Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Fri Feb 07, 2014 7:12 pm
Do they take vehicles with tyres on Bobby ?
We have to remove before entering the site down our way.
Today I fitted some of these http://www.ebay.co.uk/itm/261172352559? ... 1439.l2649 to the rear of my truck for reversing lights, my original reversing lights have been changed to indicators due to rear bumper being removed.
Will try and add some pics tomorrow.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Feb 07, 2014 7:14 pm
Yes mate they do but i wanted the alloys for me new tyres! :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Feb 08, 2014 4:22 pm
Well today I made the mounting bracket for the gearbox hoist. Which is going to make it easier to lower & lift the gearbox back in when we fit the new clutch next weekend.
( once it has the weight of the gearbox it will level out)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Feb 08, 2014 4:31 pm
I like the idea Andy, but you might find a small lifting beam like below a bit more flexible esp if matched to the electric winch you have there instead of the hand jobby I used as it will still allow you to open the doors, no risk of mullering the window seals and if outside you can still secure the car if you don't finish the job in time (or it rains...)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Feb 08, 2014 4:38 pm
Yea that does look like a better idea :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Feb 08, 2014 5:03 pm
I got the bits from B&Q, material wise (steel) IIRC no more than 20 quid, the bolts I already had along with some nylock nuts.
Length wise, it ran from the dash to just behind the rear seats, height wise as seen. Two sets of legs, one each end as seen.
For the legs I bought 2 lengths of steel box section (1.5mtr lengths IIRC) then cut them in half to get 4 equal lengths.
For the beam I bought a 1 mtr length of rectangular box section (I would use the biggest section that they do)
Taking all the legs together I stuck them all into a vice (about 80mm in the vice) with them sticking up and pulled them back gently to get the bend in them by doing it this way you can easily make sure that the bend is equal on all legs.
Then, two legs at a time and the beam I lined it all up in the vice and drilled thru for the bolts to hold it all together.
Just a case then of bolting it all up and doing the gearbox.
How would I improve it??? A Stronger beam for a start hence why I said use the biggest in cross section that B&Q do, I originally didnt and used the next one down, it worked great but would have worked better with the bigger on. Another thing I would do is put tubes through where the bolts go just to improve things and make it more durable to put up and take down without getting over confident and crushing it when the nuts and bolts get done up to much. A bit of bracing on the legs wouldnt go a miss either for longevity although I managed to do the clutch on Truck okay without it.
I would offer to put it in the post to you, but it got 'chopped' up to make the light bar currently sat on Truck!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Feb 08, 2014 5:54 pm
well today i was trying to get some fan belts... and no where seamed to stock them....
and i made a plaster cast of some of the swan...
reanson and pic's to follow if it works
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Feb 10, 2014 1:19 am
Well today I made a start on the mot list. I sorted out the offside front body mount, made a start on the offside center body mount rust hole just behind the front seat. And I fitted the missing rear body mounts pucks.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sun Feb 16, 2014 12:18 pm
Today i fitted me new second hand steering wheel. Was easier than i thought!! :mrgreen:
I also fitted me 32mm billit spacer's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Marty on Sun Feb 16, 2014 12:32 pm
Started making a list of things needing done to the Fronty I bought on Friday..
12 issues so far, 5-6 kinda urgent and serious so I think todays job will be working out why the rear brakes are binding and how far gone the bearing and droplink is gone at the front.
Joys :lol:
2.5 TDS SanDiego
Marty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Feb 16, 2014 10:01 pm
Tried to fix my Cherokee 2.5TD, it feels like it has kangaroo petrol (even though its a diesel), new fuel filter and flushed out the tank, checked over all engine loom connectors, cleaned with contact cleaner and reassembled, opened up the ECU and that was dry inside, cleaned MAF sensor contacts, checked for wet air filter etc etc and still no improvement :cry:
Stripped some more parts off the 2.8 and met a very nice lad from Cardiff who came to pickup some bits to fix his 2.5TDS after denting the front against some traffic lights
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Xplorer on Sun Feb 16, 2014 10:56 pm
Found out why my 4 wheel drive wasn't working, broken CV joint, :oh yer:
So I could only replace the trak rod arms with my new HD custom made 1s and new bottom ball joints on the drivers side ( also flipped the top ball joint whilst it was all in bits) Not much point in doing the passenger side only to have to strip it again to do the CV joint.
Xplorer
Vehicle Name: MadBull
Modifications: Isuzu Bighorn xs auto
TJM winch bumper,
285/75x16 BFG at2,
+2Bloodred spings on rear,
+2 OME Gas shocks
torsion bars raised,
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
Isuzu Trooper 3.0ltr citation
2001
7 seater auto
2inch spring spacers
torsion bars raised
265/75 x16 gen grabbers at2
chrome A bar
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by geeks on Mon Feb 17, 2014 11:40 am
Not today but the weekend. Swapped the interior from the 3.2 to the 2.2, now has full heated leather. Fitted my Bury bluetooth kit and my stereo and my sub! Dropped coolant, was going to change cambelt and water pump but the light was beggining to fade so we just inspected the belt with looked fine for now and changed the thermostat, filled it back up with fresh coolant and with some telephone assistance from Vauxsqueeks got it bled and found the temp sendor and made sure the fans were firing up.
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Feb 17, 2014 1:07 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Mon Feb 17, 2014 5:27 pm
I'm slowly getting through the list of mot fails. Just got offside inner sill to weld up and a tie rod end when the currect part arrives. Then got to aline the headlights and replace the number plate bulb then it's all done :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Xplorer on Mon Feb 17, 2014 9:21 pm
Xplorer
TJM winch bumper,
285/75x16 BFG at2,
+2 OME Gas shocks
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
2001
7 seater auto
torsion bars raised
chrome A bar
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by storesafe on Thu Feb 20, 2014 1:34 pm
Fixed the non working four wheel drive - bulb on the back of the dash, honestly!
:shock: :?:
http://s1122.photobucket.com/albums/l53 ... e149-2.jpg" onclick="window.open(this.href);return false;
Swillin' ale
storesafe
Registration Year: 2002/52
Vehicle Name: Gobbler
Modifications: New gauges fitted where crappy multi display was.
2" Suspension lift
Poly bushes all round
New Rough country shocks to front
Trooper springs on rear
Full Ice change
Olympus half leather interior
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Marty on Thu Feb 20, 2014 1:54 pm
Was about to start work.. then realised I don't have the locking wheel nut key :(
2.5 TDS SanDiego
Marty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Feb 20, 2014 2:08 pm
Wish I had time to work on the trucks/pod but at the moment I'm going to work in the dark and coming home in the dark :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Feb 20, 2014 7:12 pm
Started to replace the tow sockets, so far so good! Maybe tomorrow i will replace the caravan socket !
