Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Dec 16, 2014 11:26 am
Most A's had viscous fans, x20se and x22xe had lecky ones. V6 B had a viscous fan, all the others had lecky ones....
All diesel poopers and montegays, and hornybiguns, had a bonnet scoop replacing the bellows on earlier models, to cool the TMDBBQ (top mounted disposable Bar-b-que!)....
Subaru Imprezza's also have bonnet scoop.............so if you see a smaller car with a scoop its probably a corsa or saxo...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Dec 16, 2014 12:47 pm
:butt: :butt: :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Dec 17, 2014 7:43 pm
Sorry Neal...couldnt resist...hope your feeling better mate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Dec 17, 2014 8:42 pm
Still coughing up blood. Have doctors appointment tomorrow.
Just to keep on topic .. used the truck to take me to A&E after doing the above Saturday morning. Then again to the doctors, followed by using it to the hospital again for x-rays and blood tests. :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Thu Dec 18, 2014 10:49 pm
Cured the leaking Moon Roof without resorting to silicone sealant, or glueing it shut with Tiger Seal..........
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Thu Dec 18, 2014 10:58 pm
Blanked off my EGR and now the old girl pulls like a train cant wait to drive it after I do the straight through exhaust that should free it up a little
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Dec 18, 2014 10:58 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Dec 18, 2014 11:03 pm
Finished off the exhaust centre section and fitted to the SWB. New rear tailpipe has arrived so this will need some tweaking to fit
Nipped up the rear top trailing arm bolts and cable tied rear axle breather and brake hoses
Painted drivers sill following the recent repairs, finished off the additional brackets for the rear bumper and painted these
Started looking at the front camber angles, since fitting the Calmini arms and BJ spacers it is way out
MOT is booked for Monday so no pressure
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Thu Dec 18, 2014 11:14 pm
jaybrian32
2" Body Lift
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Dec 18, 2014 11:43 pm
Groovy :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Dec 19, 2014 4:33 pm
Finished painting the rack. Looks pretty good with its smooth edges and matt black finish. Just got to let the paint harden before I start putting bits on it (spare wheel, lights and waffle boards) then it'll be ready to use in the new year :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Dec 19, 2014 5:16 pm
Looks good....will come in handy for carrying spare coolant for that VM under the hood! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 19, 2014 5:24 pm
I think you have it wrong Greg. The VM needs a constant supply of EML bulbs due to the over use ... its the 2.2 petrol that needs the coolant. If the VM needs additional coolant it just opens a valve and tops it up with oil from the sump ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Dec 19, 2014 6:05 pm
My mistake...The only thing that triggers limp mode more than a VM, is picturing your granny in a skimpy swimming cossy when in the heat of passion!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 19, 2014 9:45 pm
Pmsl :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Dec 20, 2014 12:48 am
Brakes bled
New bolts for ball joints and spacers
Filled with coolant hose split so cut back and ok now
Glow plugs done and checked volts -all good
Sealed airbox lid as its was sucking like a two bit wh**e
Number plate gaffa taped to bonnet
Checked rear axle breather, all clear so no choice but do the seal
Loads more to do but at least i can drive it again
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Dec 23, 2014 10:13 am
Took it for MOT yesterday and it passed :D :D
But on the way back it developed a nasty grinding noise from the front and I have just discovered the moon roof leaks big time :(
Jacked up the from this morning to find a front brake pad had disintegrated, off to pick up a new set
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Dec 23, 2014 10:11 pm
Ended up having to change the caliper as well as the pads, bit of damage to the piston, brakes bled and it is all back together.
Moon roof off and drying out, gonna give the seals a clean tomorrow, smear with vasaline, adjust the catches and refit.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Tue Dec 23, 2014 10:39 pm
With the help of my mate Bigcol finally got my sliders fitted to my trooper, pics to follow soon....
:dance:
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Fri Dec 26, 2014 4:53 pm
Loaded my recovery gear etc ready for Sundays outing
Cleaned the roof and seal on the moon roof ready for refitting tomorrow
