Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Sat Oct 08, 2016 8:07 pm
Changed the lower ball joint on the offside. What a long job I started at 11.00 stopped for lunch at 3.00 then finally finished clearing up at 7.15.
I read the excellent posts in steering on how to do it, thanks for those who wrote up. I also looked at several you tube films.
I had real trouble with getting the lower joint free from the wishbone. I tried bashing the side as shown in you tube tried a ball joint splitter also to no avail.I even resorted to oxy acetylene .I put a bit of 6 mm plate over the wishbone to protect the drive shaft boot and heated up the bit around the joint with the weight taken on the end of the ball joint taper on a jack.
As I knew it needed
a new ball joint ,I didn't mind the rubber burning. This didn't work either which astonished me as heating has never failed me before. Finally tried jacking it up on the wishbone and hit the end of the ball joint upwards and at last it came free.
Then followed ratcavs instructions on fitting the new ball joint. The new bolts were longer than the old ones and too long to fit in in the space under the driveshaft boot and I had to reuse a shorter old one in one of the holes towards the rear of the fronty.
Then when I had that done I couldn't tighten the track rod end down the nut got stuck and the whole shaft just span around . I had a good look at it and found the thread was damaged halfway down so filed it in situ with a needle file and also cut a screwdriver slot in the end of the bolt with a 1 mm cutting disc on an angle grinder and used this to hold while I tightened the nut down so got tight eventually.
Whew!
This is all in aid of an m.o.t. in a weeks time, it was gratifying to find that the old ball joint was very worn indeed.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Fri Oct 14, 2016 7:30 pm
Ran the old girl in for MOT today....and she passed :dance:
just 3 advisories
small amount of play in a drop link
chip in the screen
gearbox oil leak
Happy days
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Fri Oct 14, 2016 7:45 pm
Fitted new heater matrix by the "easier" method and now have a toasty warm motor for the winter. Well chuffed as it passed its MOT last week with no advisories. :D
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Oct 14, 2016 8:27 pm
Awesome sauce Mick
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Sun Oct 16, 2016 2:45 pm
On Thursday I changed the oil and filter in time for the mot on Friday. It passed except for one tyre , a Colway which is 31 10 15 and all the others are 275 55 15. I thought it was the same size but the tester didn't like it. I haven't got another legal one so am waiting until Monday for my garage to fit a new Kuhmo 275 55 15 and take it for a retest.
Very pleased it passed apart from that.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Fri Oct 21, 2016 9:46 pm
Found a puddle under Truck today at work and then a leak in the main hose from the rad to the bottom of the engine and the header tank. Seems it has been rubbing on the steering box with the obvious result.
Tomorrow's fun n games is going to be fixing the leak followed by changing the engine mounts (one looks like it has given up) and then some welding in the passenger footwell where a couple of cracks have appeared around the edge of the body mount re-enforcement plate. Finish off with a Pre MOT look over.
Then book in for a MoT. Should get through okay, with all things considered the Truck's in pretty good nick for a 21 year old 4x4 with close to 280k on the clocks and the life it gets!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Oct 21, 2016 10:36 pm
Wobbly wheel bearing not so wobbly anymore.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by SPEEDBIRD 202 on Sat Oct 22, 2016 11:57 am
Well I have not posted on the forum recently but I have just got the Fronty through a MOT, SSSooo I'm feeling pretty chuffed fight now :wink:
Can anybody fill me in with whats been happening on the forum in the last couple of years. I've changed me job and had the usual hasstle people get in their life - so I have not been keeping an eye on things.
I hope to visit and post more often from now on.
Over & Out for now ....
SPEEDBIRD 202
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Wed Oct 26, 2016 3:11 pm
Driving to machine shop hear what can only be described as a slapping noise then silence, battery light on voltage dropped water temperature dropping!!!!
Stopped out side motor factors got a new alternator belt after me and the Mrs had shouted and swore quite a bit changed the belt for a slightly larger one got a 1753 instead of the 1725 that the computer said we needed and now all good.
Couldn't have done it with out the Mrs help and are both quite chuffed with our selves considering we don't know the difference between one end of a spanner from the other
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Wed Oct 26, 2016 9:50 pm
Marion's sister called yesterday. One of her company's trucks has passend away. A 2006 Ford Transit dti with a big and expensive problem with the injectors.
As a coincidence, our plumber had a Opel Vivaro for sale. Gave him a Fall, an hour later the Transit was replaced.
Today it was my turn to pull off the company markings Form the Transit :lol:
Maybe it is still worth a few bucks.
Reminded me pulling off the advertising of the previous owner of Godzilla six years ago.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Fri Nov 11, 2016 6:15 pm
Not today but last Saturday had the old girl cleaned by the guy that does all the cars at my Bros work. She came up really well.
lee771
33 12.5 15s
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sun Nov 27, 2016 11:01 am
Replaced turbo and starter motor on my trooper.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronterror on Sun Nov 27, 2016 5:14 pm
Replaced instrument cluster bulbs with blue leds :D
Fronterror
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Nov 27, 2016 9:41 pm
Fixed another set of wobbly front wheel bearings on a friends Bighorn. Doing it so often I have made a tool to make it easier. Seeing as I have never really welded before I was rather chuffed that a) it held together and b) it worked a treat. Used stuff I found lying around college and an old hub bearing nut.
No more mucking around with hammers, screwdrivers and spring gauges to get it right.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Sun Nov 27, 2016 10:40 pm
Look good Neil . I used a bit of scaffolding tube and 2 bolts, and socket same as you
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Sun Dec 04, 2016 11:32 am
Did my first night time green Lane last night makes for completely different experience
lee771
33 12.5 15s
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sun Dec 04, 2016 11:45 pm
Les, this makes me jealous a bit...
Today, I took care of GodZilla's sunroof. Cleared the ice, cleaned the seals from dirt and leaves. Then I gave the rubber a little massage with kind of grease.
The installed the DEFA heater again and ran it for two hours - all dry again.
Returned yesterday from a two week trip to the coast and found the windscreen wet in the inside. As the Alfa is knocked down at the moment (no loading pressure, running slow and noisy) and will return in a week or so by ADAC support to get repaired at home I will need the Frontera after I returned the rental car.
Grünstreifen has no MOT at the moment and so I am running out of cars in a way... :axe:
Kind regards,
JEOH
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Thu Dec 08, 2016 10:53 pm
Last weekend
http://share.photobucket.com/shareprofi ... d=MzUzODY=
Spent the best part of an houreffort jet washing the remnant of Korc out of the underside today.
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Dec 09, 2016 11:10 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 09, 2016 5:38 pm
Yup .. 15/16 Imperial ;)
Made sure it wasn't one I might need for the P38 as well :D
