Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Tue Jul 23, 2013 8:06 pm
Spot the difference.
Thanks to Foggy (aka Mr. Turpin) for the wheels and tyres, and to Stretch for ride height measurement.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Tue Jul 23, 2013 8:10 pm
The shadow is in a different place :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mickh on Tue Jul 23, 2013 8:49 pm
Dammit Andy youre quick.
mickh
Front winch.
CB radio.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by johnnybbad on Tue Jul 23, 2013 8:52 pm
Today i fitted my new leather interior :)
And ive got 5 of these to fit next week
johnnybbad
Modifications: none yet
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jul 23, 2013 9:01 pm
Don't think the fifth one will do much good as a steering wheel Johnny :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Tue Jul 23, 2013 9:07 pm
she looks good mick ;) (mr turpin my ass :butt: ) :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jul 24, 2013 12:31 pm
just cleaned the inside and waxoiled more of the underside...
getting it ready for sunday...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Jul 24, 2013 4:41 pm
Matt you can come and waxoil mine if you want :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jul 24, 2013 4:45 pm
you get the stuff and i will do it in about 20 mins :p
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed Jul 24, 2013 4:55 pm
Today as I wasn't at work again :thumbdown:
I didn't some work on the swb
Removed the sidesteps
Welded the hole in o/s sill
Welded the hole in the o/s rear bumper
Swapped the wheels so the road legal swb now has the pepperpot's and mud tyres
Trimmed the front bumper
Cut down the exhaust tailpipe
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jul 24, 2013 6:28 pm
and here's some pics
inside nice and clean... and i did even hoover inside, and fixed the fire extinguisher
and out side is cleaner than it normally is... still needs another clean, befor sunday
and one of the underside opf the front wing.. nice and waxoiled...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Fri Jul 26, 2013 9:22 pm
sorted out a sticking rear brake :D
and then started to remove some old peeling underseal :crazy:
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Jul 27, 2013 2:11 am
Not to the truck but I fitted a boost gauge to the A pillar of the cav. Not bad for a diy job :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sat Jul 27, 2013 9:08 am
Not me (well, not all of it, cheers for the help lads) Truck had it's rear shocks replaced at the BBQ/Spanner thingy at Bobbys. Bit of a job apparantly.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Jul 28, 2013 11:08 pm
Drove to Wales, parked up and watched some motorsport:
7 by Trugga, on Flickr
10 by Trugga, on Flickr
15 by Trugga, on Flickr
More here
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Jul 29, 2013 2:44 pm
Last night on leaving work i put the keys in the ignition but no lights. So thought what did i leave on? Checking i could see nothing. So i put the jump pack on and got dash lights and the electric fan that i had put in. I started It, took the pack off jumped in to be met by smoke billowing from my CB radio wires they were glowing nice in the dark. Turned it off. Checked under the dash to find that for some reason the new electric fan i had fitted had decided to start while i was in work and use all the power from the battery and then melt all the wires. I ripped them all out and managed to drive home. Its now sat on the car park looking a bit forlorn!!! Will sort it when i get time. I have disconnected the battery !!!! :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Jul 29, 2013 3:07 pm
The last week i have been sorting the drivers welding inner and outer sills of the Bighorn that the previose owner made a mess off. Once the rain calms down will do other other side sort the bubbling on arches then i will sadly be selling or swapping it.
Who ever let the idiot loose with a welder should be slapped he patched rust how he managed to weld a metal patch on to rust is amazing rather than cut the rust out he just welded onto it . Meaning i had to cut the 75% of it off an shape metal to match the original inner and outer least its solid again
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Jul 29, 2013 6:35 pm
Removed the gearbox from the 2.5. I couldn't be ar5ed to get underneath so I did this :lol: :lol:
Once the floor was out it it was so easy to lift the gearbox out
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich on Tue Jul 30, 2013 5:02 pm
Not mine but Alfie's 2.8 Changed the rear brakes and the front wheel bearing also secured his front seats as the bolts had come loose. Just a few more little jobs to do and it will be ready for it's MOT. :D :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Jul 30, 2013 10:39 pm
Went and collected my new boat and towed it home, much to sallys delight...
The mast on it was a bit longer than expected, and struggled to clear the discos roof, so had to angle it up a lot, which kinda made it stick up way more than was sensible...got some funny looks though...gonna extend the front of the trailer, which will make launching easier too...
Users browsing this forum: No registered users and 10 guests
