Washed it and looked at the shocks, might change them later once the mrs goes to bed.
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Wed May 22, 2013 7:50 pm
Part 2 sorted out the rear axel breather pipe because the diff oil was leaking from it then filled it up with oil. Whilst I was under the truck find a hole in the middle exhaust box and find one of the rear anti roll bar drop links had snapped.
Whilst I was doing the above Lisa cleaned the inside of the car then we washed it then a quick polish.
I still can't believe how good my tank guard is. I will be giving the underneath a coat of waxoil
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed May 22, 2013 8:48 pm
Got txt from Chrissy last night to say been allotment got flat front N/S Tyre. Had to drive it home as couldn't leave it down there. Got police escort with blue lights co's she was only doing 2-3 mile an hour. (Only Chrissy could do that!!!) :? So i had to get it fixed today, lucky not a lot of damage to the tyre wall. :roll: Then found her exhaust was blowing so fixed that then moved her CB radio to tidy the truck up a bit. :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dannyboy on Wed May 22, 2013 8:57 pm
Walked past the 2.5 on the way to work, then walked past it when i got home :roll: , thinking it might be time to let her go :cry: to someone that might actually use her, cos i just dont have the time to at the min and my year only gets busier from now on til the nose dive over Christmas :thumbdown:
Thinking cap is on :think: :thumbdown:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Roughshooter on Thu May 23, 2013 8:47 pm
Looked to see if the rad weld worked!!!!...... It didn't
So got some stuff the trade use to try free!!!!!
If that fails its strip down and new heater matrix ......Oh deep joy be changing it in the snow too if today is anything to go by
Snow!! End of mat Whats going on!!!!!
Treat every stressful situation like a dog...... If you can eat it or hump it......P**S on it and walk away!!!
Roughshooter
Vehicle Name: Tub
Modifications: None yet !!!! But I have plans
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Thu May 23, 2013 9:32 pm
Used it yesterday because the cavalier burst a coolant pipe...on my way back from the shop I drove past a lump of metal in the road that looked like a manual hub...bugger me I thought that's a find...I'll have that, pulled over, ran out to pick it up and started walking back to the truck only to see that the drivers side was missing its manual hub...dammit! Oh well, lucky all 6 bolts were still in the hub so should be a easy fix.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JEOH on Thu May 23, 2013 11:01 pm
Sorted the rear diff breather because of leaking oil see [urlhttp://www.fronteraowners.co.uk/viewtopic.php?f=6&t=53212&start=20]here CLICK[/url]
So tomorrow early morning another test drive - then: vacation with the soft top Frontera :dance:
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Fitted my replacement power steering pipe , as supplied in less than 24 hrs by Andytats , he being in Essex and me being in Liverpool.
All working and no leaks thanks once again Andy :drink: :drink: :drink:
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri May 24, 2013 9:09 pm
:thumbup: glad you have the car sorted mate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Fri May 24, 2013 10:06 pm
removed spare wheel carrier on the shorty and marked the board for the crossmember jig
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Kiteflyer on Fri May 24, 2013 10:35 pm
Made gazeddy remove spare wheel carrier after nearly harpooning myself on it again.
Ta little bro xx
for when sometimes 1 horse power just aint enough
Kiteflyer
Vehicle Name: The White one
Modifications: paint (washed it and its white not Green)
treated rust worm,
tyres
wheels
fuel line and service
Inch 1/2 lift
Lift 1-1/2 front
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat May 25, 2013 1:14 am
Managed to do the mounting for the 3 point harness, fits nice too! :thumbup: No fat jokes thank you!!!!!!! :problem:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sat May 25, 2013 4:40 pm
Welded the sunroof up. My welding is getting far better only blew one hole in the roof
Gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat May 25, 2013 6:55 pm
Had to do a bit of welding to the new trailer so the shorty would fit :lol: the shorty is 2 inches wider then the trailer so had to weld an extra 2 inches to one side.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat May 25, 2013 10:52 pm
Dove it to work!!!! WoooooooHoooooooo!!!!! Big smile on face!!!! :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Sat May 25, 2013 11:05 pm
changed the air filter
i think i must of had my air box open at the annual some time as it was very very muddy
but now got a nice new one and she does sound happier now
as well i put a new head unit in
was marked down from 240 to 100 and then i got another 20 knocked off to :dance:
so a nice new dab head unit with usb/aux in cd/mp3 player for all of £80
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat May 25, 2013 11:49 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun May 26, 2013 12:48 am
welded a new cross member into the trooper. And enjoyed the Sunshine in Scotland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sun May 26, 2013 7:49 am
I did think of that Greg but I wanted the keep the weight to a minimum
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipo1024 on Sun May 26, 2013 8:02 am
Plus its a pain to keep swoping wheels over :P...and how much long do we have to wait to see some pics of your truck then Andy....:P
