it is a mission to get this far
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Mon May 21, 2018 9:14 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon May 21, 2018 10:15 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Sun Jul 22, 2018 5:31 pm
Stsrted her for the first time since.............. Feb!!
She started first time never fails to amaze me need gonna get ready for a mot
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronterror on Sun Nov 18, 2018 7:03 pm
Yesterday i changed the outer cv joint and today did track rods both sides and front shocks was going to do the rear as well but the top bolts look like they have rusted into 1 peice so need to know the size to get replcement bolts first
Fronterror
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by reynard on Mon Dec 10, 2018 10:22 pm
Not quite today but the last few weeks......
Underseal job
Re-painted anything underneath that wasn't undersealed
Re-painted all calipers
Re-painted side step bars
Repaired & re-painted the bit of corrosion rear sills
Re-painted things like the radiator locking clips, battery tray, battery strap etc
Cut out the rust from the A bar / number plate bracket, welded in new missing sections, painted and re-fitted
Oil & filter change (Valvoline Synpower Fully Syn)
Then did a job I've been meaning to do for a couple of years..... Krylon Fusion the hard top in matt black
Then a job I've been meaning to do for a year at least.... full polish
Ready for winter now. It's a 2.2 dti RS Sport, '03 with 82k on the clock. Only ever used during winter now and owned this one for 10 years, previous to that a 2.8 tdi SWB for the previous 8 years.
Both me and the wife love the truck, it's running a chip express performance box which makes it a different vehicle, difficult to stall, responsive and good on fuel.
With what I've done in the last 2 years, leak of pipe, vacuum pipes, fixed the diesel leak in the flow/return pipes, a wheel sensor, new exhaust, I think I'll put a bit more into it next year, do some work on the rear bumper reinforcement bar and replace the brake disk shields.
It runs superb, leather interior with heated seats. What more do you want from a 4x4. Cost me £4500 10 years ago with 32k on the clock so besides the time painting and cleaning it hasn't cost me a great deal over and above what I've done in the last couple of years. I think 2 front wheel bearings and a second sensor.
Shame they still don't make them as they are still one of the best looking 4x4's on the road and I'd buy another in a shot. For me, plenty of space in the sport even with the seats folded forward. Just the right size vehicle.
I'll try and post a couple of pics.
I'd like a new set of BFG AT KO2's and to have the wheels coated, maybe black or graphite, but if I do the extra work next year, them maybe I will.
Off for an early MOT tomorrow.
reynard
Modifications: Chip Express Performance Tuning Box
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by reynard on Sat Dec 15, 2018 11:05 pm
Well.... passed the MOT the other day and yesterday I got to drive the truck, first time since last March. It's off the road over spring/summer and I've been a bit busy getting everything done on this one and another I've been working on amongst everything else.
Anyway, the Mrs always sees to have it as she does the lesser mileage but from now on it's mine as often as I can and yesterday was a pleasure. It drives just like I bought it 10 years ago with 32k on the clock and it still looks as good. The steering is tight and everything works as it should, the heater is superb and the heated seats are not long up and running. I did spend last Sunday giving it full polish and the attached pics are from 5 days later so not quite clean after it's been used all week albeit in the dry.
I even had time to clean inside the hood and engine bay with some diy detailer. Looking forward to the rest of winter :lol:
reynard
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frompel on Fri Feb 08, 2019 1:52 pm
Hello and winter greetings from Finland
My second post in this forum :D
Actually this is not did today. I've been doing this for a little while, and finally now, it's ready.
Snow pusher
And here it´s in work. https://youtu.be/Rz26JVOJcBE
Frompel
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Derv23 on Sun Feb 17, 2019 12:47 pm
Attempting to change the outer cv boots....what a mare.
I've not had it long so I'm discovering the curses of the previous owners :roll:
First off the circlip and shim were freely floating in the hub. Then the hub nut was mega tight. , had to whack it with a punch to get moving. Then I've gone and ripped the rubbers on the upper and lower balljoints attempting to seperate them. Breaking a pooey 3 leg puller in the process.
It's all in pieces awaiting new parts...and I've the same to do on the other side. Think it'll be off the road a while as MOT is up tomorrow :lol:
Wish me luck ...
Derv23
Modifications: 3" lift. Stainless exhaust.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Mon Feb 25, 2019 8:50 pm
MOT failed with Greenstripe!
Exhaust manifold leaking. A braking system line bursted while the test was in progress :oops:
:shock:
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
