Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue Apr 22, 2014 9:07 pm
Fitted my new wind deflectors they only cost £0 :D swapped a radiator fan for them
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by red5 on Tue Apr 22, 2014 9:12 pm
Fitted new shackle bushes to the 2.4. Aaah, back to normal bouncy/screeching on islands. Win. :-)
red5
Some dentage.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Apr 22, 2014 9:13 pm
I got 2 fans anyone else want swap something? Trucks looking good Andy!!!!! :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Apr 22, 2014 11:02 pm
Lost all steering :shock:
Fortunately was only doing 5 mph in a field, unlike the day before when I was doing 70 mph on the M1 with two other people in the truck :shock: :shock: :shock:
Turned out the retaining bolt that holds the column to the box had come undone enough to allow the column to just spin and not turn the box. Tightened it up and centered the steering wheel and all is fine.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Tue Apr 22, 2014 11:17 pm
found a rust hole :(
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by sirius on Wed Apr 23, 2014 9:08 am
Back light bulbs on my dash started to burn out, so I decided to replaced them with white LEDs. It turns out the final result is....blue... still looking nice.
http://imgur.com/Wpuhlwg
2.2 DTI, y2001.
sirius
Skype Username: tokipufl
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Apr 23, 2014 1:59 pm
Changed the rad on it for one that doesn't represent a clay paving slab and now it runs ever hotter :lolno: offs! After a 20 miles run and a small top up, the passenger side of the rad is hot but the drivers side is stone cold. I give up
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Apr 23, 2014 7:34 pm
Fitted new handbrake cables, sorted all the brake calipers out now. Sprayed the new bumper and mounts. Fitted the decals. Repositioned the tow electrics. Just need to get my roof rack then I'll be sorted for Wales
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Apr 23, 2014 8:04 pm
Ian don't forget the Passanger side roof rail still needs two bolts
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rippa2k on Thu Apr 24, 2014 5:33 pm
So today I bought a new truck!
Already installed some real seats and rear carpet, as it didn't have any.
Tomorrow replacing front carpet and adding a nudge bar and lights.
My friends call be Hadoken, because I'm Down Right Fierce
rippa2k
Vehicle Name: Metal Beefalo
Modifications: Big Ole AT's
2" lift.
Planned
Roof Light bar
Snorkle
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by steven on Thu Apr 24, 2014 8:34 pm
tinted rear windows limo black. looks good against the silver body work
steven
Registration Year: 2002/52
Vehicle Name: THE TRUCK
Modifications: DECAT STAINLESS STEEL RIGHT THROUGH TWIN PIPE ON END ,WIND DEFLECTORS, PRIVATE PLATE LIMO BLACK REAR TINTS,LED SIDE LIGHTS AND NUMBER PLATE LIGHTS.
ALL DASH LIGHTS IN LED WHITE.HID headlights 12v feed to boot with a power inverter. also fitted sub & amp.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Apr 24, 2014 8:46 pm
On ED
Recovered the headlining in black material and sprayed the A pillar cover + sunvisers with a plastic black paint. Looks much better then the off white
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ianoneill1981 on Fri Apr 25, 2014 5:55 pm
replaced a cv boot so as i can go play on sunday and mot due next week , should of looked at the hand brake whilst i was at it but that can be done tomorrow
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_4x4 on Fri Apr 25, 2014 9:15 pm
Took my spare set of alloys to have them dipped, blasted and re-powdercoted. Picking up next Friday and having the tyres swapped over. Hopefully will give the frontera a appearance lift.
Now saving for springs and dampers for that all important lift 8) we all need :shh: told the wife it is a critical mod that needs doing.
Have a good weekend all.
Dave
Dave_4x4
Model: 2.2i Sport Olympus 3dr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Apr 25, 2014 9:41 pm
Swapped the seats from mine into Manny's and his into mine! I now have a nice set of Recaros and the back seat's match aswell. :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fadpasser on Sat Apr 26, 2014 12:21 pm
even a man who is pure at heart...........
Fadpasser
Vehicle Name: Mad Max
Modifications: 30ml wheelspacers
Blacked out rear windows
Wind deflectors
C.B.
Rear facing spot light
Vauxhall fitted roof lights
Bonnet bra
Front grill LED
Chrome spare wheel holder
Wood effect dash laminate
Kenwood ICE
Set of 4 Vauxhall spec roof bars
Replacement side steps
D-badged
Frontera dog guard
Chrome `Frontera` sills
tried tyo get my engine out but the bloody oil sump is catching on the front axle, grrr.
how do i get the bugger out and back in??? do i have to take the gearbox out as well??
Team Fragglerock
Team Fragglerock
Vehicle Name: Das Boot
Modifications: 2" lift
31" tires
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Apr 26, 2014 6:22 pm
This is on Kaz the Fronty
New expansion tank ... hopefully that will stop the coolant loss.
New interior light .. now I can find things in the dark.
New door handle ... now I can unlock her without the risk of pushing the lock into the door and it falling out.
New front brake calipers and pads ... now I can stop .. oh no wait a minute. Effin thing won't bleed properly. Rock hard when engine off, soft as jelly when engine on. Might need a hand on this one and do it the 2 person method. :roll: :roll: :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Apr 26, 2014 10:16 pm
Mini Roundabout at the end of my road... Brake pedal hit floor (repeatably) :shock: Sort of rolled to a stop in the middle, put in reverse and SLOWLY reversed back up the road and into the yard....
Replaced split front/rear brake pipe. Need to bleed in morning before leaving with van for the Annual. Thank fe*k the caravan wasnt following me, it would have been 'interesting' ...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sat Apr 26, 2014 10:46 pm
Could have been worse. Could have been in the parking lot by Pets at Home. :wave:
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
