Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Apr 03, 2017 4:46 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Mon Apr 03, 2017 6:56 pm
The sparewheel cover on the Mrs' truck has rotted away - only seven years old...
Replaced it today and fitted reflective adhesives as before for more security and did a little paintwork with PlastDip.
This is a logo of our favourite red vine from Sardinia: Cenere.
BTW The other truck has got a new crankshaft sensor.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Sent her to the breakers today.
If anyone in the northwest needs any bits she will be laying in state at Atlas Salvage .Jackson St .St Helens .
Sad day, off to drown my sorrows .....hic.
What surprised me really was the fact that after nearly a year without starting put on a good battery and she fired into life..
She did throw a wobbler though,drove to the ramps of the truck then flatly refused to rev up she didn't want to go .
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Fri Apr 14, 2017 8:48 pm
Truck...
Nothing apart from look at it with a frown as it sit's in the naughty corner of the yard awaiting the 'spanners'.... Have to admit, these things go sooooo much better when the engine oil stays in the engine and not spread all down the chassis as in this case. Twas quite happily chugging home from work a couple of weeks ago, steady 60(ish) temp where it should be, oil pressure where it should be and no abnormal rattles (ignoring the fact it's got a 3.1 lump in there and they rattle the same as the 2.8) when there was this rapidly increasing racket and the oil pressure fell through the bottom of the gauge.
Pulled over for a quick look which confirmed the need for recovery in about 2 seconds flat... 4 hours later RAC recovery rocks up having come all the way from Guildford to recover Truck about 12 miles to home....
I'll have a good look at it to see what's given up over the next couple of weeks. Hopefully nothing a good spannering won't put right.
O-No...
Replaced the cam belt and water pump this morning, thought I really should get round to it as I hadn't change either since getting it about 4 1/2 years ago. Now rapidly heading towards 110k...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Apr 15, 2017 5:53 pm
O-No
Changed the front pads. Having now found out why I needed to change the front pads Tuesday evening will be spent replacing the N/S front calliper with a new one!
Really should add callipers to the list of spares to be kept in the shed...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Apr 23, 2017 1:26 pm
i changed the rear shocks.....
and that took about 4h to do.... as i now have something a little different on the rear...
fox racing pro air shocks :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon May 15, 2017 10:17 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Tue May 23, 2017 12:45 am
Not so much today as every spare waking moment for the last 3 weeks :crazy:
completely stripped & re-welded the rear end of that rotbox that is my 2.2 Dti, including plates on the chassis, and the fabricating of new spring seats, panhard mounts & a trailing arm mount. Also in the mix were 3 seized calipers, 3 sheared slid bolts, 2 brake pipes, a new exhaust, oil and filter, and a fooking wheel that defied all normal means of removal. This was finally solved with liberal application of boiling water, swearwords and a flaggers maul :twisted:
Cheers to gregster for the speedy provision of 2 of the calipers.
MOT time tomorrow, albeit with a 'borrowed' caliper off the 2.8, while I wait for the last on to be delivered
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Tue May 23, 2017 2:48 pm
:dance: :dance: :dance: It passed :dance: :dance: :dance:
bucket full of silly advisories though
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Tue May 23, 2017 4:24 pm
Well done that man
My one is is just a bucket!!!
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronterror on Sat May 27, 2017 7:55 pm
Fixed an oil leak on rocker cover gasket next to no.4 injector not sure if it's THE leak but fingers crossed, changed gearbox and transfer box oil which was joyous fun witht the P.O.S. syphon pump tube i bought form ebay working at half a litre an hour, gave up and cut up hosepipe and used a funnel in the end to fill it in 5 minutes. Still quite stiff to get into gear so unfortunately i think a new clutch may be in order as I've already bled the system and well and truly reinforced the bulkhead by the master cylinder.
Fronterror
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Sun May 28, 2017 4:22 pm
Today I have been mainly replacing the front discs and pads.
Discs £22.50, pads £10.00, ex VAT
[RTG Automotive, Leyland]
Fairly straight forward job, though I need a new slider rubber, I'll probably get a kit next week.
I reckon it's never had discs before as the hubs looked like they'd never been off!
2000 Vauxhall Frontera 2.2 DTI Limited LWB
Ricko
Modifications: Completely original!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Tue May 30, 2017 4:54 pm
Removed o/s rear driveshaft, fitted new back plate. Waiting for brake shoes to rebuild this side.
Ricko
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Fri Jun 02, 2017 6:20 pm
Wished the 2.8 happy birthday as it clocked 170k :lol:
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Sat Jun 03, 2017 12:15 pm
Finished off the n/s rear brake rebuild.
Thank goodness.
In the last five days; front discs and pads, rear discs, pads and shoes, rear disc covers / back plates, rear wheel bearings (unavoidable as we had to heat the retaining collar to remove the half shafts)
Insured it (good old Adrian Flux)
Ricko
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Wed Jun 21, 2017 7:45 pm
Replaced drivers side passenger door with a better one as the old one had a big rust patch. Got the window going which hasn't worked for ages,then when I put it all back together it didn't work and I started have owns trouble with the others . I think it's the switches by the gearstick. Fortunately the front ones are working although drivers Side e a bit uncertain sometimes. Couldn't work out how to get them apart and didn't want to braek any plastic,which I am quite prone to.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Jul 01, 2017 1:44 pm
MOT passed for another year,only two adviseries. She does 450 miles week in week out and never misses a beat :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Panzerwomble on Thu Jul 06, 2017 3:37 pm
Snap , mine passed it's MOT as well .
In the past two weeks it's had
Oil, air diesel filters & fluids
New brakes all round including the daffy handbrake shoes
Numerous PO "extras" removed , dodgy battery draining alarm , peeling tint on the front windows , roof rack held on with cable ties etc
New track rods ends, lower ball joint
Some light sill welding
Got the windows working again
New coolant, washed 100KG of mud out of the radiator fins and then flushed it
Stripped put all the seats VAXED everything and replaced
And then repainted all of the exterior and the wheels
I'm happy with it , and having been able to drive it round for the first time , have noticed the water pump is leaking.... woot, more jobs for Monday !
Will try an post some pix when I can work out best way of doing it !
Panzerwomble
Vehicle Name: Frontosaurus
Modifications: Debadged, repainted Bundeswehr Green, 3" lift, numberplate relocated to back door, Shogun wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ricko on Sat Jul 08, 2017 12:40 pm
Fitted a new exhaust, £78 off eBay, the job went nice and smoothly
Ricko
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Jul 17, 2017 11:18 pm
Found the oil leak on Truck.
Nothing too serious, just a 30mm dia ragged hole in the sump above the axle tube! No oil in there now, but it still runs. Sort off :roll:
Guess that'll be yet another engine swap. Getting good at those now with that thing.
Users browsing this forum: Google [Bot] and 15 guests
