Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Aug 14, 2016 3:23 pm
Washed it!!!! (it did squeal a bit)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Aug 14, 2016 4:10 pm
I thought better of you greg tut tut
Went to have a look at clean SWB B Series that some bloke called Jezza had in his private collection.
Think it's a bit beyond my skill set to make it roadworthy again though so thought I'd leave it 8)
MG Autos (Mark)
Member & Trader
Registration Year: 1994/M
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Aug 14, 2016 8:51 pm
Sorted out tHe exhaust system. Thought I'd go the route of taking the paddle out of the QWS unit and put the spacer section back in rather than risk over stretching the spring. After successfully removing the paddle blanking off the shaft hole, god back under the motor for reassemble only to find that I had bought the wrong bolts. Needed 75mm rather than the 50mm the I had bought. Ended up stretching the spring season in effect wasted 3 hours flaffing about getting the paddle out and breaking a few drills for nothing.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Aug 22, 2016 9:33 pm
Finally got round to getting the old bush's out of the spare trailing arms and panhard rod, the arms and rod all cleaned up and painted and then fitting the sparkly new thermoplastic polyurethane polyester based bush kit from Milner's.
Apparently they come in their trademark orange ya knows. The bushes are renowned for their high tensile strength compression memory set and abrasion resistance. And they locate in the lower and upper trailing arms and panhard rod which join the rear axle to the chassis. Also come with bolts and nuts too!
The new ones were somewhat easier to fit than the old un's were to get out which took a 20 tonne press to shift!
The shiny newly re-furbished bits will be on the Truck by Sat, then the process starts all over again to get a set ready to go onto O-no.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Aug 27, 2016 3:24 pm
Replaced all of the rear trailing arms and the panhard rod on Truck with the newly re-bushed ones and taken it for a test drive. Much better. Just got the front end to re-bush now. Oh and the old trailing arms and Panhard rod to de-bush, clean up and re-bush ready to go onto the other 2.8.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spikey on Sun Aug 28, 2016 12:51 pm
Swapped the stereo from my Corsa to my 2.2 Sport called Bug :)
Oh yeah, changed the center interior bulb for a green LED one.
Frontera B Sport 2.2i 16v
Cardio, check the back seat, double tap
Spikey
Vehicle Name: Bug
Modifications: Dents and scrapes :\
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Mon Aug 29, 2016 7:08 pm
Put new pads on the front, she's been pulling to the left and seemed a bit sluggish lately, passenger side was all the way down to the mettle and the piston was stuck out all freed up and running smoothe. She's had a new lease of life.
New tyres arrive tomorrow.
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Tue Aug 30, 2016 9:23 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spikey on Tue Aug 30, 2016 4:55 pm
Today I've skinned my knuckles, elbow and got covered in oil replacing the alternator, which was OK, apart from trying to get the damn 14mm nut on the back again! It pinged off a few times, then hid. Now I need to find a spare, as I'm sure the pixies have stolen this one....
Apart from that, it all works fine, is charging and that makes me happy :dance:
Spikey
Vehicle Name: Bug
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Wed Aug 31, 2016 10:52 pm
Fitted 33s on -32 offset steal rims, trimmed front bumper.
Still catchin so the grinder will becoming out tomorrow.
lee771
33 12.5 15s
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Sep 01, 2016 8:36 am
Worked out fuel consumption for my dti, on a recent 700 mile mission, dragging an 800kg ifor, delivering an engine on the way out, and collecting another frontera, then a journey 350 mile back through snowdonia, and hillyness of the west midlands...
And the old girl did 33mpg overall...not bad for a 185,000 y22dth dti!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Thu Sep 01, 2016 6:04 pm
Attacked my wheel arches with a death wheel no more tyre rubbing, surprised at how well she drives with 33s on and the noise ain't to bad either nothing a bit of Toby Keith can't drowned out any way.
lee771
33 12.5 15s
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fil-H on Sun Sep 11, 2016 11:58 am
Wow! Found this group on Facebook ! So posted sum pics up - this a bit easier than photo bucketing...
3.2 v6 2002 black manual lwb in need of some tlc, but roadworthy!!! (currently at home)
3.2 v6 1999 premium blue lwb manual- just couldn't resist it !!! ( currently at home)
3.2 v6 2003 black manual lwb- a little poorly but gradually recovering |||( currently at home)
3.2 v6 2004 silver manual lwb - stunning condition and performance but sold because I missed my old black one so bought a black 3.2 instead! ( gone :0( )
2.2i 1995 black manual lwb (stupidly sold, sadly missed -but still alive ( gone :0( )
Fil-H
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Sep 13, 2016 6:07 pm
Can't see what you did!!!!
Or is it me just missing the point here
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Sat Sep 17, 2016 6:54 pm
it was time to bring the caravan back again and this time after all the work thats been done to her the car pulled brilliantly ....so pleased
aredee
Vehicle Name: Bubbles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fil-H on Sat Sep 17, 2016 11:38 pm
Cleaned up my oil filler cap !!!
Fil-H
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Spikey on Thu Sep 22, 2016 2:43 pm
Got it back from the storage yard after a bump :)
Spikey
Vehicle Name: Bug
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Fri Sep 23, 2016 8:16 pm
Truck. Not much, just a few small jobs. Front end, both sides. Changed the upper wishbones. Front brake hoses. Replaced the last 200mm of the brake lines on both sides (had to cut it to get the pipe out of the way to replace the wishbones). Brake callipers. Brake pads. Top ball joints. Bottom ball joints. Front wheel bearings and seals. Steering knuckle support bearing, shim and seal. Drive shaft CV joint boots.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Sep 30, 2016 8:34 pm
Drove it :dance:
And it didnt play up........ apart from coming close to losing the exhaust as ive lost a one of the bolts holding it on
