Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Mar 10, 2014 8:58 pm
This is all correct Frank however i aint putting any holes in me roof for anything this time! Its staying nice!!!!!!!!! :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Mon Mar 10, 2014 10:44 pm
I had my aerial there on my Sportrak for years with no transmitting problems.
It may knock the back window now and again if you catch the aerial on low branches though.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Mar 10, 2014 10:46 pm
Centre of the roof is the best location, might be OK for your off road toy but not a shiny :wink:
Facing a similar dilema with the D2, want to put it in the centre of the roof but there is no way I am drilling a hole in it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Mon Mar 10, 2014 10:47 pm
Started swapping out the LSD on the SWB for my Aussie locker :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Mon Mar 10, 2014 11:32 pm
Same with my truck. Middle of the roof night be best, but it's installed on the spare carrier on the tailgate.
No way that car is ending up with any more holes in the bodywork than it left Luton with in the first place.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Mar 11, 2014 12:12 am
A Series, LWB has a nice wee plastic cover thing near the roof edge above the rear pillar on each side. Access to the studs and nuts holding it in place can be gained by removing the trim underneath it and easing the roof lining to one side.
Makes a reasonable place for mounting an antenna, if replaced with a small metal adaptable box it would also make a reasonable place to bring all sorts of leccy stuff to the roof area.
For what it's worth I've fitted the CB Antenna on Truck there and have in the past been able to 'talk' to a couple of users based in Swindon who were using base stations while I was sat on a hill just outside of Brize Norton with a simple short whip antenna on.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BIGMIKE1 on Tue Mar 11, 2014 11:24 pm
Fingers crossed I've permanently repaired my B series dash, been ok for 5 miles so far tonight! Write up to follow incl pictures but mine had previously been apart and somebody had badly tried to solder up the connection strip and broke one of the stepper motors, I did initially try to solder every dry joint and managed to repair the stepper motor and this did get the dash working a lot of the time but not 100% some dials juddered so tonight I replaced all 4 stepper motors with brand new ones from china and added a couple of flying wires to bypass tracks on the board I wasn't happy with and so far so good :D
BIGMIKE1
Modifications: Trooper HD Springs, 245/75R16 Muds, rear axle breather extended to engine bay, HID's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Mar 12, 2014 1:07 pm
Mine is IN the boot :D
Was working fine until the handset decieded to break a wire.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Powderfan on Thu Mar 13, 2014 7:23 pm
Drilled out two of the 3 sheered off bolts for the back seat. Took the tip off the drill bit so decided to call it a day and grind it tomorrow. Tapped out the two holes plus the one that I managed to get the bolt out of so at least the seat is secured 3/4s.
Might tackle the final bolt tomorrow and maybe the passenger mirror.
My cooling fan switch arrived today so at the weekend I will get some antifreeze and a thermostat. Then hopefully the temperature gauge will rise to normal and the fan will cut in and out as intended. Then the front bumper will become urgent to gain the clearance between the fan and the damaged bumper
Powderfan
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Mar 13, 2014 7:39 pm
Fitted my new mud tyres insa turbo special tracks 265/75/16r now ED sits a good 6 inches higher than the standard frontera.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Mar 13, 2014 8:37 pm
Took Betsy down to Manny at the garage to have a new rear wheel bearing fitted. Turned out that the caliper was sticking on a bent slide bolt. Phew not as costly after all !! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Thu Mar 13, 2014 11:05 pm
LWB light conversion
fitted front bumper
flushed the oil twice
attempted to replace the hego sensor
replaced rear brake discs and pads
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by ianoneill1981 on Thu Mar 13, 2014 11:37 pm
finished painting my back door and tackled the sills, only surface rust thankfully no welding needed :thumbup:
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Xplorer on Sat Mar 15, 2014 10:52 pm
finally got the right drive shaft and fitted it roll on Wales :dance:
Xplorer
Vehicle Name: MadBull
Modifications: Isuzu Bighorn xs auto
TJM winch bumper,
285/75x16 BFG at2,
+2Bloodred spings on rear,
+2 OME Gas shocks
torsion bars raised,
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
Isuzu Trooper 3.0ltr citation
2001
7 seater auto
2inch spring spacers
torsion bars raised
265/75 x16 gen grabbers at2
chrome A bar
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Sat Mar 15, 2014 11:25 pm
Drove it to the DIY market to get a new lamp.
After a short while another ride to get a new drill to put the bloody lamp on the f****** ceiling.
At least, enjoyed the ride with the Frontera as this day's highlight - again!
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sun Mar 16, 2014 1:31 pm
Dragged the lwb to the breakers and drove the swb to the test station
Gazeddy
Fitted new pads and new to me carrier(thanks Drifty) after hacking off the old carrier also replaced the slider pins on one side 5 finger discount from a scrappies :shh:
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Mar 16, 2014 5:49 pm
:thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Mar 16, 2014 7:57 pm
This weekend I have
Finished fitted the rear locker into the SWB
Rear LSD from the SWB was collected by Snapper along with a Trooper solid flywheel and clutch kit
Finished stripping the LWB chassis of all its useful bits so its off to the scrap yard tomorrow
Had a good sort out and I can now get the SWB back in the garage :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Mar 17, 2014 5:57 pm
Had a quick look at the c.v joints on the green one but can't tell which one has gone or even if it's the front diff that's knackered confused.com lol
