Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Tue Jul 18, 2017 8:42 am
Bloody hell Frank - what another one (in Radio 1 East Anglian accent if you've ever heard it).
Do you think it was an off roading incident whereby something got caught up in there.
Be nice if I could get the son-in-law to swing it so that you could utilise his £20 annual fee to use either the 4 or 2 post in that members workshop just down the road from you (without saying the name, you know where I mean).
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by red5 on Tue Jul 25, 2017 4:44 pm
Today I shinned myself walking around one 2.8 lwb to get to the other 2.8 lwb.
Never thought I'd say this - I have too many Fronteras*
* Yes, I know you can't really but they're big and my drive has two and a caravan.
red5
Some dentage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by boraciner on Sat Jul 29, 2017 11:09 am
Today, I solved the speedo rev problem of my father's frontera :)
the solution is in that link viewtopic.php?f=32&t=61006
boraciner
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Sat Jul 29, 2017 2:07 pm
Today I replaced;
Both anti roll bar drop links
Rear D-bushes
O/S top & bottom ball joints
and I'm now having a sit down!
2000 Vauxhall Frontera 2.2 DTI Limited LWB
Ricko
Modifications: Completely original!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jul 29, 2017 8:43 pm
To the truck? Not a lot, yet.... But I did make a wee 250 mile round trip in the spare truck to get a 3.1 engine and the engine swap begins tomorrow, rain permitting.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Mon Jul 31, 2017 1:01 pm
MOT passed!
I'm over the moon.
(Advisory on drive shaft gaiters, job for another day)
Celebrating by spraying the sills!
Ricko
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Tue Aug 01, 2017 6:57 pm
Converted my 12n/12s towing electrics to the Euro 13 pin socket and also fitted an extended tow ball.
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Panzerwomble on Wed Aug 23, 2017 9:04 am
Replace the sagging and frankly quite disgusting headliner . Thanks to Rifleman's "how to "guide , made it a lot more straightforward than having to work out what needed removing to achieve this . Comes out and and goes back in just like the gent says :D
Didn't help though that a previous owner had used builders foam through the light fittings to try to glue the liner to the roof ....!!!######!!!
Word of advice though , the liner needs a lot of care when removing as it is quite flimsy and could easily snap, I did its single handed but two would have been easier .
Now have a cream liner instead of the original grey ,which is a lot brighter inside all for 13 quids worth of leatherette and a can of spray adhesive . :dance:
Panzerwomble
Vehicle Name: Frontosaurus
Modifications: Debadged, repainted Bundeswehr Green, 3" lift, numberplate relocated to back door, Shogun wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Tue Sep 05, 2017 12:28 am
Drove it from Conisbrough Doncaster back to Scotland up the A1 (M) after being on holiday with the caravan.
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Thu Sep 07, 2017 6:36 pm
Put a railway sleeper through the windscreen :oops: :oops:
Have now bought a trailer lesson learnt
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Panzerwomble on Thu Sep 28, 2017 10:45 am
Replaced all the hardened PVC fuel line from pump to tank , noticing along the way that they had been accidentally swapped over at some point , so the return was going in the feed . Seems to have made no difference to the running . Cold starts are still difficult, new glow plugs on the way .
Panzerwomble
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dooley on Mon Oct 09, 2017 10:33 am
I blanked off the EGR valve as my fronty was going sluggish, blowing black smoke ect. Blanked EGR off and she's sweet as a nut.
Dooley
Model: 2.5 TDS Sport 3dr
Vehicle Name: Beast
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Oct 14, 2017 7:50 am
put the duck in for mot...
only failed on 12 points and 4 were the head lights..
not too bad for sitting for over 6 months mot moving
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Oct 21, 2017 12:11 pm
yesterday i recieved the parts needed for the mot, so started on them last night....
forgot how errm fun the ball joints are to change.... but only now down to 4 things left to do, just waiting for the weather to settle down
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Thu Oct 26, 2017 5:15 pm
Ran the truck in for MOT, as I'd forgotten it expired 13 days ago :oops:
And it sailed through, with just a few advisories :dance:
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Thu Oct 26, 2017 8:30 pm
Went out in it loaded with tools to carry on installing some gates in the middle of Canterbury.
This is only possible because much to my astonishment and delight it only needed the silencer and tailpipe renewing to pass its mot.
My mechanic said " it lives to fight another day".
Really pleased to have it hopefully for another year on the road.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FronteraBob on Fri Nov 03, 2017 8:23 pm
Fitted heated leather seats all for the sum of £40 very happy camper :D
When words become violence, what could be better than silence.....
FronteraBob
Vehicle Name: Red Devil !
Modifications: Zero....
Skype Username: Saxwood
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Liam66 on Wed Nov 22, 2017 10:09 pm
Fitted a 20" light bar and had a new set of tyres fitted.
Liam66
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Wed Jan 17, 2018 6:10 pm
Killed it!!! :cry: :cry: :cry:
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Wed Jan 17, 2018 9:09 pm
What happened?
jmc
Users browsing this forum: Google [Bot] and 15 guests
