Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Mar 30, 2014 8:09 pm
lookin good bobby 8) 8) 8) ....and NO 8-track either.... :shock: :shock: :shock:
But I bet it took ages to trim all your fave 78's down to fit in the slot in that Kenwood!! :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Mar 30, 2014 8:14 pm
Your a sh1t Gregster, i will get my own back!!!!!! :wink: :butt:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Mar 30, 2014 9:10 pm
:lol: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 30, 2014 9:55 pm
Bobby, did that 8 track to PC cable work? It wont take long to get the tapes on to Disks :shh:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Mar 30, 2014 11:38 pm
I regreased the nearside bearing and reassembled it again, it's made next to no difference but the offside is the same so I'll just kick up a huge fuss if they try and fail it again. I also put my bfg muds on the front as they are much smoother on the road so shouldn't be kaining the bearings as much
Then I decided to 'fix' the shifters so I don't have to hold it in 2nd and 4th gear. All is well, I've had to bin the rubber boot because that just isn't going to fit anymore, but it reminds me of when I drove gregs old 2.8 lwb as to get 1st you have to almost punch the ashtray lol but it works and feels really good to drive :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Mar 31, 2014 7:57 am
You could allways get the gearstick cut and a small piece welded back in and change the angle slightly. I did it on one of my old cars!
Bobster. :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Mar 31, 2014 8:13 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Mar 31, 2014 10:12 am
Cheers for the offer but it's all sorted now. It's because it has a body lift on it the shifters where hitting the gearbox tunnel. So I cut and welded them but as a consequence 1st gear is in the ashtray lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Mar 31, 2014 10:36 am
Got ya, the quadrant wouldnt have solved that problem. I guess the only way is to extend and then bend the levers.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 31, 2014 10:44 am
Take the stick out .. notch it with a grinder .. bend it backwards a bit (trial fit to make sure its enough) then when your happy fill the notch with weld.
Don't do what Andytats did with mine where he took too much out and it snapped when he bent it to fit ;)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Mar 31, 2014 11:02 am
That's exactly how I did it :P I assume everyone else is having to ditch the rubber boot thing? I only have the leather bit stopping things from falling out of the car lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 31, 2014 12:07 pm
I flipped mine upside down, then put the leather gator on as normal.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 31, 2014 12:53 pm
You only need the bend the rear edge of the tunnel downward's then you can fit the rubber gaitor back on.
Or you can cut the rear edge back by 2cm then add 2cm to the front edge then refit the gaitor.
If you don't have the rubber gaitor fitted then you will get wet feet when you did the carwash in Wales
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Mar 31, 2014 1:26 pm
.. or the puddles of Thetford Forest :roll: :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Mar 31, 2014 5:32 pm
And so after a small argument with the bloke it now has a pass. They failed it telling me it sounded rough and you could feel some vibration through the top wishbone, but on the sheet he put down it had excessive play. So I argued that it doesn't have any play in it at all and the now I've regreased it it's no worse than the other side that was ok on Friday. Then he had the cheek to try and charge me for the retest. Anyways I walked out of there at no extra cost to me with a pass. This ginger gets nasty when angry lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Mar 31, 2014 5:39 pm
Nice one Dan!!!! :rotfl: :rotfl: :rotfl:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Mon Mar 31, 2014 5:58 pm
Taxed him. Now to see how he runs with his replacement turbo.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Mar 31, 2014 6:21 pm
Nice one Dan....finally managed to beat it through an MOT.... :dance: :dance: :dance:
Did you threaten the curse of the gingerness upon the tester??? :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Mar 31, 2014 7:51 pm
No Mate he told the MOT Tester that if he didn't pass it this time he was going to send his Greg Donk to pay him a visit!!!!!!!!!
Handy having a Greg Donk!!!!!!!!!!!! :mrgreen: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 31, 2014 8:04 pm
I reckon dan threatened to take off his trousers if the car didn't pass :lol:
