Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Aug 15, 2014 2:27 pm
Dave...that tailgate I have wont fit your car mate...yours has the later tailgate with the upswept bit and curved glass, this one I have is straight on top. Sorry fella...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alsavs on Fri Aug 15, 2014 5:17 pm
Took it for its mot today and failed. A couple of things need sorting but it also requies some welding on all 4 corners due to structure corrosion that is within 30cm of the body mountings. Any advice would be helpful :(
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Aug 15, 2014 5:49 pm
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Aug 15, 2014 5:50 pm
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri Aug 15, 2014 6:14 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Aug 15, 2014 6:22 pm
I got a silver tailgate Dave if any use to you????? :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Fri Aug 15, 2014 6:25 pm
Better to be late than to lie in state!
Fronty 'A' - 2.4 LWB - 5 speed. named: Godzilla (it was green!) ;-)
Fronty 'B' - v6 3.2 ltd - Silver LWB - 5 speed manual.
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Aug 15, 2014 7:11 pm
My pleasure fella....Need anything else, give us a shout... :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alsavs on Fri Aug 15, 2014 7:38 pm
Alan.
alsavs
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Aug 16, 2014 1:32 am
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Aug 16, 2014 8:08 am
Your welcome Dave anything to help!!!!! :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Aug 16, 2014 10:40 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alsavs on Sat Aug 16, 2014 12:01 pm
Alan.
alsavs
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Aug 16, 2014 12:25 pm
It will be a case of making something up mate...just bend a piece of steel to the right shape and weld it over the top. Make sure you cut all the rot out and treat it before over plating though, or in a couple of years time your plate will fall off and the hole behind will then be the same size as your plate!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alsavs on Sat Aug 16, 2014 1:10 pm
Cheers for the info Greg :)
Alan.
alsavs
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Aug 16, 2014 7:09 pm
Today I fitted my new seats I got off ratcav.
I believe Those come from a nissan 300 ( Neal will conform this )
The drivers seat has 3 air bags in the back to support lumbar back & adjustable side wings
I had to modify the base so I could fit the runners from the original seats.
The 3 bottoms for the air bags & the wing adjuster
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stretch on Sat Aug 16, 2014 8:31 pm
Today I changed all the fuel lines on the DTI from the filter back but it hasn't made any difference grrrrrrr :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Aug 16, 2014 11:08 pm
New set of tyres onto Truck and the old ones from truck went onto O-no. Both trucks now have the same tyres fitted so should make things easier now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Sun Aug 17, 2014 12:20 pm
Fitted a replacement windscreen washer motor... and both ABS sensors, and now the dash has one less light glowing! hurra :dance:
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sun Aug 17, 2014 8:14 pm
Designed, made and fitted a rear dislocation kit on the 2.8 I'll try it out at the weekend'er hopefully I'll get some pics up tomorrow
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
