Re: WHAT YOU DID TO YOUR TRUCK TODAY! by matt_mph on Thu Oct 23, 2014 8:19 pm
Refitted my off side torsion bar bolt
Removed the remains of my exhaust after it falling off
Refitted some wheel nuts as aft kindly only put 2 in per wheel lol.
Tomorrow will be time to strip the second frontera ready for cuttings muhaha
matt_mph
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Greekfronty on Thu Oct 23, 2014 9:27 pm
Fitted my daylights yesterday. What do you think?
Greekfronty
Modifications: New wheels Irmscher 17" on with 245/65 michelin tyres, xenon H.I.D. kit 6000K, K&N Air Filter,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by sirius on Fri Oct 24, 2014 8:54 am
Looks nice. I don't need daylight since I have to turn of position lights so my dash can work :eh:
2.2 DTI, y2001.
sirius
Skype Username: tokipufl
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fadpasser on Fri Oct 24, 2014 11:49 am
Another wheel stud broken.............removed spacers and binned............. :clap:
even a man who is pure at heart...........
Fadpasser
Vehicle Name: Mad Max
Modifications: 30ml wheelspacers
Blacked out rear windows
Wind deflectors
C.B.
Rear facing spot light
Vauxhall fitted roof lights
Bonnet bra
Front grill LED
Chrome spare wheel holder
Wood effect dash laminate
Kenwood ICE
Set of 4 Vauxhall spec roof bars
Replacement side steps
D-badged
Frontera dog guard
Chrome `Frontera` sills
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sat Oct 25, 2014 7:05 pm
Replaced the plastic plugs holding the headlights...
MOT (kind of as HAUPTUNTERSUCHUNG in Germany is a bit more tricky, bu is lasting for two years) follows on Tuesday. Hope they will accept the mounted Bodylift and accomplish my papers...
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Oct 25, 2014 7:58 pm
offside brake flexi hose replaced -gotta love those spring clips holding them in place - NOT!!
replaced brake lines with copper from master cylinder to front brakes-now running a single line to rear-rear end to do and remove bias valve assy.
egr pipe from exhaust removed with no problem after a good soak for 2 days in penetrating fluid :)
front all done now - noticed the near side upper ball joint bolts were loose :oops: so replaced bolts and re tightened
next,the rear end and then then engine stuff....
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Oct 26, 2014 10:32 pm
Painted the +4" springs that were fitted to my LWB a fetching shade of yellow ready to fit later this week
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Oct 26, 2014 10:42 pm
Put some more bits back on it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Oct 28, 2014 4:58 pm
Got abit further with the rack today. The main part of it is done, got all the light mounts on and the spare tyre mount. Just need to do the trays for the waffle boards and the tree/bush sliders down the sides (these'll be last so they don't get scratched to buggery) then some paint. Very pleased with it so far :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Wed Oct 29, 2014 9:04 pm
Kind regards,
JEOH
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Oct 30, 2014 8:35 am
Congratulations Ian!!!!! :clap:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Oct 30, 2014 10:14 pm
Well done Ian, ref conversions I got a 3.1 engine that needs a truck.... I just need a SWB to go with it ...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Nov 01, 2014 11:03 am
Nothing yet, was hoping to have spent loadsa time on it this week but with work and travelling have hardly been home, today however I will be in the garage until the wee hours cracking on with it, got a play day lined up next Sat and there is loads to do
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sat Nov 01, 2014 8:35 pm
I found out LWB bull bars dont fit SWB cars due to the to loop bit up bu the wings on the inside of the bull bar and the shape of the wings being different.......... So out come the angle grinder and the mussles I cut off the loops a bent the bar apart now it fits
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Nov 01, 2014 11:34 pm
+4" springs off my old LWB fitted, replaced rear top suspension arm, modified some Land Rover dislocation cones to fit Frontera coils, painted them yellow and fitted to the SWB.
Started removing the front axle, diff guard is off and the drivers side is stripped out, back on it tomorrow and hopefully have it wrapped up.
Job list seems to be going up not down, had to cut the bolt holding the axle to the chassis as the captive nut had broken free, snapped off 2 of the bolts that hold the diff guard to the chassis cross member so will need to sort out these as well :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jaybrian32 on Sun Nov 02, 2014 8:41 pm
New radiator and fresh antifreeze yesterday, new drivers door hinge today
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Nov 03, 2014 12:26 am
Another session and the old front axle is off, the 2 rear captive nuts decided to break free which caused me a major headache, fitted the front axle off my old LWB as it has a locker in it and a 35mm diff drop. Fitted my Calmini top arms, driveshafts, hubs, shocks, back on it again tomorrow
And I managed to slice open the top of my thumb with an angle grinder, serves me right for rushing :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Nov 03, 2014 11:47 pm
More spannering today
Fitted manual hubs, front calipers, flexi hoses, suspension crossmember, front propshaft. Replaced all metal brake pipes with copper and a good s/h brake block. Drilled out the split pins on the track rod ends and fitted them with the 2 new arms I had on the LWB
Drilled out and retapped one of the mountings for the front bash plate as the original one had snapped off
On a mission now, needs to be all done ready for playing on Saturday and there is still a shed load left to do
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Nov 04, 2014 12:19 am
No excuse's Chris, not with that set up you have mate. I think you should have to do the work out in the yard meself.... Tis even more fun when it's raining or snowing :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Tue Nov 04, 2014 12:20 am
Well done chris, you are working hard there!
Be good to see some updated pics soon.
What length are your rear shox? Bit surprised you needed cones with +4" springs!?
2much
