Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Fri Dec 12, 2014 8:56 am
I think he was after a how to for the heater matrix :lol: talking of witch it would be handy as the 2.8 needs a new one
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Dec 12, 2014 1:26 pm
there is a how to for an a series matrix somewhere guys but for some reason its not in the "how to" section !
edit - ive found it ;) -
viewtopic.php?f=41&t=37663
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Dec 12, 2014 8:33 pm
He has his uses :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Dec 13, 2014 12:04 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Dec 13, 2014 12:05 pm
I can get the dash out of A series in sub 5 mins.....refitting might take a while longer! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Dec 13, 2014 7:21 pm
- cam belt tensioned and everything put back together
- new water pump
- new v belts
- intercooler and pipes back on and reinforced with self amalgamating tape to stop them flexing under boost
- new radiator (gotta buy an electric fan as my idea to fit the 2.0 one didnt work as too wide and hits the fan pulley where viscous fan was)
- started on glow plugs but will be easier with a deep socket, what a tricky little job this is!
- new fuel filter
- noticed replacement copper brake line is weeping - boo hoo, try again!
running out of bits in the box - must be a good sign i am getting close to the end
cold stopped play......
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Dec 13, 2014 8:17 pm
That rear glowplug is easier with one of those knuckle joints ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Dec 13, 2014 8:29 pm
They can't be top difficult, given the speed at which you removed Sophie's glowplugs at Avalanche.
Got a new set to go in myself actually, starting the engine of a morning is becoming a little slow now
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Dec 13, 2014 10:04 pm
It is easier if you "adjust" the fuel lines to get to them. The back one on the Frontera is under the bulkhead in effect.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Dec 14, 2014 10:02 am
A dab of bluetak in the end of the socket helps to lift the glowplug out when fully loosened.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Dec 14, 2014 10:53 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Mon Dec 15, 2014 9:42 am
Thanks for heads up on fan Chris - what was reason for staying viscous in the end?
2much
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Mon Dec 15, 2014 9:44 am
And thanks Neal and Pete for glow plug tips. If i ever warm up again i might finish them off.
2much
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Dec 15, 2014 2:04 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Mon Dec 15, 2014 4:25 pm
can see the theory behind this certainly but imagine that in practice the reduction in cooling of air when at low speed would be limited (intercoolers are pretty small on fronty) and indeed whether this would actually increase power noticeably and whether it would be needed at low speed.
possibly the reduction in power would be offset by the increase in power by reducing engine drag from viscous fan?
trooper has different set up so doesn't get this "free cooling", don't think they suffer unduly?
anyone know what the 2.5tds set up is - electric or viscous fan?
2much
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by robbie on Mon Dec 15, 2014 5:01 pm
The 2.5 is viscous fan. You have to go aftermarket slimline. I even tried a B series 2.2i as they are twin fans but they are to wide for the rad/intercooler pipes
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Dec 16, 2014 12:27 am
IIRC the Top Mounted Intercooler on the trooper has an electric fan to pull air through ?
2.5 is viscous
TBH it was just my musing, there are slim leccy fans available that might do the job
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Dec 16, 2014 12:40 am
Found some spare time today so made a start on the exhaust
Made a flexi hose to go between the downpipe and centre box then discovered the downpipe would need to be shortened so the flanges on the flexi section cleared the crossmember, ho hum
Chopped up the centre box, rewelded the pipework, added a short piece of tube, added another flange and ended up with this
Before
Ready to fit (minus hangers)
Cut off the hangers off the chassis, turned upsidedown, repositioned and welded back onto the chassis then bent some round bar to make a bracket for the exhaust box at which point the regulator I recently bought to use a disposable argon bottle for stainless welding decided to disintergrate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Tue Dec 16, 2014 9:25 am
2much
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Dec 16, 2014 10:56 am
