Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Apr 26, 2014 11:34 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rippa2k on Mon Apr 28, 2014 3:39 pm
Installed new front carpet, replaced centre console and seats. Replaced auto window mechs on passenger and rear windows. New truck coming together nicely.
My friends call be Hadoken, because I'm Down Right Fierce
rippa2k
Vehicle Name: Metal Beefalo
Modifications: Big Ole AT's
2" lift.
Planned
Roof Light bar
Snorkle
Fitted new rear springs , well I say new I bought them for my last 2.5 that died a couple of years ago and they have been sat in the cupboard since it went to the scrappy in the sky :)
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Mon Apr 28, 2014 8:49 pm
Blanked off the egr !...now to see if it makes much difference
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Mon Apr 28, 2014 11:24 pm
Ignition key got difficult to turn in the ignition switchwhen I left work. Got it going and drove home, gave the ignition barrel a dose of WD40 and that cocked it right up. Stripped the covers off the column and managed to wriggle and fiddle with the key to turn it into the Aux position then poped the barrel out. The key and/or the slide plates must be worn as there was a lot of plate showing with the key in the barrel. fettled the plates down flush as they should be, clean it all up and reassembled. Works a treat, good for another 18 years. :D
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 29, 2014 7:49 am
Yesterday Horses45 brought his truck over for a simple brake change.
Yea right!!!!!!!!!!!! :evil: Changed all the disc's and the pads. Snapped the carrier bolts in the rear, that was clever. Had to drill them out. :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Apr 29, 2014 8:49 pm
I hammered apart my fairlead ready to unseize it, tomorrow I'll clean everything up
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue Apr 29, 2014 9:05 pm
Omg dan you have only just got round to doing that. I told you about 18 months ago that it needs sorting. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Tue Apr 29, 2014 9:10 pm
Lol yeah...I've had slightly more important things like replacing sills and body mounts etc to deal with little things like a fairlead :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by sirius on Tue Apr 29, 2014 9:58 pm
2.2 DTI, y2001.
sirius
Skype Username: tokipufl
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Apr 29, 2014 10:41 pm
Fixed an oil leak on the girlfriends Bighorn. Been getting steadily worse. After jet washing the underside (which took over half an hour to get through all the oily gack) I drove it around to allow it to bleed out. Turns out the oil pressure switch had undone itself. All back together and no more leaking.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Apr 30, 2014 11:49 am
Checked all the fluids on ED then loaded up the pod with the camping gear. We are already for the off at 6:30am :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Apr 30, 2014 6:27 pm
Last once over. Dryed the bits that should be dry and wetted the bits that should be wet. Loaded the boot with various tools and spares. Caravan all cleaned and prepped. Just clothes and stuff to pack then we're ready. First day back at work tomorrow after 7 weeks off with the ribs oh and last day before me holibobs hehe....well I don't wanna be overdoing it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Apr 30, 2014 7:37 pm
Ffs rob. You broke it already? ??
pot bellied pixie
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri May 02, 2014 5:39 am
Just got in from doing as much welding on my bumper as I can take, not to mention the welder lol. It's far from complete but it's much better than nothing lol. Going to bed now for a hour and a half stare at the ceiling then up at 7 to to find the tent and load the truck for bala stopping at Newmarket lol :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Fri May 02, 2014 6:01 am
i will pack my welder then..... dan.. you may need it
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by stretch on Fri May 02, 2014 7:51 pm
took the inlet off
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat May 03, 2014 10:11 pm
Yeah .. that needs a bit of a clean!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue May 06, 2014 5:14 pm
As my car stereo stopped working ( won't play CDs or DVDs ) I went out and bought one from halfords
Nice little bit of kit.with Dab radio & bluetooth for hands free and music streaming.
