Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Mon Aug 04, 2014 9:51 am
Better to be late than to lie in state!
Fronty 'A' - 2.4 LWB - 5 speed. named: Godzilla (it was green!) ;-)
Fronty 'B' - v6 3.2 ltd - Silver LWB - 5 speed manual.
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Aug 04, 2014 11:30 am
Booked Brenda the Bighorn (Mk.II) in for her first MOT in our ownership. :? :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Aug 05, 2014 9:17 am
Dropped Brenda off for the MOT ... now for the wait.
Did the usual checks, plus last night I tightened up both front wheel bearings. Here is hoping.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Aug 05, 2014 1:25 pm
Failed :evil:
Rear fog light (forgot to check that one)
Steering tie rod end (they must of used a bigger whammy bar than mine)
All in all not a bad result considering I have no history on the car. Waiting for the call to go collect. after they fix it. Cannot be bothered to do it myself once I have gone out and got the parts, then back to fit them, then back to the station for a retest etc etc.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Aug 05, 2014 3:29 pm
If I was a betting man I would say welding ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Conian on Wed Aug 06, 2014 10:14 pm
finally got around to fitting a remote locking kit to my 2.8td
hardest part was feeding the wires through the door and dash board but now all done, awesome!
Conian
Vehicle Name: The Fronty / The truck
Modifications: Removed fluffy dice.
Skype Username: Conian944
Fitted my newly painted diff cover to replace my pourus one , no more rear end oil leak :) now to sort the one in the middle and the two at the front :oops:
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Aug 07, 2014 8:51 pm
Mounted the new CB and Antenna.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Aug 07, 2014 9:32 pm
Fitted new tyre's to my yellow peril!!!!!!! :D
Before!!!!Image
NOW!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Sun Aug 10, 2014 12:30 pm
Took a multi meter to the ABS sensors to see if all was well.
The off side failed... so that's one to renew. :evil:
Took a look at the near side see if all was well...
... I wonder who forgot to reconnect that when he was working in that Side...the other weekend...Vauxsqueeks...
Tested it anyway if failed... :thumbup: :twisted: :twisted:
So fitted a new number plate and ordered some sensors....
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sun Aug 10, 2014 5:24 pm
Replaced my rotten fule lines with a little help from gregsters fork lift
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Aug 10, 2014 8:57 pm
Got a Baaargain..... 5 brand new Kumho KL 71 - 31/1050 R15 tyres all for 395 beer tokens :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Aug 10, 2014 9:32 pm
Not today but yesterday.
Finally wired up my winch ( it's only been on the car for 7 months )
Then wired up the rear view camera & monitor
Plus made some wheel nut covers out of shot gun shells
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Thu Aug 14, 2014 4:31 pm
Adjusted the hand brake, fitted new number plate bulb, fitted replacement rear wiper motor.
Received two abs sensors ready for fitting.
Piad the boys for my bits.... :drink:
Yup you guessed it it's MOT time... :?
Going to be loads of fun doing the 'ruddy sensors... :twisted:
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ceriffwrdd on Thu Aug 14, 2014 8:00 pm
Put 2 new General Grabbers on the back axle and had one brake backing plate disintegrate.. oh well.
1999 2.2DTI Shorty
Ceriffwrdd
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Aug 15, 2014 2:51 am
I reversed into one of those stupid traffic bollards that is in car parks with our truck,the bollard came of worse as I took it completely out of the ground. :oops: :(
I know I will get stick for this. :)
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Aug 15, 2014 11:04 am
Any picys? :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Aug 15, 2014 11:31 am
Piccy's???? We want the video!!!! Daves car has more cameras than a BBC outside broadcast unit....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Aug 15, 2014 1:15 pm
Here is the pic from last night but got more this morning. :lol:
Sorry to disappoint you all but no video footage. :lol:
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Fri Aug 15, 2014 2:22 pm
Ok guys & gals,here are the picys from this morning:-
I had went to look at that stupid bollard and I thought I had taken it completely out of the ground but saddly it is still in the ground,as you can see from the picy. It was to dark to really see anything last night.
dave1966
Users browsing this forum: No registered users and 60 guests
