Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Oct 26, 2013 6:43 pm
I was bought a set of those for a birthday and there fantastic, the harder you turn the tighter they grip! :lol:
Yep mine are irwin aswell.!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Top drive on Sun Oct 27, 2013 4:35 pm
Got the irwin version of them they good :)
Today i dropped the oil and switched the filter + new air filter - lot more throttle response now. Sometime between march and now the air filter got barkit ! Also fitted new oil pressure sensor. Hasnt solved the eml at start up ( goes away when you rev it a little )
Not done the fuel filter yet - still got the memorys of the last fight with it !
At the moment im going round the truck snapping the body mount bolts with a 3 ft breaker bar to get the body lift fitted :)
Top drive
Vehicle Name: Redneck
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Oct 27, 2013 5:07 pm
Removed the Bull Bar from Truck ages ago with the intention of getting the plastic stuff off and the rust sorted before it becomes a real issue. Finally got all the plastic off it yesterday and ready for painting.
Came into the house for a quick brew before hitting it with the hammerite only to get called out by one of the on call engineers. Seems someone had put a temp LTHW boiler in on a site to run the district heating main while the MTHW boilers were being changed (DH Main is LTHW) but they had left the pressure unit set to 4bar and has so far split 8 rads over 2 days... With the last two to go the engineer couldnt isolate them so they had a couple of accomodation blocks reseambling swimming pools. Problem was sorted at 01:30 and home for 03:00 :yawn:
Now just finished painting the Bull Bars and hopefully will get them on the truck tonight when dry. Im fed up driving without the spots and with the weather coming up having the metalwork back up front may be handy!
Fitted a replacement battery, remote fob casing, headlamp & door mirror. They where the easy bits. Sadly the rest of it's not quite so simple :roll:
MG Autos (Mark)
Member & Trader
Registration Year: 1994/M
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Oct 27, 2013 6:18 pm
Nothing :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun Oct 27, 2013 6:33 pm
Checked the air pressures on both cars and put some fuel in the swb
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Top drive on Sun Oct 27, 2013 10:56 pm
Resorted to the grinder for 4 our of 8 bolts on rednecks lift.
Need to reposition the bumpers now.... Tempting to rip the rear one off and fit a box section replacement.
So much for a cheap car hahahhaha - spent more time on this crapbox than on my landy. Looking the mutts nuts tonight though. Taking my mate to work the morn - should be funny to see his face when i turn up in this. Its about 8 inches taller than last time i picked him up.
Top drive
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Oct 28, 2013 1:03 am
Got the Bullbars and spots back on Truck.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Oct 28, 2013 8:17 am
A lovely drive back from Preston yesterday in the Trooper. My god the power difference between the 2.8 and the 2.3 is HUGE!!!!!
I could actually accelerate up hills .. in fact I just stuck to 70 on the M'way and she stayed there, as opposed to having to drop down through the gears and crawling at 35 mph going up the M62 summit for example. Being able to overtake asthmatic sloths is a major advantage as well.
Oh and the heat ... the beautiful heat. I dunno what it is but the Frontera just doesn't seem to be able to get any kind of inside hot air, and the Trooper (even with a 2.8) gets so nice and toasty.
I love my Trooper :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Tue Oct 29, 2013 6:47 pm
Went down to me new truck that wouldn't start and thretened her with a jump from a tractor battery! Its amazin how quick she feckin started tonight. Its a shame that the tractor battery wont fit under the bonnet! :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Tue Oct 29, 2013 9:20 pm
well bobby i think with a welder anything will fit :twisted:
i used to have a 110ah mini bus battrey in my old red one
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Xplorer on Tue Oct 29, 2013 9:28 pm
got some Rock Sliders made and fitted thanks to Chris Blake of Humber 4x4
got their first outing 12hrs later at KROC, took quite a bashing to 8)
Xplorer
Vehicle Name: MadBull
Modifications: Isuzu Bighorn xs auto
TJM winch bumper,
285/75x16 BFG at2,
+2Bloodred spings on rear,
+2 OME Gas shocks
torsion bars raised,
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
Isuzu Trooper 3.0ltr citation
2001
7 seater auto
2inch spring spacers
torsion bars raised
265/75 x16 gen grabbers at2
chrome A bar
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Oct 29, 2013 9:36 pm
Broke the N/S door mirror :cry: I really must stop driving in the hedge when going down lanes!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Oct 30, 2013 7:52 pm
and this week i got my new heat resistant paint so painted the rear callipers and i am happy with this colour,
second time lucky
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Oct 30, 2013 9:37 pm
Well i have just got back from dropping off my new truck ready for MOT tomorrow morning. This was the first time i have driven it any distance. She didn't miss a beat! I just hope the mot tester has had a good night at home and is feeling good. Now all i can do is keep everything crossed!!!!!!!!!!! :|
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Oct 31, 2013 3:13 pm
Well ive had the results and she failed on a front brake pipe, front to rear pipe, horn not working correctly. And addvisory for a rear brake pipe so im having it all sorted at the garage. Will have a nice new ticket in a couple of day's!!!! :mrgreen: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Loneranger on Thu Oct 31, 2013 3:39 pm
Not to bad then Bobby, bet you cant wait.... :dance:
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Oct 31, 2013 6:24 pm
I certainly can't matey !!!!!!!!!!!! :lol: :crazy: :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Nov 01, 2013 8:13 am
Nice on bobby :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Fri Nov 01, 2013 11:08 am
Started it for the first time in a couple of weeks. she started first press of the button.
