Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Shaggy on Wed Sep 30, 2015 8:54 pm
Broke down on the way home from work... Turned out the bloody crank sensor had fallen out lol :oh yer:
Shaggy
Model: 2.2i Transglobe 5dr
Vehicle Name: Dorothy
Modifications: 2' suspension lift
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Bluetooth Sony headunit and uprated speakers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Sep 30, 2015 10:04 pm
That could explain your other running issues ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Shaggy on Wed Sep 30, 2015 10:16 pm
Indeed it could. With any luck anyway :thumbup:
I took it to be diagnosed earlier (partly the reason we think the crank sensor fell out..) and had the new O2 and Maf sensor 'learnt' but the crank sensor code kept on coming up. Looked into it whilst it was idling and it kept fluctuating between active/inactive. Gonna take it off tomorrow and clean the connections as there was a lot of dried mud on them. Also looked at the alternator and that gives a steady charge :D For once I actually feel like im getting somewhere with it
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Oct 01, 2015 8:10 pm
Got the engine back in the truck. A bit awkward but in! I would love to know who designed the oil pickup pipe so i can punch him in the gob!!!!!!!! Has anyone seen how its held on in the sump. Its 2 torx bolts that you cant undo as there coverd by part of the casting. Doh!!!!!!! :shock: Got a day off from her tomorrow so will be getting her ready to fire up on monday. :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Sat Oct 03, 2015 9:37 pm
Fit some reclaimed wind deflectors, changed my rims for some tasty 5 spokes and treat her to a soapy spongeImageImage
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Gave the truck a well deserved clean,done 140 miles since new clutch fitted,rear crank seal,and head gasket done.
martinkettering
Modifications: 3" rear lift
2" front lift
Cb radio
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Oct 04, 2015 1:52 pm
I wanted an A bar on the bumper so I made this today Out of an old chain. A little bit of mad max :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Oct 05, 2015 12:45 am
Having neglected the Fronty for a while, a task list has been drawn up and the jobs being tackled bit-by-bit. Here's hoping all goes well.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by caesium on Mon Oct 05, 2015 10:38 am
I'm changing the heater matrix, again!
caesium
Vehicle Name: Shoot Truck
Modifications: 2" Lift on ES9000's
Isuzu Trooper steering wheel
Viper total closure alarm
2 Huge HID spotlamps
Entirely Raptor Coated
DAB Radio
Plenums Removed and Oil Catch Tank fitted
Bonnet ducts for heat management
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Oct 08, 2015 10:37 pm
Replaced the two Manual Front Hubs (Milners) with a pair of new AVM Manual Hubs.
See if I can break one of these on Sat's laning trip like I did the old ones a few weeks ago.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Oct 10, 2015 8:06 am
Got the new engine running yesterday. All well apart from one small oil leak from the turbo return pipe. Oh and my mate replaced 2 brake pipes at the front, on bleeding the system the last bleed nipple snapped so have had to order a new caliper at £55+vat ! At least she sounds nice with no smoke!!!!!!!!! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Oct 10, 2015 8:26 am
Well done bobster!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Oct 10, 2015 7:12 pm
Well today I attempted to replace the clutch.
Redneck one man gearbox tool. Set up
Drained the gearbox oil - Removed the exhaust down pipe + both prop shafts then removed all the bell housing bolts. Undone the gearbox mount then lowered the gearbox down and slid it out of the way.
Then checked the clutch only to find someone in the past has bolted the flywheel and used a trooper clutch. :oh yer:
the bearing was noisy and had a badly fitted carrier only being hold by one side of the Spring. so replaced the bearing with the new one.
Now do I unbolt the flywheel and use the 2.8 clutch or just put it all back together. The clutch that is already in there doesn't look to bad ??
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Oct 10, 2015 7:38 pm
Return the 2.8 clutch to the wholesaler, get a trooper kit and fit that. You know it makes sense after all the hassle involved getting the gearbox off. Chances are, if you just put it back on as is your going to be taking the thing off again within 12 months to replace the clutch.
I know the remove/replace thing isnt really that hard to do (had enough practice with mine ffs) but even so it's a job to be avoided if you can.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Oct 10, 2015 7:43 pm
Took it for a wee drive around the Gloucestershire country side to test the new AVM hubs that I fitted last week. Went well, didnt get stuck anywhere and didnt break anything either!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Oct 10, 2015 10:46 pm
The clutch is fairly new apparently. Was changed not long before I got it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Oct 11, 2015 9:39 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Shaggy on Sun Oct 11, 2015 12:01 pm
Bought myself some spot/driving lights yesterday. Now to add some side light holders to them and wire them up
Gonna run 4 on the roof and 2 on the front :thumbup: Can't wait for those long dark winter nights :lol:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Oct 11, 2015 12:20 pm
Out on the front yard fitting the new rear springs, and watching the sky for XH558 to go over or is it watching the sky for XH558 and fitting the spring job in while waiting....
Take off set for 13:00 apparently, hopefully they will do a centre-line run and a couple of tight circuits when they get here. Centre-line run will give a nice side view, tight circuits a good view of the underside!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Oct 11, 2015 12:31 pm
We're keep an eye on that Frank, daughter said something about 3.45 over Brize.
Users browsing this forum: No registered users and 41 guests
