Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Oct 16, 2014 8:44 pm
Re giving O-no a right good clean on the Sunday....
Got to work Monday, to find I had to isolate an HV Cable between DSS S and DSS R, one of the Sub Stations (DSS 'S') was the wrong side of a newly finished dig area that had been covered in nice clingy top soil.... Said top soil now has Fronty Sized wheel tracks running across it for a couple of hundred mtrs towards and from the Sub Station :oops: .... O-no on the other hand looked like a happy hippo that had spent all day rolling around in a megga mud pit :lol:
Last time I clean that one before work... :axe:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Oct 18, 2014 9:23 am
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Oct 18, 2014 12:56 pm
Bought a car load of 1 inch square tubing to make my roof rack of out for the 2.5. Will post pictures as and when (hopefully doing it tomorrow and Monday). The plan is to have 4 lights accross the front, 2 work lights at the back, twin amber beacon and spare wheel mount on it. Oh and to have 2 slots for the waffle boards to hang under the load deck. Because of all the lights I'm thinking of running some heavy gauge cable upto the roof and having a relay box hidden under the spare wheel rather then running 4 separate feeds upto the roof
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Oct 18, 2014 9:04 pm
Not a damn thing even tho I have loads to do on my truck. But I did work on a discovery td5 ( please forgive me father for I have sinned ) had to replace the old power steering pipes for new ones. Now that was a bloody mission removing all the silly plastic engine covers then front grill so I could remove the radiators because the power steering pipes are fitted underneath them. And tomorrow I will be replacing the brakes on my daughter car so I still can't work on my truck :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Oct 18, 2014 9:09 pm
Got it running again after an incident with the new auxiliary fuel pump packing up! :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Oct 18, 2014 10:11 pm
Took the engine out to clean it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Oct 19, 2014 12:50 am
Welding
I knew it needed a repair to both sills, started on the drivers side today and a small patch has turned into a full inner and outer repair. Inner sill is done, on with the drivers side tomorrow
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sun Oct 19, 2014 4:19 am
Filled up the tank on the Pajero, 51,79Lt premium fuel. $117.00. Premium petrol is $2,26 a litre at my local BP.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Oct 19, 2014 7:52 am
Lucky bugger! £1.11 for your petrol. Were paying £1.27 for petrol ! :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sun Oct 19, 2014 8:26 am
Just to rub it in l will be enjoying summer again this year :D . I don't think that I will be missing the cold winters over there any more.
kees
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Oct 19, 2014 7:28 pm
Used three cans of spray gunk cleaning the engine, then stripped off all the chopped hoses. Moved all the required bits from the old engine over and put it into the truck.
Gear box next.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Oct 19, 2014 7:45 pm
You a busy boy Frank. :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sun Oct 19, 2014 8:48 pm
Got my LWB rear light conversion done
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Oct 19, 2014 10:45 pm
After Liam decided he was too tired to goto work today he came over and helped me with the rack. Started with alot of tape measuring and throwing ideals about. But after a couple of hours we had a good solid plan in our heads so we made a start on cutting up some metal and quickly made this:
And by dinner time we had got this far (about 3/4s done) before packing up for the night:
I'll have another crack at it tomorrow and hopefully get it to a point where it can be painted and mounted on the roof.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Oct 20, 2014 12:27 am
Aye Bobby. I had the forthcoming weather in mind too, seems that every time I do something to that ******* truck it's either raining like it's going out of fashion (clutch a couple of years ago). Snowing (rear axle). Storms (Gearbox / flywheel / clutch / lsd trooper axle) earlier this year.
Plus I'm currently using the 'spare' for work and need to to do something with the fuel tank holder (usual thing, more rust than steel) so Truck needs to be sorted asp.
Just need to connect stuff up now (fuel lines, electrics etc) and stick the gearbox back in too. Next weekend hopefully unless I get's voluntold to go shopping or summit more important than fixing me truck :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Oct 20, 2014 10:58 pm
Finished off drivers sill today and then cut off what was left of the drivers side rear bump stop mount and cleaned up the chassis. Made a new mount out of some angle ready to weld back on.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Soupstone on Tue Oct 21, 2014 2:31 pm
After being recovered by the AA yesterday, I removed the exhaust from the cat back to help prove the cats collapsed. Certainly looks like the LHS ones a gonner, AA guy seems to be spot on.
Soupstone
Registration Year: 2004/04
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by matt_mph on Tue Oct 21, 2014 7:00 pm
Fitted a battery and dug it out. Stripped the back seats out, rear roll bar and cleaned the inside to start turning it into a pick up. Still unsure what i'm going to do for the bulkhead yet tho :wtf:
matt_mph
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Oct 22, 2014 11:54 pm
Welded on the new drivers side bump stop after drilling holes in it and welding on some captive nuts
Cut off the passengers side bump stop, made a new one with captive nuts and welded that on too
Stripped off the lift springs, clamps and dislocation cones ready for the fitting of the +4" springs off my LWB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Thu Oct 23, 2014 10:57 am
Finally changed the starter motor - not an easy task!!
Nearside front wheel bearing replaced
Removed the rusted side step brackets
fitted egr blanking plates and started to free off the pipe from exhaust to egrs - slowly, slowly so I don't snap the bolts
near side front brake pipe replaced - cant find a supplier for new copper washers though...
loads more to do on list and an even bigger list for the house :roll:
2much
Users browsing this forum: No registered users and 53 guests
