Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 21, 2016 10:02 am
I use the spring gauge method on both mine. Seems to work. It is how they tell you to do it in the Isuzu Workshop manual for both the Gen 2 Rodeo (Frontera B Series) and all the Troopers. There are two values depending on whether they are new or re-used ones:
New:
20-25 N (2.0-2.5 Kg m : 4.4-5.5 Lb)
Old:
12-18 N (1.2-1.8 Kg m : 2.6-4.0 Lb)
Like you I was skeptical, but then it is the sort of basic and simple thing Isuzu comes up with for doing stuff.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 21, 2016 7:40 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Mar 21, 2016 10:40 pm
Its now in the garage, jacked up and ready to sort out the front driveshaft.
It looks like the CV cup on the diff has survived just hoping the shaft I have is the right size
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronty4x4spares on Tue Mar 22, 2016 12:39 am
I have some 2.8 shafts if you havent got the right one Yaki...
Visit our Ebay Shop by clicking HERE
Contact us by phone, through ebay or by PM on here on FOG.
Currently breaking A's and B's....3.2v6's, 2.2dti, 2.8tdi's, 2.4i's, 2.0i's, 2.2i
Next day delivery on most parts...every part tested fully. Payment by Card, Cash, Paypal or BACS
Fronty4x4spares
Member & Trader
Vehicle Name: Call Greg 01622 739908
Modifications: We specialize in tested used Vauxhall Frontera spare parts, from both A and B series models.
We offer rapid delivery on all of our parts, and very competitive pricing.
We are currently breaking
B Series 3.2 V6 Manual
B series 2.2dti. x22dth and y22dth
B series y22se lwb 2.2i
A series 2.8 LWB x3
A series 2.2i x22xe x2
A series 2.0i sport c20ne
A series 2.4i lwb
A series 2.3td
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Mar 22, 2016 1:11 am
Front end is all Trooper and has bigger inboard CV's than the Vauxhall offerings :!:
The Troopers seem to have at least 3 variations in CV joint size, just hoping the spares I have are the right ones otherwise the front axle will need dropping to change the halfshaft
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 22, 2016 8:39 am
I know of three. Standard and wide track. Then you had the pre-1987 which had 26 outer splines into the hub.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Mar 22, 2016 10:23 pm
Started work on replacing the OSF driveshaft, stripped off the hub and hub carrier, inspected the inner CV cup and it is still intact and no damage. Trial fitted the replacement driveshaft and the replacement inner CV is the correct one :D
Extracted what was left of the CV joint not that there was much to remove
Looks like it had started failing a long time ago as the failure point had worn smooth before it finally completely let go
Unfortunately it has also damaged the hub carrier :( But I do have a spare one
Ordered new bearings, seals and bottom ball joint so hopefully have it back together next week
Am probably going to strip out the Milner CV joint from the other side just in case it too decides its had enough
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Mar 22, 2016 10:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 22, 2016 10:44 pm
No idea .. never replaced a CV joint. I cannot see how the CV joints change length as they all use the same hub carrier. I thought the drive shaft changed length .. unless the cup gets deeper?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Tue Mar 22, 2016 10:47 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Mar 23, 2016 12:01 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Mar 23, 2016 1:50 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Mar 23, 2016 1:52 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Mar 23, 2016 9:28 am
It is one of the great Isuzu mysteries .. even in the club :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Mar 29, 2016 7:26 am
Jeep passed it's mot yesterday with only a few advisorys, one of which is that it has a engine cover.... So not too worried lol and late last night I found someone chucking out a briggs and Stratton petrol rotorvator (spelling?) so I had got that for free. Scores!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Tue Mar 29, 2016 9:45 am
Spent yesterday making brackets for the front bull bars that I picked up from Cornwall :-)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Wed Mar 30, 2016 10:02 pm
Changed the instrument cluster bulbs to blue LEDs.
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Wed Mar 30, 2016 11:11 pm
Moved it, from one side of the drive to the other. The Niagara sport still lives (ironically better sounding than the Sport S!).
Lots planned, awaiting delivery of parts and presents, so we'll see what happens this next week!
Don't confuse your books:
Gone but not forgotten...
Comments here
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Thu Mar 31, 2016 5:44 pm
Not all . Fitted new fuel lines feed and return, new fuel filter and housing with built in primerpump along with a second hand injection pump to the 2.2 dti I got last week. And all seams to be going good.
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Thu Mar 31, 2016 6:35 pm
Fitted a B series brake vac tank to replace my old rotten one in the wing witch had to be moved for my snorkel and relocated my winch solenoid pack under the bonnet keeping the plug for the wonder lead on the grill and put secondary controls for the winch in the cab, I'll post pics when I take them
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Users browsing this forum: No registered users and 60 guests
