Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Fri Jan 15, 2016 6:34 pm
Cured the leaky roof panel...........replaced it! Must have an airline crack in the old one somewhere the panel it's self was full of water, and managed to find a rear screen with a working heated screen elements, well most of em lol.
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Jan 21, 2016 6:50 pm
Finally got some Frontera time :D
Flushed out cooling system including the heater matrix, fitted new thermostat but not refilled it yet, ordered a 3" long hose joiner to extend the bottom hose to accommodate the 3" body lift but its not arrived yet.
Drivers door glass had come away from its plastic mountings so out came the glass and mounts and have reattached with Araldite, glass refitted.
Power steering belt idler bearing was noisy, stripped it down to check the bearing size and new bearing ordered
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Thu Jan 21, 2016 10:24 pm
Went to a yard with my Ifor Williams 2 tonne trailer got it filled up with scraped tarmac from a huge digger. At the weighbridge it was 1,7 tonnes.
Towed it to the drive being done and when we unloaded it there wasn't enough so I went back and this time although the trailer was filled up the same it was 2.5 tonnes !
Very pleased to have saved twice the delivery fee of £90:00 which is £180:00. The fronty's almost paid for itself this year already.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Jan 21, 2016 11:23 pm
How much are they doing the planings for Julian, might need some myself?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wnderer on Fri Jan 22, 2016 2:32 pm
replaced my duff glow plug relay for a good landrover one from this Image to this Image
wnderer
Registration Year: 1992/J
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jan 23, 2016 6:38 pm
Finally got round to replacing the OEM side repeaters for some neat LED units... No more hunting missing lens after a scratchy lane!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Jan 24, 2016 8:45 pm
Plumbed in the boost gauge
Fitted new idler pulley bearing
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jan 24, 2016 9:38 pm
Welcome back Yaki :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Jan 24, 2016 9:57 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jan 24, 2016 10:46 pm
Hope you passed. :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Jan 25, 2016 12:40 am
I did :thumbup:
Bit of a rollercoaster, you don't find out you result for 7 days. Immediately after the exam I thought I'd failed, following morning after thinking some more I thought I should have done enough to pass but as time went on this reverted to I think I failed. Then the certificate arrived and I'd passed with merit so did quite well :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Jan 25, 2016 9:49 pm
Since the duck has been dropping bits. I ordered some stainless
And started to make a stainless steel exhaust... 2" stainless... all of 20M worth
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Tue Jan 26, 2016 5:40 pm
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 26, 2016 9:58 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Wed Jan 27, 2016 8:46 pm
Fit an alarm after some scrote had my stereo away, fit a 7" flip screen DVD headunit and a Parrot hands free kit
jaybrian32
2" Body Lift
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aredee on Wed Jan 27, 2016 9:38 pm
hi jay what flip screen did you fit i tried one a while ago and cant remember exactly why or what it clashed with but the screen would foul up on something above and not open fully so unless you crouched down it was impossible to view
aredee
Vehicle Name: Bubbles
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jan 27, 2016 10:21 pm
Hose joiner and new clips arrived and fitted, cooling system refilled with fresh antifreeze.
Replacement fan cowling modified to clear the fan and fitted and made a start on the intercooler hoses, there are some silicone fitted however after fitting the fan cowling the modified plumbing no longer fits so its now a toss up between modifying the plumbing or taking the fan cowling back off :?
Whilst under the bonnet I tidied up the loom where the snakes nest was, removed all the redundant connectors and sealed off the surplus wires.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jan 27, 2016 10:27 pm
And discovered the wastegate bracket had worked loose and the bolts were missing, now sorted
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Wed Jan 27, 2016 10:54 pm
jaybrian32
2" Body Lift
Fire Extinguisher
