Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sun Aug 31, 2014 2:11 pm
Just finished replacing both front drop links.
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sun Aug 31, 2014 5:55 pm
Finally got round to fitting my LED light bar and in the process somehow found out my 2.8 has central locking and a alarm :lol: not sure what I touched to make that work but it does now :lol:
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Aug 31, 2014 6:01 pm
That had central locking when I had it...LOL...and central unlocking...
I have a new solenoid that I bought for Sally's to put the tailigate on cental locking too somewhere...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Sep 01, 2014 5:17 pm
Broke it, now waiting for RAC to rock up and tow it home. Not 100% what's wrong with it. First thought was cam belt as there were sounds of something slapping on something before it died, it cut out at a roundabout as I was pulling off from a complete stop. On trying to restart the engine would not even turnover, almost as though it was seized solid. I have since checked the cam belt and it looks okay, but that was via the wee inspection hatch so have no idea of the belt teeth. Also I have managed to start it although it ran rough as a ...... And then stopped solid again so somethings going on that shouldnt be.
So at time of the original failure:
Oil pressure was ok
Coolant levels and temperature ok
The cam belt looks okay subject to further inspection....
Engine stopped and wouldnt turn over
Link to thread 2.8 4JB1 with more rattles than well a 2.8! here, anyone got any sensible ideas towards the problem?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Sep 01, 2014 6:10 pm
Please put techy stuff in a thread in the 2.8 section frank, as any responses will get lost in this thread...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Sep 01, 2014 11:16 pm
Sold my spare 2.8 engine, don't want to but with funds being low and a wedding to contribute towards it was a quick way of getting some cash (yes I know I am going to regret it someday soon)
So before it goes I need to relieve it of its exhaust manifold which has the tapping and adaptor for an EGT gauge, SWB is in the garage and the manifold is nearly off ready to swap onto the engine I've sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Sep 01, 2014 11:57 pm
Timing Chris.... timing :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Sep 03, 2014 12:36 pm
Last night I had a look at the 2.5 and why it wouldn't start on the starter and found that the battery terminal on the solenoid had broken off and was just hovering in mid air (hmmm might have something to do with it lol) pulled the started off and replaced the solenoid with a new one I had laying about (prime example of why hoarding is a good thing) wired up the factory start circuit and nothing, no clicks or anything. So I packed away and went to bed lol (about 3am)
Just got out of bed and tried to start it again and voila! She took a few turns of the key to work but now it seems to be working every time 1st time. Woop! Free fixes are the best! Well chuffed!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by DarrenH_2.2 on Wed Sep 03, 2014 4:57 pm
turned on heated wing mirrors
they worked 8)
DarrenH_2.2
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Sep 03, 2014 11:24 pm
Walked past it on the way to work this morning wondering how long it would take me to chop it up with the gas axe, then just kicked it (again) and trotted off to work in O-no pondering whether to fix or just replace the engine (or both)...
Stupid truck mutter... mutter.... mutter....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Sep 05, 2014 10:31 am
Cleaned my interior and fitted the new roof light switches!!! :clap: Now just got to wire it all together!!!! :thumbup:
I also fitted my dash camera kindly informed where to purchase by Dave1966. Thanks bud!!!! :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Fri Sep 05, 2014 4:09 pm
Were did you get them switchs I want some
mudman1988
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Fri Sep 05, 2014 6:08 pm
The switches look like Carling switches ... custom transfer labels though by the look of it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Sep 05, 2014 8:03 pm
Found a lovely patch of rust in rear passenger footwell where it meets the sill ....feel im rebuilding the bighorn rater than repairing
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Sep 05, 2014 9:10 pm
Here you go fellas!!! :thumbup: As requested if admin wish to remove I'm only doing as asked!!!!! :mrgreen:
http://www.ebay.co.uk/itm/390876364338? ... EBIDX%3AIT
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Sep 05, 2014 9:11 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Sep 05, 2014 10:56 pm
Wish me luck ED is booked in for his MOT at midday :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sat Sep 06, 2014 7:08 am
If it fails come for a drive and it may just pass :lol: :wink:
mudman1988
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Sat Sep 06, 2014 9:28 am
Good luck Andy and ED
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Sep 06, 2014 10:08 am
Good luck Andy!!!!!! :thumbup:
