Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Mar 17, 2014 6:18 pm
The clue to a busted CV is lumps of metal and ball bearings fall out when you pull back the boot....my money is on the diff though, I have only ever bust CV's after I welded diffs up, meaning the CV's are normally stronger than the diff. I have not ever had a cv fail on an open diff, and you heard the racket the cv's on the BGL made for a year up the woods, and only then did one break after running with them with a locked front end for another year.
I wouldnt even disturb the cv boots before draining the front diff, and sticking a magnetic pic up tool in the hole and checking for teeth in the bottom, thats if teeth dont come out with the oil.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 17, 2014 6:40 pm
Ok cheers Greg I'll do that at the weekend
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Mar 18, 2014 11:55 pm
Got my new truck today.... :dance: :dance: :dance:
Big thanks to....
Dwifty for looking after it for all these years for me, and then selling it to me...finally we got it down here, sadly minus Dwifty though...
Stevey2stuck for going and picking it up for me and driving it down to kent...
and Bobby for hanging onto Yakis stuff for me so that Stevey could collect them today on the way back in the truck...
Its an iconic truck and is going to be a shame almost to prepare it for its new life...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Mar 19, 2014 12:59 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Wed Mar 19, 2014 1:01 am
Gave the D2 some attention, nearly finished a full service, just rear diff oil left, fixed the reversing lights and adjusted the fuel flap so it now closes flush with the body. Gave the interior a good clean and swapped the tyres around
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Mar 19, 2014 12:35 pm
Ive dropped the oil out of the front diff on ED there was some metal bits so I'm going to need a new one. It's a shame I'm not breaking the pickup up yet because I could of used the one off of that
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Mar 19, 2014 1:18 pm
Only 1 tooth.....bloody amateurs!!! :lol: :lol: :lol:
Told you it werent a CV :wink:
Probably went cos you use your front axle as a piggy bank mate, having coins rattling around in there aint gonna be good fella :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Wed Mar 19, 2014 3:42 pm
Finished the fabrication of the new front adornment and got it in primer. Did a dry fit yesterday,all I can say is it looks badass.
No photos as I haven't got the patience to do the photo bucket thing.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Yesterday I gave it a mini service of oil, filter, plugs etc and discovered that the bonnet catch had disintegrated.
Today replaced the front spot light that had also fallen apart. Removed the center box from the exhaust system as it was now more holes than metal to find that the mounts where shot as well. Called the local motor factors and no one seems to hold stock. :evil: So now got to wait until the mounts and gaskets arrive tomorrow before I can put it back together. :oh yer:
MG Autos (Mark)
Member & Trader
Registration Year: 1994/M
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Wed Mar 19, 2014 4:38 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Wed Mar 19, 2014 5:11 pm
Dan, you'll have to wait until May at the annual. Hopefully it'll be fitted together with the electrical bits in time for Wales.
We've rented the static van direct from Chris the site owner so our names (Pete and me and the motley crew) are not on the list.
Regards
Stuart
Fatbaz
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Mar 19, 2014 7:37 pm
As It was pointless taking the front diff until I can source a new one. I sorted out the leaking sunroof on the silver swb by replacing it with one out of the pickup. As I had the roof lining out i noticed it looked a bit tatty. So I PIMPED it by covering it with black material.
Fitted the new exhaust center box, refurbed the tail pipe and fitted all new mounts and gaskets so at least that's sorted before the MOT 8)
MG Autos (Mark)
Member & Trader
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Mar 20, 2014 5:55 pm
I bought a 1995 isuzu bighorn it was imported in 2005 . Its a 3.1td auto with rear lsd and T.O.D system . Collected from west yorkshire for 500 scottish pounds .
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Thu Mar 20, 2014 10:23 pm
Finished the service on the Disco, gave it a wash and fitted some new centre caps to the wheels as I managed to lose 2 somewhere
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Mar 21, 2014 8:38 am
And now your gonna sell it !!!!!!!!!!!! :D :wave:
I have fitted the Bulldog plate and tidy'd up the towbar! All working now ready for The Annual Meet!!! :dance:
Sorted the Bonnet Catch (Thanks Bobby 8) ) changed the clutch fluid and bled the system then nipped up the front wheel bearings so hopefully it's all ready for it's MOT :dance:
MG Autos (Mark)
Member & Trader
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Mar 21, 2014 5:58 pm
So you managed to sort that spring then mate? :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by taylor6632 on Fri Mar 21, 2014 11:15 pm
sat next to it in laybys and grass verges across south dorset cursing and kicking it everytime it got starved of fuel. Also considered dumping it somewhere and burning the piece of stool.
taylor6632
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Mar 22, 2014 5:11 pm
Just sheared 2 bolts off putting the clutch pressure plate on :oops: Could do without that!
