Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Jun 28, 2016 9:20 pm
well this weekend i had the truck in coventry for a little work.
and had fun with a train ....
didn't do anything today!!
david.smith0143
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Jun 29, 2016 11:13 am
Yesterday on way home from work I used it to stop traffic on the a10 as there was a car in the middle of the road with a snapped tie rod. A defender was already there getting his tow rope out so I left him drag it into the nearby lay-by until her recovery arrived. She was behind a bush on a left hander smack bang in the middle of the lane. She's lucky traffic was bad otherwise she'd of had something jump into her boot at 60mph (hense why I blocked the road just before the bend)
Naturally, even tho I'm very clearly stopping traffic, hazards on, facing the oncoming traffic at a 45degree angle and standing next to it in a yellow hi-viz rain coat a muppet in a BMW thought it be a good idea to plow down the middle of 2 lanes of traffic and go past me. For the sake of the 5mins I closed the road you'd of thought he could of waited. Mucking fuppet. Wonder if he would of done it if I had blue flashing lights in the grill :yawn:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fil-H on Wed Jun 29, 2016 9:50 pm
nearly, very nearly finished the reversing camera installation. spent a week of evenings chopping it into the sun visor nice and neat but rain stopped play tonight finishing the cable routing behind the panels..........
3.2 v6 2002 black manual lwb in need of some tlc, but roadworthy!!! (currently at home)
3.2 v6 1999 premium blue lwb manual- just couldn't resist it !!! ( currently at home)
3.2 v6 2003 black manual lwb- a little poorly but gradually recovering |||( currently at home)
3.2 v6 2004 silver manual lwb - stunning condition and performance but sold because I missed my old black one so bought a black 3.2 instead! ( gone :0( )
2.2i 1995 black manual lwb (stupidly sold, sadly missed -but still alive ( gone :0( )
Fil-H
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jun 29, 2016 11:17 pm
Cracked out my spare front hubs and fitted a new set of main wheel bearings.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Jul 01, 2016 9:35 pm
Replaced the intercooler radiator today.
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Fri Jul 01, 2016 10:13 pm
drove past it and pined
aredee
Vehicle Name: Bubbles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jul 02, 2016 5:19 pm
Looked at it and.....
Adjusted the handbrake
Then
Found a worn Propshaft U/J
Found both front wheel bearings need adjusting
Found the bush's in both front upper suspension arms worn and will need replacement.
Found a split CV boot
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jul 03, 2016 1:26 am
Drivers side:
Main wheel bearings.
Upright needle bearing.
Thrust washer.
Upper ball joint.
lower ball joint.
Outer tie rod joint.
Outer CV joint.
Swapped auto hub for Aisin manual hub.
That should cover things for a while.
Once the new ball joints arrive the passenger side will be done.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Jul 05, 2016 11:45 pm
Replaced the clutch slave cylinder when I got home...
But first, kicked off at silly time this morning to get to the old HMS Dryad site for 08:00. Normally a nice gentle 2 hour drive, 20 mins into the trip and needing fuel I pulled into the garage and tried the clutch... Apart from the pedal hitting the floor in a smart and soldierly manner 'fek all else happend' truck kept going until I stood on the brakes, forcibly dragged it out of gear and turn the engine off at the same time to prevent it ramming the car sat at the pump in front :shock: Oh brill, dead clutch thingy, great start to the day...
Needed fuel anyway so filled it up.... Then pulled the clutch pedal back up from the floor to see what was going on (no fluid under the truck at this stage) and checked the reservoir which still had fluid in. Amazingly the clutch worked! A quick purchase of some brake fluid to keep it topped up and off we went on the principle so long as it lasted until I got on the M/Way it would get me there and if it didn't then the RAC would!
Made it okay, got the permits sorted and work started leaving me with a day of trotting between Dryad, Blockhouse and the Navel Med sites prepping next weeks stuff. Also rang my local factors Motor Parts Direct and ordered a new clutch slave cylinder (delivered to the door so it was ready for me to fit when I got home. Totally recommend them for service).
Managed the day's drive about okay with the odd 'fluid top up' and then the 90 mile drive home. The clutch literally died just as I pulled up at the house and parked up, bonus!
So... New clutch slave cylinder fitted... To do, new clutch master cylinder on the pretext it's done the same amount, if not more work as the slave cylinder over the years and I'm getting in before it dies in the middle of nowhere!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Jul 09, 2016 3:06 pm
Just replaced the drive belt and drive belt tensioner, I'm surprised that the drive belt tensioner didn't snap due to the amount of wear, check my photo's.
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sun Jul 10, 2016 9:22 pm
Fitted 2" lift shackles and wound up the front torsion bars ( slightly too much and now handles like a rabbit in full run lol ) :-)
New fuel pipe as the old one had started spraying the exhaust manifold ( not good :-( )
Now I find a rear wheel cylinder has bitten the bullet and covered the shoes in lovely brake fluid so i now know what im upto for next weekend
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Mon Jul 11, 2016 9:21 pm
Been parked up since out side since Feb, as I had an affair with a 3.1 trooper that I blew the rear diff on last night.
Walked up to my fronty this afternoon apologising humbly and begging for forgiveness, put £15 of fresh fuel in her checked the belts (the alternator belt Is a little fraud but not too bad) put some tape around a split air intake hose checked the oil looked good and clean jumped in said a hail Mary turned the key and bugger me she fired straight up was a little lumpy for about 3 or 4 minuets but settled down and sounded sweet even the tires had only dropped by a couple of psi each.
I god damn love my truck and for the life of me cant think why I bought the trooper!!
Long live the Frontera.
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Muckmagnet on Wed Jul 13, 2016 6:02 pm
Took the truck for it's annual medical and it passed :D Couple of advisories, like deteriorated number plates and a windscreen crack but hey-ho, another year's enjoyment ahead :D
Live for today -tomorrow might turn into a can of worms ;)
Muckmagnet
Model: 2.5 TDS Transglobe 5dr
Modifications: Roof lights, Rear work lights
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sat Jul 23, 2016 3:30 pm
Fitted a new heater matrix the "easy way"!! I have never had to fit a matrix to any other car other than vx. I vow never to do another as long as I live.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Sat Jul 23, 2016 4:04 pm
took it for a drive been just over 2 months off the road so really enjoyed
aredee
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stretch on Sat Jul 23, 2016 9:56 pm
Glad you got it sorted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sat Jul 23, 2016 10:12 pm
Change the rear tyres to a couple of part worn Grizzly Claws I had knocking about. Quite cuffed with myself, because I did it on one of them DIY stands and a combination of standing on the walls so that the tyre rim sat in the wheel inner recess correctly and tyre levers. Did paste on some of that pink wax stuff to assist the tyre going over the rims. Bit of feffing and jeffing going on but I got there. Then it was a matter of four tank fulls of compressor air before the loud pop with the tyre walls finally pushing up against the rims. You wouldn't want your finger in the way when they do pop. Put it this way, it will stop you picking your nose.
In the end it became a real necessity, because the Special Tracks that start off with 25mm high blocks were down to about 2mm. Must have even been in the realms of bald tyres had I got pulled over :shh:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jul 23, 2016 11:21 pm
Well done Pete...I remember when I had one of them things....so glad I have a proper tyre machine now!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Jul 24, 2016 7:50 am
