Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Mar 01, 2015 12:04 am
Had the rear bumper I made for my LWB sand blasted and primered, will give it a few coats of satin black this week and then boot it on the SWB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 02, 2015 11:10 pm
Fitted my front propshaft transfer box end UJ on the Mk.II. Against all adds weather wise. Got it done but was frozen to the cor and soaking wet. Weather was fine when I started. Had to finish as I was across town at a friends. Feckin' bolts transfer box end are a nightmare to get to. Just above the gearbox cross member so cannot get a spanner onto it. Heads of the bolts are so close to the UJ yoke you can only get a socket onto it using black magic.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 02, 2015 11:13 pm
Wound up the torsion bars to just over 2 inches & tightened up one of the front wheel bearings then went and had the tracking done. It now feels like a new car after all the work it's had this weekend
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 02, 2015 11:27 pm
Coolio ... bet it feels like a wobbly one though.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Andytats Boss on Mon Mar 02, 2015 11:31 pm
Cor just a bit Neal, i get tipped about in it just going round corners and roundabouts lol
Andytats Boss
Vehicle Name: The pod
Modifications: It's a sleeper pod lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 02, 2015 11:49 pm
It is one of the main reasons why I went wider when I did all my lifts.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Davey j on Tue Mar 03, 2015 8:03 pm
Spent half an hour reassembling the auxillery pulley set up and serpentine belt after diagnosing knackered cam belt tensioner. I swore at it a bit. Huffed. Logged onto Rock Auto and proceded to try and suss which bits I need to fix the beast. Yesterday I dropped the engine oil and swapped it out with some 5w40 fully synthetic Gulf stuff courtesy of Opie Oils.
Went off on a tangent and searched out inlet manifold gasket, rocker cover gaskets, rear shock absorbers, etc. Probably all for the wrong car but at least I can navigate their (Rock Auto) site a bit quicker now. Naturally, if Vauxhall were reasonably priced I wouldn't have to do it but if you can buy a timing belt kit with water pump for £150 inc import duty and postage from America when it's £570+ from Vauxhall.........what can you do?!
Davey j
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Tue Mar 03, 2015 8:37 pm
Freed off two sized rear calipers, fit new rear pads nd passed it's MOT.
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Fixed serious oil leak,replaced cam cover gasket,front cam shaft seals,and did oil/filter change,seems to be leak free again :)
martinkettering
Modifications: 3" rear lift
2" front lift
Cb radio
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Mar 04, 2015 10:05 pm
Thought about removing the pile of junk out of the engine bay and dropping the 3.1 lump in.... Then made a brew and thought about it again :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 06, 2015 1:12 am
Swapped the drivers door lock barrel over for the one for the car, I also fixed the drivers side rear doors central locking as it wouldn't unlock. And then repaired the boots central locking motor by replacing one of its diodes as it wouldn't lock. Now all 5 doors lock and unlock as they should :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by R1chard on Fri Mar 06, 2015 8:27 pm
Today i gave the Frontera a 2 inch lift and made the wheels poke out a bit more than they used to
R1chard
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Mar 06, 2015 8:56 pm
Converted the Mk.II single speed intermittent wiper to a variable speed intermittent wiper.
Fitted a new exhaust tail pipe brand new of eblag 17 quid delivered free :)
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Sun Mar 08, 2015 8:29 pm
Washed it for the first time in 6 months.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Mar 08, 2015 9:44 pm
Painted the rear bumper
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Mar 09, 2015 11:27 pm
Put some more paint on the rear bumper
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 10, 2015 12:21 am
Gonna be more paint than bumper at this rate Yaki :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 10, 2015 12:25 am
This arrived today from down under:
So I took the old seized bonnet release cable off the Mk.I this evening before rain stopped play.
I wouldn't mind but it was quicker and cheaper to buy one from Australia Eblag and have it shipped from the opposite side of the world than through the dealer :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Mar 11, 2015 6:40 pm
Looked at it, considered attacking the tracking but then washed the cav. Haven't washed it since this time last year and my God had I forgotten what a metalic paint job looks like. Not bad for a 22year old ex-taxi work horse that's let's face it, has had nothing but abuse all its life. Despite all the break in damage on the doors, melted back bumper, slightly wrong coloured front wing where a taxi driver parked it in a ditch (I wasn't lieing about getting abuse all its life) it still shines up to an impressive level with nothing more than some turtle wax wash and wax and a bucket and sponge :)
All of which add to the sadness that it's time is probably nearly over come 15th of April when the mot man fails it on having a crack on the windscreen that's best part of a foot long :( and costing £120 for a new screen plus the other issues that are poking their nose in I don't think it's got long :'(
