Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Smith3210 on Thu Jun 05, 2014 10:49 pm
It'll be fine just flutter your eyes and be ready to bend over. Or hope he has some dark glasses on :thumbup:
This can only end badly
Smith3210
Vehicle Name: APU
Modifications: muds
lift kit
rock/tree sliders
winch
winch bumper
Welded rear diff
Extra dents
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ianoneill1981 on Fri Jun 06, 2014 7:45 pm
blanked my egr seems to idle better but only done a couple of miles, lets hope it sorted now
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sat Jun 07, 2014 1:30 pm
Waved it good buy as someone else drove of in it. Going to miss it. Was going to look for an Isuzu Wizard or Mu but there is a good chance I might be getting Shogun V6 as soon as we land in New Zealand :dance: .
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudman1988 on Sat Jun 07, 2014 5:38 pm
Got mine MOT'ed
Good news and bad today,
Good news is my frontera passed it's mot with no advisories
Bad news is as the pass was being printed the radiator exploded so still more work to do before modifying can begin
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jun 07, 2014 6:23 pm
well today i took the duck for a quick trip out and started to bed in the new rear disc's..
and when i got home checked for brake fluid leak.. and non.. so all good
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jun 07, 2014 7:37 pm
Just done the tappits on Truck. They are now set to the spec 0.4mm rather than the 0.8/9mm that I found... Having never checked the tappits since I got the truck me thinks that a MINIMUM of 120,000 miles between checking them is bit excessive!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Sun Jun 08, 2014 11:51 am
Fitted a manual switch for the rad fans , the old girl got a little hot under the collar tackling liverpool yesterday !
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ksidza on Sun Jun 08, 2014 3:29 pm
lets face it!!! There is many things to do on me lady. but lack of time and money leads to taking her out as is.
sadly this was only pic that was any good:D
English wasnt my first language.
truck: viewtopic.php?f=46&t=57301
comments: viewtopic.php?f=115&t=57311
Ksidza
Registration Year: 1994/M
Vehicle Name: Tica
Modifications: Central locking, Build in USB charger, pain job, custom staring wheel, HId lights, LED roof lights, 2` lift, 31x10.5 AT, CBradio,....
Skype Username: jovan_pantelicc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Jun 08, 2014 6:30 pm
I'm not convinced you've quite got the hang of "camouflage" just yet :butt:
Looks nice though, i like the roof lights.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Jun 08, 2014 7:31 pm
Gave to car a coat of lacquer. Then as the carpets looked old and tired I spayed them black :lol: they don't look to bad now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Ksidza on Sun Jun 08, 2014 9:46 pm
If i wanted a camouflage i would turn the lights off :P
Ksidza
Vehicle Name: Tica
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Sun Jun 08, 2014 11:13 pm
Removed the scuttle tray so the metal can be de-rusted then made good and refitted. I took the opportunity to remove many years worth of leaves, twigs and other vegetation from the revealed void.
That's the problem when the weathers been bad and you watch Car SOS and other car renovation programmes - you want to get the hands grubby and join in.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Jun 09, 2014 8:11 am
yesterday afternoon i decided to treat the swan
so it now has new, cam belt, tensioner, water pump, oil, oil filter, air filter, and coolant.
should be happier now
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Mon Jun 09, 2014 9:00 pm
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jun 14, 2014 4:59 pm
Truck:
Replaced the Centre Tie Rod, the ball joint on the steering gear drop arm was well loose (I had something like 15 degrees free movement on the steering wheel, the truck almost tacked when going down the road). On the other hand the ball joint on the lazy drop arm appears to be siezed solid.
Pretty near mullered a 'light truck' strength ball joint splitter getting one of the outer tie rod ball joints off the centre tie rod, had to get the impact gun on it for a few mins before it split, the joint splitter bent in the process.
Fabricating the winch bumper while the trucks in bits too.'
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jun 14, 2014 6:28 pm
Removed the old green window tint then fitted a very dark black tint to the windows
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sat Jun 14, 2014 6:35 pm
Me and Audra put the dog in the back and went to the beach near penzance :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 14, 2014 7:12 pm
8) 8) 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Xplorer on Sat Jun 14, 2014 7:20 pm
just filled the truck up with 60ltrs of veggy at £8.00 for 10ltrs saving me 34quid :dance:
Xplorer
Vehicle Name: MadBull
Modifications: Isuzu Bighorn xs auto
TJM winch bumper,
285/75x16 BFG at2,
+2Bloodred spings on rear,
+2 OME Gas shocks
torsion bars raised,
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
Isuzu Trooper 3.0ltr citation
2001
7 seater auto
2inch spring spacers
torsion bars raised
265/75 x16 gen grabbers at2
chrome A bar
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sat Jun 14, 2014 9:01 pm
