Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furio on Wed Dec 09, 2015 8:03 pm
Finally managed to source a solid rear tank guard, now all painted up, they are getting like hens teeth for a good one. While off also replaced some fuel pipes at the back that were looking past it. Now found one of my sills has turned to tissue paper so need to get that welded up. Bloody tin worm :roll:
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sun Dec 13, 2015 2:37 pm
New rear trooper springs and monroe adventure shocks fitted and another few turns on the torsion bar, no more saggy ass :thumbup: Nothing snapped and no seized nuts or bolts, that's the good thing about buying a Cornish truck, hardly ever see salty roads.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Dec 16, 2015 3:45 pm
Fitted my new boots 33 12.50 15 on modular 10j
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Dec 16, 2015 5:08 pm
Nice .. poser (with your white/blue writing on the outside :D )
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Dec 16, 2015 5:58 pm
I will be changing the white/blue writing to red
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Dec 16, 2015 7:08 pm
Good lad!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Dec 17, 2015 12:07 am
Nice.. 8) 8) 8)
Stop bringing back memories Andy, that will tempt me to build another one!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Thu Dec 17, 2015 8:57 am
Got a new starter yesterday.
Next days a new exhaust and a fresh bulb for illumination oft the instruments, and Grünstreifen will be fit for 2016 (MOT in October).
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri Dec 18, 2015 12:51 am
New steering idler arrived today to replace the one I bent at a P&P the other weekend
Its booked in for its MOT on Tues so will be giving it the once over on the weekend as well as replacing the idler
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furio on Mon Dec 21, 2015 12:13 am
The dreaded mot somethin i have to look forward to early jan.Best of luck mate
furio
Roof lights
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Dec 21, 2015 12:46 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Mon Dec 21, 2015 3:20 pm
Mot this morning and one patch of welding later I'm now sat waiting for its retset this afternoon :-)
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Dec 21, 2015 3:27 pm
Where the hell have you been hiding Rich?? :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Mon Dec 21, 2015 4:15 pm
I'm still here :-)
Lurking in the shadows ;-)
4G WiFi
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lurchy666 on Sat Jan 09, 2016 1:40 pm
drove over a speed bump and the torsion bar adjuster bolt snapped....... went with one hell of a bang.... luckily only a few mins from home.......
just brought 2.5 tds lwb
lurchy666
Modifications: no mods so far
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furio on Sat Jan 09, 2016 2:56 pm
Ouch!! Good job you were near home!
Replaced radiator last night with the new one that was sat languishing on my donor truck.Seems to be running a bit cooler now.
furio
Roof lights
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sat Jan 09, 2016 4:44 pm
A friend sorted the brakes and tested them at a MOT Garage, looking fine.
Today checked from beneath and several other points. Had to replace only both bulbs of the city lights - thank God for my gynecologists-fingers...
Take Godzilla for MOT on tuesday. Press your thumbs! 238.000 km in the clock now.
Kind regards,
JEOH
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jan 09, 2016 6:52 pm
Good luck on that one JEOH, IIRC our simple little MOT simply pales into insignificance when compared to the TUV Test/Inspection...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stretch on Sat Jan 09, 2016 7:37 pm
With the help of Bobbinsjob we did the front brake pipes on my B. Could vx have possibly put and more bends and twists in them? Also we found out that brake pipe 'kit' supplied joints arent threaded to the end and the ones in the engine bay are so won't screw in at all. Anyway thats another thing ticked off the mot fail list thanks again for your help Ian.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FronteraBob on Sun Jan 10, 2016 12:17 am
Tried to do new caliper but no banjo bolt with new flexi/caliper and wrong pads without wear sensor , very annoyed !
When words become violence, what could be better than silence.....
FronteraBob
Vehicle Name: Red Devil !
Modifications: Zero....
Skype Username: Saxwood
