Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Apr 01, 2016 12:08 am
Did you use the B pipework to Chris? Is a good mod, much better than the crusty A ones....see I aint just a pretty face!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Fri Apr 01, 2016 6:46 am
Yep all the pipe work is in I probably should of had the clips that hold it to the bulkhead too would of looked better than cable ties
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Fri Apr 01, 2016 11:47 pm
Today, after clearing the drive, I got the blue Sport S home after having it parked at work the last week or 2. Loooooong drive was looooooong (~25 miles)... and embarrasingly slow (1.5hrs, inc a food/cool down break)..
Anyways, guess what I'll be playing with over next couple of days to see if my problems are more extreme than they might be?! :dance:
Don't confuse your books:
Gone but not forgotten...
Comments here
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sat Apr 02, 2016 7:00 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sat Apr 02, 2016 9:41 pm
mudman1988
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Apr 03, 2016 10:59 am
You will be fine Pete, I have done this to an ABS A before.
As I told Chris you need the crossover pipe and vac tank from a Derv B series, I have a couple of dti's here I am breaking so can so
can sort you out the same parts that I did Chris if you wanted to do it...
I have done a few now, as the OE vac tanks rot out in the wing space,
and are an awkward shape to remount, wheras the B one is much more accomodating, nestling in nicely where the birdness used to be.
All you need extra is a longer rubber vac pipe to run from the pump on your alternator to the t-piece in the cross over pipe...
Be good to see you Pete, havent seen you in ages, pop up when you are next over Maidstone bud...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sun Apr 03, 2016 6:04 pm
Pics now in my members rides thread
mudman1988
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Sun Apr 03, 2016 9:34 pm
re located the vac tank to the n/s inner wing
fitted 2 new wings
fitted a snorkel
new led side repeaters (but I broke 1 already :oops: )
edited cause I forgot the pics :oh yer:
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Apr 03, 2016 9:55 pm
Started making my rock sliders. Will have to take them off soon to repair one of the sill because I poked it with my finger lol
This is the sill that now needs repairing
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Apr 03, 2016 10:08 pm
You should start making pattern panels. At this rate you can make a killing considering how many you have welded up recently.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Apr 03, 2016 11:36 pm
Fitted replacement OS driveshaft, new CV support bearing, new wheel bearings and seals, lower ball joint and it is now back on all 4 wheels and working 4WD.
Fitted new steering idler to replace the new one that got bent at its last outing.
Removed radiator and started fabing up a mounting frame to hold the new electric cooling fan
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Apr 05, 2016 2:11 am
We visited the MOT station on Saturday, passed again with no advisories..............Not surprised really after fitted a stack of new bits.
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Apr 05, 2016 8:08 pm
today i removed what was left of the exhaust
not much left, and yes this part is in 2 pieces.
time for a new one i would say...... anyone know where i can get a duck exhaust from :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Apr 06, 2016 11:24 am
Hope you drove it .. or couldn't you resist using the Chinook :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Apr 10, 2016 5:33 pm
Had a look at the camber as I have had a slight pull to the left since fitting the Calmini arms, N/S was out so removed a couple of shims and its now about right. Then went to check and adjust the tracking only to discover the NS steering arm was slightly bent. Fitted my spare arm, just need to order some new ones from Milners
Finished the electric fan bracket, painted it and attached the fan. New fan thermostat switch arrived so hoping to fit them soon. TBH I have been driving it for the last week without a fan, as long as I don't get stuck in traffic or climb any really long steep hills its OK, heater is the best its ever been :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Apr 10, 2016 8:59 pm
Bought it .. well yesterday I did.
1994 (imported 2004) Mk.II Isuzu Bighorn 3.1 TD auto Lotus Edition.
Had for less than 90 mins and already in the mud lol.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Apr 10, 2016 9:45 pm
Noyce...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Apr 11, 2016 11:04 pm
Driving home from work today I had some really horrible sounding grinding/squealing noises from the front.
Popped it in the garage, jacked it up and it looks like something was trapped behind the brake disc shield. Turns out it was what was left of the one of the brake anti-rattle spring clip.
Spent over an hour trying to find one in my spares stash but no chance, plenty for the rear but nowt for the front.
Found some new ones on eBay and should be here Thursday
Bought another Project
MG Autos (Mark)
Member & Trader
Registration Year: 1994/M
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Thu Apr 14, 2016 8:48 pm
Reminds me of my first Fronty its just missing the tinted windows :-)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
