Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Jul 01, 2013 4:33 pm
Dunno if I have got enough vinyl for that Ste.... :butt:
You would do better with a vinyl wrap mate and do the underside as well :lol: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Jul 01, 2013 4:50 pm
Hmmmmmmm..... :think:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Jul 01, 2013 6:04 pm
wile we are putting reqests in
greg can i get a "S" in white. since i am missing one from my rear window..
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Jul 02, 2013 1:56 pm
I took the car for a spin and booked her in for the MOT tomorrow :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jul 02, 2013 3:26 pm
Good luck Drifty ... don't forget to fill the washer bottle and check all the lights (including the number plate ones which I always miss and if I do invarably one has blown)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Jul 02, 2013 3:32 pm
I do that stuff when its on the ramp if the tester does spot them :lol: :lol:
Cleaned and vac the inside aswell as cleaning and conditioning the leather :shock:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Tue Jul 02, 2013 5:17 pm
Nothing to the truck but broke the merc!!!
I was driving home from work down the motorway and looked in the rear view mirror to see a mass off black smoke!!
Didn't think it was my car then the car lost power!!
Pull over to the hard shoulder and had a bit of a rant to myself as I thought it was something major. Anyway pop the bonnet and saw a massive hole on the intercooler pipe that attaches to the turbo.
Pulled the phone out pocket to call the aa and remembered that I had some gaffer tape in the boot. A bit of red necking later I was driving home.
Just need to ring MB now and see how much a new pipe is going to cost!! :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Tue Jul 02, 2013 6:14 pm
took mine for mot cos i noticed it had ran out 24th june oops,,,, failed on a list of things so looks like am busy this weekend :)
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Jul 03, 2013 8:22 am
Good luck with the MOT's lads and keep us posted!!!!! :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jul 03, 2013 3:58 pm
Took it for its MOT.........................FAIL. :roll:
Took it outside and adjusted the handbrake.......................PASS :dance: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Jul 03, 2013 4:02 pm
Nice one drifty. I like simple resolutions :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jul 03, 2013 4:06 pm
So do I :dance:
Though it fails on the handbrake every year :lol: once I have an idea how much adjustment is needed I usually fix it in the car park :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Iceman80 on Wed Jul 03, 2013 8:42 pm
What I did on my fronty today?....
.....I kicked it in anger and put a small dent near the petrol cap. Clever!
Iceman80
Registration Year: 2000/V
Vehicle Name: Rusty
Modifications: 1000W ICE install - Amp in rear compartment, front grill debadged, air element removed
*Aftermarket Digi speedo and Digi tacho gauges to be added*
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rustynlc on Wed Jul 03, 2013 8:51 pm
Had to charge the battery as I left the lights on all day! :oops:
rustynlc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Jul 04, 2013 10:04 am
I am going to put fuel in it :shock:
First time I have done that since April :angel:
Then is man cave clean up, its a tip in there :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Jul 04, 2013 11:07 am
Once you have cleaned your man cave up do you want to come and do mine :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Thu Jul 04, 2013 8:04 pm
Started to remove the engine from the 2.5 because some one is interested in the short block and cylinder heads :dance:
Sorted half my arches to get ready to fit my 31"s.
Also sorted out the tracking and snaking at speed by swapping the tyres front to rear sorted it sweetly!! :dance:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Jul 05, 2013 10:08 pm
Took the truck for a short gravel track run and operated the 4H and 4L to give the associated parts a bit of purpose and lubrication. The auto-hubs engaged and disengaged smoothly and quickly.
The 2H-4H "on-the-fly" worked a treat too, with almost immediate engagement when selected.
