Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 22, 2013 7:03 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jun 22, 2013 11:07 pm
So after Spending 12 hours on the 2.8 this all I got done.
Removed the ball bars and the front bumper with the angle grinder because the bolts were knackered. Then cut the old front smile out.
Removed the old steering box , steering idler track rods then replace the lot with the ones off the 2.5 as all the bushes were in better condition.
Rust dreated the chassis and replace one of the chassis front body mounts. Then cut the front smile I got off Greg to fit the whole welded all that in and painted it.
Flushed out the radiator, fitted the new fan belt.
After all that I took it for a small test drive and the steering is still the same as before :evil: I'm at a complete loss as the why now. I've checked the trailer arm ,panhard arm ,torsion bars, changed all the steering the only bit I do know is one of the upper ball joint has a small amount of grease leaking out of it. I will order a pair once I've fitted them I will book the car in for a four wheel tracking.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jun 22, 2013 11:13 pm
And tomorrow I'll be doing a couple of more jobs on the 2.8 that will transform the whole look of the car :lol: :silent:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 22, 2013 11:17 pm
You doing what I am thinking you are doing? 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jun 22, 2013 11:25 pm
What's that then :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Jun 22, 2013 11:26 pm
Camo??? :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jun 22, 2013 11:34 pm
No sorry mate it's not that. You will have to wait to see what I'm doing :lolno:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Sat Jun 22, 2013 11:49 pm
@ andytats. I could be barking up the wrong tree, but a mate of mine had a similar problem to yours on a RWD vehicle a few years ago. Every time he towed, it used to weave about.
Took him weeks to find out what was wrong, but it turned out to be rear suspension bushes. There was nothing visibly wrong with them, but they had gone soft, causing the rear axle to move slightly under strain.
As I said, this could be completely wrong, but ya never know
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jun 23, 2013 12:39 am
Techi talk guys :naught: :naught:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bhcalcutta on Sun Jun 23, 2013 12:45 am
:oops:
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jun 23, 2013 1:30 am
:lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sun Jun 23, 2013 6:20 pm
took the sump off to try and find the leak...
was only ment to be an hour job... or so i thourght
but the sump gasket was shot so replaced. and all back together now, 6h later... had to drop the front diff for access.
and i have found that my sump has a small crack in it too :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Jun 23, 2013 7:52 pm
Completely stripped the entire rear brake system.
Secured the offside front headlight with cable ties. Its more secure than the other held with the official mounts intact.
Fixed broken numberplate bulb wire.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fronteramac on Mon Jun 24, 2013 3:35 pm
took the 33's off the sport as a not so nice traffic policeman was goin to confiscate it if i wasnt goin to go home with it and didnt have another set to throw on ....as they stuck out an inch past the arch and his concern was a child mite get dragged under ,but it wud be ok if put wider arches on
fronteramac
2.8 td sport sold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Jun 24, 2013 5:59 pm
Started stripping the 2.5 of bits so I can list them on eBay :dance: so I can get the money back I paid out on it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jun 24, 2013 7:04 pm
New rear brake shoes both sides.
New rear nearside brake cylinder.
Cleaned and refurbished both rear brake drums.
Bled entire brake system.
Adjusted handbrake (so much easier than the Trooper).
Secured the other headlight with more cable ties. Both now not flobbly.
Now for the MOT retest.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Mon Jun 24, 2013 7:11 pm
Fingers crossed mate :thumbup: :thumbup: :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jun 24, 2013 10:37 pm
Cheers Greg. Hopefully it will be ok. Another one saved.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Jun 24, 2013 10:40 pm
Good luck fella!!!!!! :thumbup: At least we all know how you feel!!! :?: :thumbup:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Tue Jun 25, 2013 11:50 am
Fitted new key fob cover thingy ! :-)
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
