Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Jun 28, 2013 6:17 pm
Just loaded the truck up ready for a 500+ mile trip to Newcastle in the morning:|
Its Going to be a long drive as I am just picking something up I won on eBay and driving straight back :roll:
Will give the new truck a good run out though :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Fri Jun 28, 2013 11:28 pm
I hope that the cost of the item outweigh's the cost of the trip?????? :mrgreen:
I've driven mine to work because of the bloody weather again, I'm gutted !!!!!!!! :lol: :lol: :thumbup:
It will be a good shake down drive. :shock:
I got to use mine to get to a farmhouse where the alarm was going off but the Corsa would have died trying to get down the gauntlet of a drive. :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sat Jun 29, 2013 4:43 am
Not to the truck, altho the same will be happening to it soon. Just put a nice new danyco cambelt kit on the cav @ just over 207k miles. Think it must of had a new belt just before getting parked up for 7 years because the old belt didn't look much different from the new one (wear and tear wise anyway). And it only took me just over 4 hours! Not bad considering I was triple checking everything because I haven't ever done a cambelt before.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 29, 2013 11:35 am
After over two months of the truck not moving I changed the battery and turned the key an boom she burst into life without so much as a stutter :dance:
Now to service the old girl and a bit of waxoiling before the MOT due in a couple of weeks.
And I have done less than 3000 miles since the last MOT :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 29, 2013 5:24 pm
Wheel bearings nipped up and re-greased and the chassis, brake, fuel pipes and rear axle waxoiled.........shower time now to get the evil stuff off :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jun 29, 2013 8:37 pm
today i put the muds back ok for tomorrow
and then did some maths with the sus and decided this is the high i want the rear
and then i am in need to fab up some nice bits to have the fun :twisted: floppy shackles.. esp for the bunny :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 29, 2013 9:59 pm
Looks good...(well I would say that :lol: )...but what are you gonna do to bring the front up to match, or are you aspiring to the dragster look. :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat Jun 29, 2013 10:54 pm
well the front i am looking into it
i think i can go to prob +4 with a bit of fabing.. and will prob leave it there
so over +8 on the rear and +4 on front, for the little bit of a dragster look i think
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Jun 30, 2013 7:44 pm
and today
taken it out laneing :dance:
and nearly finished off my rear winch mount
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Jun 30, 2013 8:03 pm
why do you need a rear winch when Dan was in front of you??? :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Jun 30, 2013 8:16 pm
well it is for when i get stuck... i know rare as it is
and heres a pic
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by mudog88 on Sun Jun 30, 2013 8:57 pm
Tightened front wheel bearings, adjusted the valves, drained water from fuel filter and greased the prop shafts... Now to do an oil change and fuel filter and ball joints... While greasing the prop shafts, noticed the tail pipe is rotting, so another thing to add to the 'List of All Things Fronty'.
~1992/J reg Vauxhall Frontera LWB 2.4i (sold)~ (the Frontera that got me started on Fronteras)
~1996/N reg Vauxhall Frontera Sport S 2.8TD~
mudog88
Vehicle Name: Betty
Modifications: Kingpin Advantage 265/75/16's on black steel wheels.
2+in coils with torsion bars cranked up 2+
EGR 'birds nest' removed (turbo spools sooner and it actually reached max pressure now)
Skype Username: johnphillippoin
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Jul 01, 2013 12:39 am
Oil changes for both trucks and got a new rear number plate for O-no so I can move it from the bumper to the tailgate.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jul 01, 2013 10:25 am
Friday
Gave Kaz a much needed oil change. Black as sin and so so thin it was unbeleivable. Sourced the oil leak as well. Turns out the oil filter was only just tightened and spun off with no effort at all. Looked at the wiring for the oil pressure sensor and one terminal was corroded and loose. Cleaned it up and crimped it slightly to re-attach tightly. New oil and filer and gave her a quick run around the block. All works fine. Gauge now sits just above midway when driving and does the usual 2.3TD oil light on and gauge drops to about the quarter mark when idling. Happy days.
Saturday morning she had a baptism of fire as the other half's Ford Explorer has major piston blow by and is drinking oil quicker than petrol (and for a 4.0 V6 thats a lot). Anyways long and short of it is she has to borrow Kaz for work until she can get another truck. So we set off for sunny Northamptonshire bright and early. Was great to see Kaz trundling along in front of me. No smoke (apart from the occasional puff when changing gear). Averaged 70mph all the way (pretty astounding for a 2.3).
On the road:
Little and large when stopped for coffee:
On site getting her first taste of mud:
We put her through her paces I can tell you. Lugging some pretty heavy trailors (including a couple of diesel bowsers weighing in at around 4 tons a piece. You can see one in the backgroud of the last photo next to some portaloo's for a rough scale) which she handled with ease. I even tested the 4wd and it works perfectly with no noises or knocks. You have to love these old Frontera's.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Jul 01, 2013 3:33 pm
Got some new fonts for the vinyl cutter....so had a play...been thinking of you Ratty!!!! :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jul 01, 2013 3:45 pm
You prat Greg :D
in all honesty I may have a request for you ;)
Need to replace the ones removed when she had the respray!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Jul 01, 2013 3:46 pm
I am sure I can make "replacements" when I can get this cutter working :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Jul 01, 2013 4:19 pm
:rotfl: :rotfl: :rotfl: @Greg
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Jul 01, 2013 4:29 pm
Can you knock me a few stickers up for my MOT saying "Dont look here and I will give you a fiver" :lol: :lol:
Users browsing this forum: Google [Bot] and 12 guests
