Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Thu Mar 27, 2014 5:12 pm
Started stripping the turbo off the tractor in prep for the replacement. Just waiting for the gaskets to arrive.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Thu Mar 27, 2014 8:21 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Mar 27, 2014 11:20 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 28, 2014 1:31 pm
It's in the hands of the mot tester as I type :S
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Mar 28, 2014 1:43 pm
Fingers crossed mate....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Fri Mar 28, 2014 1:47 pm
Im sure tha case of stella on the passenger seat will help :D
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 28, 2014 2:32 pm
Well it failed - on excessive play in the n/s/f bearing. Odd because it was fine 40 miles ago ffs. Different tester different problems eh
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 28, 2014 3:37 pm
Yeah that's all, this time around... I'll try and get it looked at and retested today but we'll see how it goes with time etc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Mar 28, 2014 5:04 pm
Started to install the CB so i will be back to a proper truck!!!!! :dance:
Passed the dreaded MOT just now ..only needed a ball joint a tyre ,some brake pipes and the anti roll bar bushes. :dance:
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Fri Mar 28, 2014 7:19 pm
He couldn't do it today so I'll regrease the bearings over the weekend and have it tested again next week. 4th time lucky eh! :roll: :axe: thing is he failed it for having excessive play but it has no play in it at all, it's just a bit rough and noisy, but because there wasn't anything to put down as a advisory he failed it. So I had a moan because it wasn't picked up before today and I didn't think there was anything wrong so he said he wont charge me for the retest, not the pass it should of got but better than the 1st time lol
Mine also failed on a sidelight bulb that was working.so I never touched that when it went back in .
pot bellied pixie
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Sat Mar 29, 2014 2:47 pm
Went for our MOT this morning, a mere formality, passed with no advisories again. Did do all balljoints and front hub bearings couple of weeks back. Happy days.
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sat Mar 29, 2014 4:37 pm
threw a damp sponge over and noticed theres a hole in the roof
:evil:
Gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Sat Mar 29, 2014 7:14 pm
Hound Dogs Tractor
Hound Dog
Missing In Action
Missing In Action
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Mar 29, 2014 8:25 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Mar 29, 2014 8:36 pm
Finally got the new (to Truck) 2.8 axle off that I put on last Dec and the new (to Truck) Trooper LSD Axle on (in-between going to work, shopping, taking eldest daughter to work and replacing the aerial on OiC HF's Volvo that youngest daughter managed to rip off going to work).
Jobs left to do...
Fit handbrake bits, disks, Brake Compensation bracket, rear calipers and brake lines. Bleed Brakes. Fit Propshafts, exhuast and gearbox/final drive bash plate. Oils to Gearbox, Transfer Box and rear Axle. Run breather pipes for the axle, gearbox and transfer box to the engine bay.
Tommorrow should just about do it. If it all works okay then I will do a 2" suspension lift and sort the winch out during the week.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Mar 30, 2014 11:20 am
Finished fitting the CB and the stereo out of my other truck. Just got the gauges to finish.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Mar 30, 2014 5:33 pm
Looks good Bobby
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Mar 30, 2014 6:35 pm
Thanks Frank! :thumbup:
