Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Thu Jun 25, 2015 8:52 pm
well the new box section sills are now in place and welded - nearly tidied up just need a little body filler along the top edge and then some paint or similar(!) - pics to follow when (finally) complete.
on the plus side I have a nice welders tan on my arms!!!
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cossiejay on Fri Jun 26, 2015 8:12 pm
sent it to the garage for a clutch
cossiejay
Modifications: 2 inch body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mordusy on Sun Jun 28, 2015 12:03 am
Fitted better carpet, heater box and better dash with no screw holes :0
mordusy
Registration Year: 2002/52
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jun 28, 2015 10:18 am
This:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Jun 28, 2015 6:40 pm
So got some new boots fitted yesterday. Well chuffed as got them at a bargain price at just £420 fitted for 4 general grabber at's in 265 70 17.
So as it stands it's got;
2" lift
2" wheel spacers
Bonnet guard
265 70 17 GG ATs
Pinch weld mod
The pic's:
I went out and did a local lane to give the boots there maiden voyage and took this shot again (last time it was in stock form, see further up)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stretch on Sun Jun 28, 2015 6:55 pm
Sold the 2.5 :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Jun 28, 2015 8:45 pm
You do sell a 2.5, you infect someone else with one....kinda like you dont buy a 2.8, you adopt one!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Sun Jun 28, 2015 10:18 pm
Found a silicone hose to replace my split inlet pipe, had to relocate the IAT sensor to the top of the air box.
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ianoneill1981 on Tue Jun 30, 2015 1:35 pm
Replaced my handbrake cable. What a pig of a job trying to get it over the petrol tank. I would of dropped it but its full and didnt fancy trying to get it back on by myself
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jun 30, 2015 1:50 pm
Took the lower sump plate off the girlfriends Ford Explorer and found this:
That will be bits of the plastic guides for two of the four timing chains blocking the pick up pipe.
With some rummaging and removing the upper sump plate pictured we found the sprung steel tensioner plates for said two chains all torn apart and swimming around the lower half of the block.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Tue Jun 30, 2015 2:16 pm
Started to disconnect every thing on the 2.8 shorty ready to pull gearbox and engine and axels before it gets scrapped
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jul 04, 2015 10:30 pm
Lunchtime Oxford area Glass monthly meet up followed by some lanes in the Wantage / Berkshire Downs areas.
The lanes were pretty scratchy in places, a small puddle of mud was encountered and quickly overcome but other than that all of them very dry and dusty due to the hot weather. Truck did not need dragging out this time!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sun Jul 05, 2015 9:49 am
New MOT yesterday with no faults :D :D
Was worried but shouldn't have been i guess,
the print out shows less than 1000 miles for 373 days since last MOT which it passed previously with no advisories.
with the amount of time and parts this year i have replaced or "improved" if i Include price of fuel and tax, i reckon the running cost per mile is worse than a Ferrari :oops:
2much
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jul 05, 2015 12:43 pm
Well done buddy ... you still love it though ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Jul 06, 2015 12:01 am
Was going to change the front hubs on the D2, drove it into the garage and discovered the N/S/R half shaft oil seal was leaking so drove it back out and parked it up.
I have been given 2 sets of front hubs direct from a large LR parts supplier. D2 front hubs are non-serviceable, when the wheel bearing goes you have to replace the complete hub assembly :!: Apparently they have a batch of hubs that are fitted with the incorrect ABS sensor rings (either too many or not enough teeth). This causes a fault and the ABS/TC lights come on. They have asked if I can fit a pair of hubs to see if fitting a pair stops the fault showing, if this doesn't work then I have the OEM hubs to fit instead 8)
So instead I spent the day working on the Frontera
1. Finished off the rear end wiring. now have number plate lights, interior light and the fuel gauge works :D Fuel gauge was a total PITA, eventually traced it to a break in the main wire about 2" from the fuel tank gauge :!:
2. Cleared out al the crap from inside
3. One of the rear springs had popped off its lower seat so jacked it up and reseated it
4. Made and painted some spring clamps to clamp the springs to the axle mounts to stop 3. happening again
5. Repaired the winch earth lead
6. De-stickered the front and rear windows
7. Re-fitted the drivers seat and seat belt
8. Fitted 1 of the new sunvisors I bought from Greg
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrPete on Mon Jul 06, 2015 2:45 pm
Had a dream I was doing a regular service on a 2.0 shorty, then a valet inside and out... but I woke up before I could take it for a drive, then realised I didn't have one :cry:
One day...
MrPete
Model: 2.0i Sport Niagra 3dr
Skype Username: MrPete_81
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jul 06, 2015 3:51 pm
Bought one ... not an Isuzu or Isuzu derivative either.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Jul 07, 2015 12:18 am
Fitted my rear spring retainers
Did some more of the auxiliary wiring in the centre console, most bits are working but not happy with the hardwire kits for my phone and tablet so will be redoing these tomorrow night
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Jul 11, 2015 4:25 pm
Been out to south Wales today sourcing panels to replace my somewhat scabby ones. Successful mission, too.
Came back with 2 straight and rot-free wings plus a full set of rust free doors, complete with glass, regulators, etc.
All for the princely sum of £120, so a bit of a bargain there I feel
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sat Jul 11, 2015 5:23 pm
