Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Mon Nov 16, 2015 5:42 pm
I bought mine back for the dead, it didn't take much it had been parked up for 4 months I'd not even turned the key, I went out to try it get in turned the key the lights come on I thought that's a good start gave it 3-4 hits of glow plug and it went first flick of the key. For the 4 months it was sat there the battery was connected and I didn't need a just start. I love my fronty
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Fri Nov 20, 2015 11:48 pm
Iv'e used mine as a site vehicle all week full of tools and traditionally forged railings as Iv'e been installing them into stonework in a villge outside Canterbury. Even had a welder generator in the back ,running, while I did some welding in the road just behind the fronty.
I expect to be working on it all next week as well.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sat Nov 21, 2015 6:14 pm
Changed oil and filter, need to do the air filter, but couldn't source one today. Gave the torsion bars a little tweak to take out 15 years of use.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Nov 21, 2015 6:57 pm
New front pads and disks at the front on the Mk.II. Was needed after this happened the other week. Bought some cheap disposable pads to tie me over until I could do a proper job. Also replaced all the seals and piston on the passenger front as it was leaking a bit.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Nov 21, 2015 8:00 pm
Took it for MOT only failed on rear brake pipes :D Result!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Wed Nov 25, 2015 4:50 pm
Fitted the tow bar that Greg sent me. Two new coil springs also turned up, but ran out of time. Think I will hold off fitting those until I get a pair of shocks.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Nov 28, 2015 6:19 pm
Replaced the glow plugs on the 2.8 hopefully the car will start in the mornings now.
But when I removed the glow plug from number one cylinder it was covered in oil hope it's not a the start of the head gasket on its way out.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Nov 28, 2015 10:24 pm
My cavalier's plugs were covered in oil and the head gasket on that is aok. Probably just carbon deposits that soak up diesel to look oily. Well that's my theory anyway
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Nov 28, 2015 10:40 pm
Dan could be right .. Have you adjusted your rocker clearances.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Nov 28, 2015 10:50 pm
No Neal I haven't. I will have to get the book of lies out because I've never adjusted valves before.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Nov 28, 2015 10:57 pm
Could be worth doing as it will affect how the valves open/close leading to improper burn.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Nov 29, 2015 8:29 pm
Dodging gale force winds and horizontal rain, I managed to finish fitting a new gearbox and Torque Converter to the P38 (yes I own a Green Oval).
Previous owner was a complete cockwomble and had installed the old one incorrectly. Meant that the output shaft of the TC had crushed the oil pump and that in turn broke it down and sent lots of crud around the gearbox and TC chewing them both up. Managed to source a second hand box and TC for little money and with warranty. Had to do the entire job on my own on the driveway in gale force winds and rain. Bad weather did however cut things short. All that is left to do is fill the Transfer case and gearbox with oil and re-attach the handbrake cable to the handbrake. That is tomorrows job.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Mon Nov 30, 2015 12:31 pm
After a little fun in the woods for the first time since getting the truck last weekend, and finding a couple of overly-friendly trees...
... and after a little drive from Cambridge to Brum then to Kent yesterday, she went from this...
(Ideas for the summer... hmm! Damn bad ideas...)
... back to this!
Thanks to Greg for a hand, now a replacement roof & tailgate (damn wiring, but working!) sorted. Got to keep it looking good! :drive:
Don't confuse your books:
Gone but not forgotten...
Comments here
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Nov 30, 2015 9:13 pm
Range Rover is on the road again. Finished everything off and she drives and everything. Now to leave positive feedback for the guy I bought the gearbox off :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Wed Dec 02, 2015 1:22 am
Since the trucks been struggling to start these past few mornings, I finally managed to set aside an hour to change the glow plugs. Tested the old ones as they came out, and 3 of the 4 had failed comple
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Dec 02, 2015 10:14 am
Changed the oil stuff in the jeeps engine for some new oily stuff :) the old stuff was black but it's a diesel and tbh it didn't seem that bad at all, maybe the dealer did service it before I bought it after all
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fronty_TPJ on Thu Dec 03, 2015 9:03 am
I have started modifying the front axle hangers to lower the axle, taken the half shafts out and then going to drop the diff out tomorrow ready for the new hangers. This should be fun! Then on to the rear to fit new rough country +3" shocks as my old ones were toast!
1999 Vauxhall Frontera SWB RS DTI viewtopic.php?f=46&t=47878 (Fronty Pics)
1979 Porsche 924 GT Replica http://s1068.photobucket.com/albums/u45 ... che%20924/
Fronty_TPJ
Vehicle Name: Blue Thunder
Modifications: [IMG]http://i1068.photobucket.com/albums/u453/Fronty_TPJ/P1050062.jpg[/IMG]
Skype Username: tim.jay3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lee771 on Fri Dec 04, 2015 5:15 pm
Sat in the MOT station hiding be hind the sofa waiting on the results!!!
And she passed!!!!
Advisory on corroded dust cap and close to limit tyre other than that all good.
The search for mud tyres begins
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bennymac on Fri Dec 04, 2015 5:42 pm
Well I am delighted that mine passed an mot today with no advisories :)
To be fair the guy noticed a couple of things and because he knows me he just verbally told me so I can sort it tomorrow.
Cv boot was insecure and two split pins missing from front ball joints other than that she's sorted.
I do have a running issue at the moment though but she behaved during the MOT so all is good for me roll on winter..
bennymac
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Dec 07, 2015 6:56 pm
Replaced both upper ball joints because the old ones had a bit of play in them. ( yes they are flipped )
