Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon May 04, 2015 9:38 pm
Picked up a Discovery gearbox and transfer box for the Frontera, absolute bargain at £70- and box was rebuilt a few years ago :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue May 05, 2015 11:00 am
I am not sure, but you might be able to get a PTO underdrive for that Yaki!!! 8) 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Wed May 06, 2015 1:14 pm
Will Yaki need an underdrive unit, Axle ratios on a Disco are 3.54:1, 2.8 sport and Trooper 3.1 duty are 4.56:1. Running the stock Disco tranny and Tbox ratios should make it more than low enough even with 35 inch tyres. won't be a motorway flyer though, but should climb the side of a house with out to many issues. Err-in-doors might get a bit miffed with the tyre marks left on the brick work though.
I'm interested in the conversion, how you going to couple the engine and tranny together and what you doing to the rear prop due to the diff on the Fronty/trooper axle being in the centre while the disco diff is offset to the right hand side.
Appreciate the disco Tbox gives full time 4x4, will the front axle cope with continual drive?
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed May 06, 2015 1:37 pm
Yaki...I have an adapter plate here that came of a 2.8 engine that goes to a v8 manual gearbox...
As for underdrive, you can never have low enough gears!!! 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by oldham_matt on Thu May 07, 2015 9:38 pm
unfortunately put the beast up for sale :(
oldham_matt
Vehicle Name: font t tera
Modifications: BRC LPG (before I bought it)
2" (I THINK) SUSPENSION LIFT (before I bought it)
POWERFLOW STAINLESS EXHAUST (before I bought it)
4 X OBLONG SPOT LAMP LIGHT BAR (made and being fitted at weekend)
7 SEAT CONVERSION (very nearly done using swb seat)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu May 07, 2015 10:47 pm
Got round to replacing the filler pipe on the Explorer. Just as well really. Had to order the replacement part from the USA. Went out tonight to swap them and the old one fell off onto the floor when I tapped it with my finger.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Fri May 08, 2015 4:08 pm
:oops: ...um...a bit of shame to share!
I chased a BMW 118 :butt: and a little later an Audi A5 ... the look of fear on the Audi drivers face was nothing compared to the fear I felt as I braked coming up this or that junction but still it was fun keep forgetting there is a 3.2 under my right foot!! :lol:
Better to be late than to lie in state!
Fronty 'A' - 2.4 LWB - 5 speed. named: Godzilla (it was green!) ;-)
Fronty 'B' - v6 3.2 ltd - Silver LWB - 5 speed manual.
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri May 08, 2015 7:22 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri May 08, 2015 7:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Sat May 09, 2015 8:08 pm
Fitted new front brake pads
Fitted a new tow ball with more clearance so I can hitch the caravan with the d 3" drop plate attached
Fitted a new head unit with DAB
Fixed NSF fog lamp, new bulb and rewired the earth connection. Now it works!
Replaced 15A fuse after fixing the NSF fog lamp :lol:
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sun May 10, 2015 8:23 am
Waved goodby to my fronty as it went to its new home :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun May 10, 2015 5:11 pm
What's replacing it then rob?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun May 10, 2015 10:06 pm
Finished my Anderson Connector mod:
viewtopic.php?f=46&t=54771#p619068
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sun May 10, 2015 11:03 pm
Dan I have an Nissan X Trail for the minuet not a proper 4x4 but does the job
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon May 11, 2015 2:04 pm
Its a cool little car Robster....just needs a lift and some big muds!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Davey j on Thu May 14, 2015 10:40 pm
Finally replaced knackered cam belt tensioner, cam belt and a new serpentine idler. My reward? Exhaust pooed itself again.
Germany-sourced replacement went to go on tonight and the middle box pipe to Y piece is too short. Grinder out. Welder out. Box will be fitted tomorrow night instead :)
Davey j
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sat May 16, 2015 2:59 pm
Checked and repacked the front hub bearings, greased it up and checked the levels all ready for next weekends trip to the North Yorkshire lanes. Respooled the winch rope as well but hopefully we won't be needing that.
Regards
Stuart
Fatbaz
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat May 16, 2015 3:50 pm
Fitted circlips and shims to the front drive shafts so they don't slide in and out now. Also cleaned out the debrie from one of the manual locking hubs (bits of casting) while I was in there. Both manual hubs now cracked (top quality hubs from you know where) so I guess I'll be looking for some new ones.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ianoneill1981 on Sat May 16, 2015 5:51 pm
Changed my starter just to find my live seems to be earthing when battery connected back up. Look like ill have the joys of stripping that down again an other day
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Sun May 17, 2015 3:22 pm
Removed and refitted another diff on my Trooper for the tird time in as many weeks and seem to of finally resolved the clunking when pulling away and turning.
Also gave it a well deserved oil change and nipple grease.
Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
