Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Fri Dec 26, 2014 8:01 pm
Cleaned up the replacement fuel tank guard ready for a coat of paint later and fitting hopefully on sat. Last job for the MOT on Monday.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sat Dec 27, 2014 11:48 am
Toped up the antifreeze, cleaned out a blocked washer jet and checked the front wheel bearings. Hopefully laning tomorrow.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Dec 27, 2014 5:15 pm
O-no
Cut a hole in the boot floor so I can get at the fuel lines from the tank.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Dec 28, 2014 9:17 pm
Went laning :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Mon Dec 29, 2014 10:53 am
Went laning in the Peaks with Stuart (Fatbaz) and Bigcol, had an awesome day got very cold at the end though...
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Dec 29, 2014 10:03 pm
Fitted some new lights to the front of the car. :lol: :
Click on pic for the video
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Dec 29, 2014 10:32 pm
Took it to the local Turkish car wash to get all the mud washed off, they gave the roof a good going over with the jet wash and the moon roof no longer leaks :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Dec 30, 2014 8:44 am
Nice lights!!!! And well done yaki!!!!! :wave: :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Dec 30, 2014 7:55 pm
Well, O-no's MoT came and err went on Monday... :axe: followed by a quick trip to the local factors and getting the bits on order for the morning.
Today, after the bits were dropped off saw me...
Ripping off both the rear calipers and fitting new ones.
Stripping the rear disks off to get the mud out so I could have a fighting chance of adjusting the handbrake.
Re-wiring the front O/S sidelight after the stupid connectors to the lamp holder fell apart in my hand.
Securing the O/S headlight, seems the MoT tester fella isnt into wobbly headlights... That one (the headlight) ain't gonna wobble no more!
And finally, front N/S wheel bearing changed.
Made it to the MoT testing place for 14:30 and a re-test only to be told to come back for 16:00 so went for a little drive and, being mindfull that I had only put 10 litres in to the tank when I re-fitted it on Monday I figured I'd better put some more go further juice in.
On the way to the petrol station I found a small tree that had fallen down in the hedge, or rather the N/S door mirror found the ****** tree branch :thumbdown: New mirror glass arrives at the factors in the morning :thumbup:
Oh and the MoT, did it pass? Aye we got back there for 16:00 and was given a Pass Cert :party:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Dec 30, 2014 8:02 pm
Well done Frank!!!!! :clap:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Thu Jan 01, 2015 12:20 am
took it making on the way home from work, slipped off the land and smashed every thing on the left hand side oopps :evil:
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Thu Jan 01, 2015 12:20 pm
Picture of my new to me rock sliders on my trooper, didn't get to take a picture before using truck.......dooh
Clamped to chassis to as and when the sill needs attention they can be removed with a bit of jiggery pockery....
Loneranger
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Jan 01, 2015 6:00 pm
There great fella but i gotta say they would look better on my 2.2dti!!!!! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Thu Jan 01, 2015 6:31 pm
Get Manny to make some after all he made these..... :wink:
Loneranger
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Jan 01, 2015 7:31 pm
Truck
Replaced the N/S rear axle rubber bump stop or rather swept up the remains of the bump stop mounting bracket, said a few choice words and then fabricated another bracket, drilled and tapped a couple of holes for the bolts, welded it in place and then fitted the rubber bump stop.
Found a wee hole in the rear N/S sill.... Good job the migs still out!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Jan 03, 2015 6:49 pm
Drove it to Driftshire and got me one of these :)
Genuine Mk.I Isuzu Trooper Inclinometer. Told you I would have it one day Drifty ;)
Was nice to catch up and have a chin wag. Cheers buddy, and I will get Alison on the case asap.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Jan 05, 2015 1:18 am
Started on the 'wee list' the MOT fella handed me on Friday when Truck went in for a late MOT .... :axe:
1. N/S Front Wheel Bearing has excessive play - Adjusted (interestingly, the screws that secure the hub nut only moved by ONE hole once the 'slack' was removed, not much!).
2. O/S Front Wheel Bearing has excessive play - Adjusted (same amount of adjustment as the N/S).
3. O/S Front Anti-Roll Bar linkage has excessive play in a ball joint - Replaced (took two hours to change ffs!).
4. N/S Front Anti-Roll Bar linkage ball joint dust cover excessively damaged - Replaced (to be fair I'm not surprised considering the Truck spent most of 2014 on the Airfield and the building site that was the Tech and Domestic areas. This one only took ten mins to change!).
5. N/S Rear Anti-Roll Bar linkage rubber mounting deteriorated resulting in excessive movement - Removed, awaiting delivery of a new replacement.
6. O/S Rear Anti-Roll Bar linkage rubber mounting deteriorated resulting in excessive movement - Removed, awaiting delivery of a new replacement.
7. O/S Front Track Rod end ball joint has excessive play - ??? (can't find that one, the ball joints appear to be okay even when 'pressure' is applied via a 2ft bar) replacement Track Rod with ends ordered anyway.
8. N/S Front Upper Suspension Arm ball joint dust cover excessively deteriorated - Now loose and ready for replacement (as is the O/S one that he missed).
9. N/S Rear Anti-Roll Bar attachment bracket/mounting insecure - Removed, ready to go back on with new rubber mounting.
10. N/S Rear (front bush) Trailing Arm rubber bush bonding deteriorated resulting in excessive movement - 2 replacements (20 quid from Hughes Scrap Yard, Bicester came off a 97 2.5 LWB with 70k on the clock) sat in shed ready to go on (the originals will then be re-bushed and go on to O-No the ones coming off will also be re-bushed as spares).
Not much really for a 240k mileage truck once you get into it, shouldnt take long to sort once Milners get a grip with the courier and I manage to get the young one to stay in long enough to take the delivery the bits will be going on and the Truck back for a re-test.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Jan 07, 2015 8:17 pm
As it was dark and wet outside I decided to do my oil change at work in the warehouse at work before I even clocked out as I was getting paid :lol: :lol: :lol:
I now have oil pressure again :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Wed Jan 07, 2015 8:44 pm
I put a new Varta battery in my 2.5 . The other one came out of my old 2.3 and is still usable but has been lacking oomph in the cold weather.So its at least 6yrs old. When I made enquiries about a new one, I discovered that it is a 510 CCA (cold cranking amps the higher the number the longer it will turn an engine over for) and what the 2.5 should have is a 680. So for a bit more I got a 780. Quite a difference.I had always thought that it didn't seem to have quite enough go and that explains why. :)
jmc
