Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun Nov 10, 2013 5:21 pm
Now you just need a AA style beacon on the roof (the ones with tail lights on as well) and it'll look pukka!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Nov 11, 2013 8:31 pm
today i picked up my other car... pic when it is light.. but it has a v6 :twisted:
and here is some pic's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Nov 12, 2013 7:14 pm
Nothing with the Frontera and just the usual with my other truck :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Nov 13, 2013 1:08 pm
Its rough up North Drfity ... by the time you took the second photo someone has nicked two of them :shock: :shock: :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Wed Nov 13, 2013 1:22 pm
Treated it to a set of new tyres.
Kumho KL71's muds 285 75 16's.......
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Fri Nov 15, 2013 1:34 pm
Couldnt handle the peace and quiet of not having a 2.8 on the road....so bought a 2.8 shorty as my new scud about! 8) 8) 8) 8)
Yesterday
Changed the oil, greased the rear for mech. my son struggled to open the door.
Today put the 2" springs in, only gave me about 30 mm more might have to change the shocks as well.
On the list for soon.
Team Fragglerock
Registration Year: 2002/52
Vehicle Name: Das Boot
Modifications: 2" lift
31" tires
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Nov 17, 2013 12:07 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Nov 17, 2013 12:18 am
Stu, have you not seen the pictures of the Duck?
It's got a full external cage, and the back section is on hinges with jerrycan storage on. You can see bits of the cage there.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by merlinlee10 on Sun Nov 17, 2013 4:20 pm
Today ive had semi success with the dreaded dash probs ive stripped dash pod and re tinned the connectors and tried to find any dry joints atleast I now have a speedo that works just the fuel gauge that reads full all the time to go :) :D and ive had no luck with the central locking on the tailgate although all rods are in place and it makes the noises it dont lock and I can smell antifreeze in the car so im guessing heater matrix is on the list at some time........ ahhhh the joys of motoring :roll:
merlinlee10
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Sun Nov 17, 2013 5:21 pm
New fuel filter and replace throttle position sensor ( again )
Replace snapped crossmember on the wife's pug ! Not a bad days work !
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrTom on Sun Nov 17, 2013 7:05 pm
Ok not today but yesterday I
Fitted new wheel bearings
Fittend new AVM hubs
Fitted new Lambda sensor --- which was a ****
Shortend my winch cable
Fixed a leak in my exhaust
Changed powersteering fluid
Fitted new NGK plugs
Fixed a leak in my dads 2.2 dti brake compensation valve
Grafted my balls off but the cold has well and truly gone through me now though. Still freezing with the heating on full blast :thumbdown:
My EML light is still on :evil: so Colley has reccomended resetting it and I have a new windscreen washer motor as mines still playing up and we all know how sh!tty things can get out laneing. :wink:
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Sun Nov 17, 2013 7:15 pm
Yesterday i decided i best return to the world after months of excessive work, so i pulled the tarp of my trucks n stuck a battery on the 2.5 and fired her up..............first turn and no smoke at all, not bad to say its been covered since i went to the lakes with Steved n Trev(countryest). 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Nov 17, 2013 7:26 pm
Got the shorty muddy in Kent :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Nov 17, 2013 8:33 pm
took it to kent..
and now have a set of 33" mud tyres
and collected my rear winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Top drive on Sun Nov 17, 2013 9:49 pm
Dropped it off for its annual ridicule.
Wont pass but its a case of how many pages will the fail sheet be.
Hasa duff fog light - didnt have any bulbs that fitted around and no power at the screenwash pump + engine management light on at idle- which i think is a vacumn leak.
Its gone to my friendly ( family friend)garage so no doubt he will stick it in for test then laugh like hell....while rubbing his hands together.
Top drive
Vehicle Name: Redneck
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Nov 18, 2013 5:38 pm
today i got some pic's of the new tyres 8)
does look much better :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Nov 19, 2013 10:02 pm
Well today i bought a new battery from halfrauds because i needed one quick. Then i managed to remove the oil cooler and found that the rubber gasket had failed. Then i find the thermostat housing was busted so a new one orderd £57 blooming quid. :eh: Then i find the rear hose to the cooler is about as thick as a bloody rubber glove. Its perished big time and its the one that goes to the rear of the block so the feckin worst one to get at!!!! What else is this little beast going to throw at me???? :roll:
New brake pads al round and new discs on the back axle.
Team Fragglerock
31" tires
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Nov 20, 2013 5:00 pm
Didn't do anything to the truck but took a leaf out of gregs redneck bible and bought 20 hockey pucks to be used as body lift pucks :D for the shorty just have to source the bolts now
