Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Mon Jul 25, 2016 4:41 pm
Removed the black tint on my Frontera's rear light clusters, as I got bored with them being tinted. What a messy and sticky job that was but it was worth it.
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gruntera on Mon Jul 25, 2016 6:14 pm
Today I think I found a Fronty to buy. 2.5 diseasel, already lifted on big rubber. I got a court case on 4th August - I'm suing someone - and if I win, which I'm confident I will, ill have a load of compo and a shed load of my own money freed up so i'll be buying it.
Gruntera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Mon Jul 25, 2016 6:33 pm
Got all the water and turbo pipes sorted on the 2.8 conversion so started it up and let it run for about 15mins. Just the clutch, downpipe and brakes to sort out the give it a run out :D
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Tue Jul 26, 2016 8:32 pm
Over the weekend I got the new wheel cylinders fitted and brakes bled :-)
Also bought myself a cheap supercharger from China to see if I could up the power of the old 2.4 lump, after a bit of a fiddle and some head scratching got it fitted in such a way that you can't even see it when you open the bonnet ;-)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sat Jul 30, 2016 12:05 pm
Bought these yesterday for Tessie :-)
4G WiFi
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Jul 30, 2016 9:59 pm
Re-welded the twin rear exhaust boxes, after they have been laying in the shed for nearly a year and they will be back on my Frontera tomorrow.
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Sun Jul 31, 2016 9:33 am
had air con topped up nice and cold now
aredee
Vehicle Name: Bubbles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Jul 31, 2016 12:28 pm
Removed the old broken 2.8 engine now waiting for my new one to turn up
Forget about horsepower redneckpower is the way forward
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sun Jul 31, 2016 4:54 pm
Finally got round to replacing the front exhaust down pipe, after having the brand new one since 2014 :oops: and the twin rear exhaust boxes are finally back on.
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Aug 07, 2016 3:33 pm
Over the weekend I've put the new engine and gearbox in the 2.8 ( I had a bit of help from bobbingjob AKA Ian the other day )
It's up and running. I had a test drive of 25miles. I've missed driving the fronty. Couple of small issues to sort out. Oil return pipe from the turbo has a small leak at the bottom. Oil pressure gauge is sitting past the red line when driving. And the temperature sits at 3/4. Plus it's a little bit slower than then old engine was.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by red5 on Mon Aug 08, 2016 11:13 am
Moved my 'sleeping' 2.4 off my mums drive (and then back on) seeing as my own is mostly full of Swb leafer and creaking RangeRover...:-)
Must pull finger out. :-)
red5
Some dentage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Aug 09, 2016 10:53 pm
Started it as battery needed topping up, been parked up for a few weeks, no time to tinker as swmbo has me on a mega DIY project
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Wed Aug 10, 2016 5:48 pm
Give it a wash as coming weekend we will have the annual meet of German opel4x4 at Idar-Oberstein.
Hope weather will improve a bit - last night there they had only 4°C.
Not that many seem to come due to work/holiday/other interests... Some of our 'veterans' announced to come with Defender or Peugot-Dangel 4x4.. I am a bit curious.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Sat Aug 13, 2016 12:05 pm
Made this for the B serise 2.8 conversion
Not to bad I don't think as not used a lathe or mill c for about 30 year
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Aug 13, 2016 1:25 pm
Did the B series originally have a MUA5 gearbox onto the original engine?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Sat Aug 13, 2016 4:43 pm
Yer they do just having problems getting the clutch to work as there was to much free play between release bearing and pressure plate.
Been having a good play about with it today and it looks like the pressure plate is compressing to much
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Aug 13, 2016 5:58 pm
Did you swap the bellhousings over and then use the 2.8 clutch/flywheel/release bearing.
e.g.
2.8 gearbox with 3.2 V6 bellhousing:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Sat Aug 13, 2016 6:38 pm
Yer used bell housing but not flywheel. Using the vx brava solid flywheel 2.5td as that's all I could get at the time.
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Aug 13, 2016 8:40 pm
3.1 TD would of done as well. It is solid as well. Did you drop the spacer between the engine and gearbox?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Sat Aug 13, 2016 9:08 pm
Yer all gone. Wouldn't care done 1 conversion allready and had no problems.
Opened a new post in clutch section
robbie
2.0 1997 the gold1.
2.0 1997 green1.
