Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Jul 13, 2014 4:05 pm
Managed to put the farm jack under the back door and lift it, at least i can open the feckin thing now without climbing into the boot with a screw driver!!! :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Jul 13, 2014 11:17 pm
Primered the front wings, hopefully giving them a quick rub down tomorrow might and then squirt some colour on them
Refitted the roof console now that the wiring is finished
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Mon Jul 14, 2014 10:27 am
.. new brakes !
and ... the original airbox ! Hurra!
Better to be late than to lie in state!
Fronty 'A' - 2.4 LWB - 5 speed. named: Godzilla (it was green!) ;-)
Fronty 'B' - v6 3.2 ltd - Silver LWB - 5 speed manual.
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Jul 15, 2014 8:09 pm
Quick wet flat of the front wings and top coat is going on, not looking too fab at the mo as I'm using spray cans but its better than a 2 tone shorty and no doubt will soon get them nice n scratched :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Jul 16, 2014 11:01 pm
Bought more spray paint as yesterdays job is looking a bit patchy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Jul 16, 2014 11:45 pm
Truck:
Fixed this
Not the smartest of patches, but hey it works....
Just needs some paint now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Wed Jul 16, 2014 11:57 pm
Truck
Also, moved the winch bumper project on a bit. Now done the little bits of bumper leading to the wheel arch trim and welded in some plate to try and protect the body section below the headlight mounting that seemed a bit 'exposed'
Side bumper
Protective plate
Nearly finished, just a top bracing bar/spotlight mounting bar to make and fit and drill out the shackle mounts to 20mm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Jul 17, 2014 1:24 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Jul 18, 2014 9:57 pm
Blew the feckin turbo!!!!!!!!!!!!!!!!!!! :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Jul 23, 2014 7:25 am
Fitted another turbo and put on nut's & bolts that someone else bloody left off!!!! :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Wed Jul 23, 2014 7:20 pm
I did this yesterday. :lol:
Wired up my amber LED side marker lights on the side step there is a total of 60 amber LED's on each side step. 8)
How they look in the daylight:-
How they look at night:-
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Jul 24, 2014 10:54 am
Used it to drag the caravan down to Stoke Gabriel, Devon for weeks holiday. Tis well hot down here, off to find some more beaches in a bit. And no, Im not leaving it on the beach
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hawkmoon on Thu Jul 24, 2014 5:26 pm
Hawkmoon
Modifications: none
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu Jul 24, 2014 5:44 pm
Day off today so I've finally finished doing the wheels bearings lol only taken a week pmsl. Next up is crack on and finish off the bumper :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Aug 02, 2014 11:12 am
Mmm...
Was just about to go get the tools n bits from the shed and do a cam belt change on Truck followed by the front wheel bearings... I say was as the sky has just emptied a bucket of water over the town and it's still coming down!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Aug 02, 2014 7:44 pm
Took me phone (N8) to bits instead and replaced the main speaker, lot's n lots of very small bits lol... Amazingly I even got it back together again and it works :party:
Now for the truck as it's stopped raining :roll:
Bled up the complete brake system, had no brakes for twelve months. Did handbrake on monday night, this still needs adjusting. Balljoints next and check underside for rust, then mot first in 2 yrs, fingures will defo be crossed.
MARTIN FROM LLAN
Vehicle Name: STINKY
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Aug 02, 2014 10:05 pm
Good luck fella, i know how tence it can be!!!! :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sat Aug 02, 2014 10:10 pm
I gave the bank account a battering ordering shiny stuff for my truck to stop my springs falling out got a bit of bar to clamp my springs at the top a set of land rover dislocation cones witch will probably need a bit of fettling and a extended rear brake hose oh and a new tow bar I'm going to be busy before the weekend'er
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Aug 03, 2014 11:53 am
and this morning i take the duck out and then come back on a low loader
... screwed my front wheel bearing
